Quite simply when I turn on my camera (it is about 3 yrs old, and has fallen on one occassion) it gives the message "System Error" on the screen. After a few times of putting it on and off, it will work, or sometimes if the mode is set to review, it will show the current picture stored on the card, but if there is no "valid image" to display it goes back to the error message. Please help.
Comments:
May 06, 2006
- Thank you so much, that helps alot, now that i can narrow down the problems. It is working now, before i read ur solutions, but I do think that it could be the lens or sand and grit problem, because the problem did start when i was in a very "sandy" country. Is there a cleaning method for this?
-   i have the same "system error 0009"message shown whatever i turn the cam on and off beside the lens is always in zooming condition.-   marmoush
Dec 26, 2007
-   i have the same "system error"message shown whatever i turn the cam on and off beside the lens is always in zooming condition.
what i can do? do i have to take it to a profissional technical to try reinstall the camera software driver?-   sherief
Nov 12, 2007
-   anytime i swithch the camera on, it simply gives a 'system error' msg -   pngithuka
Best Solution
posted on Jan 22, 2007
Guest
Rank: Apprentice
Rating: 0%, 0 votes
why dont you try helpin with the problem, like having a section tht you can type the error code in!!!!!!!!!!!!!!!!!!
So you have any other memory cards? You may want to try that first. What batteries are you using? Can you try a new set of NiMH batteries? not alkalines but NiMH try these things first because they are easy. If you have tried different memory, and different batteries then it could be a connection problem inside the unit.
These cameras dont have may circuit boards so they use ribbon cable to connect the different componets together. These can sometimes work loose. An impact can vibrate them just enough to cause the problem. It could also be the lens mechanism. Sand and grit can work into the gears and bind them up. If it zooms in and out smoothly then this maynot be the problem. If you hear any change in the speed of the motor when its zoomed in and out that could be it.
warum memory card error bei panasonic lumix bei anndere foto apparat ist alles ok?Bitte antworten...
(More)
warum memory card error bei panasonic lumix bei anndere foto apparat ist alles ok?Bitte antworten sie auf deutch...!
I have a panasonic Lumix dmc-fs3 camera that I have barely used. Now when I put the memory card in...
(More)
I have a panasonic Lumix dmc-fs3 camera that I have barely used. Now when I put the memory card in it doesn't recognize it. When I turn the camera on it says "pictures will be recorded to built in memory" . When I try to copy the built in memory pics to the card, it won't let me access the "copy" function. Under the "format" function- it doesn't recognize the memory card either, instead asking if I want to delete the built in memory. Any suggestions?
The flash scroll button does not work. The up and down arrows work but not left and right. Can this...
(More)
The flash scroll button does not work. The up and down arrows work but not left and right. Can this be fixed?
When I swithc the camera on it does a few whirs and clicks then comes up with the "blue screen...
(More)
When I swithc the camera on it does a few whirs and clicks then comes up with the "blue screen of death" on the display. The lens are also extended and stuck in position and when these try to move under power the above fault comes on. Youa are able to view the pictures on tehcard so I guess it is the lens operating mechanism that is faulty.
I turn camera on. Lens goes out, lens comes in...and then I get blue screen with "system error". HELP!
