Question about Rio Sport S35S MP3 Player
Volume button stuck
The volume contol is stuck in the all the way up position. Do you know where I can find a free online step by step schematic to assist in taking the whole player apart?
    President:
  • 3,130 Answers
There is no such thing Even repair places dont have a step by step manual. The problem you have is that the plastic button is broken off the tab and not returning to the up postion or the little switch actuator is cracked . you probably need a new case and it may need to be sent to the factory for repair. Try this # first then try to look them up online or look in the owners manual where to call or send the unit. Good Luck Main support number(254) 299-2759
Posted on May 07, 2006
My nexus 7 wont go past multicoloured x.. cant switch on/off. tried hard reset and nothing works
Important:Plug your device into power outlet
Step 1: Power off Nexus 7
Step 2: Power on while holding Volume Down/Up
(enter BootLoader)
Step 3: Press Volume Up to toggle to "Recovery Mode"then press power to select
Step 4: Hold The Power Button and tap Volume Up when you see "No Command"
Step 5: Press & hold Power Button & Volume Up Button Again
Step 6: Toggle with vol down and vol up / power at wipe data (all data) & reboot
Nov 20, 2013 | ASUS Google Nexus 7 8GB Tablet Unlocked...
Alternator schematic diagram
Go to online site of Autozone, Oreillys...etc and you may have to register but they have free online step by step manuals and schematics.
Nov 05, 2010 | Nissan Sentra Cars & Trucks
My Sony Trinitron volume goes from mute (1 bar) to loud (2 bars) - can increase to even louder but can't get low or medium volumes. The lowest volume is too loud for normal viewing. Any ideas about what I...
Hello
If you have some idea about the working of your TV, and some service experience you can do it by yourself. Your TV has electronic volume controls. That means, a gradual voltage rise or lower does the volume to go up or down. This voltage variation is done by an Ic which we call it as "System Control Ic", that every modern TV has; but differ in their type and number. You must know how to follow the schematic diagram of your tv to get the exact point from which the voltage orginates, and which point regulates the same.
At present there is some voltage, say 0.23VDC or so, remains at that control point even if you turned all the visual controls seem to be off; and that voltage suddenly goes up; say 3.05VDC or so when you adjust the volume to the near mid stage. Further saying 3.05VDC must come only after you have turned the volume bar to extreme high. Now you are listning your tv at is 1/4th volume at extreme low I thinks.
Looking for fault at system contol section must be done with patience, and should have schematic diagram of it, and some sort of skill. It is best for you to get service of an experienced service personal, otherwise the the faults will be rise in numbers. All sony tv has complex schematics even go to pages on a book, and have some difficut to follow even an experienced one you know. So think a little better and do the needy.
If you have confidence that you can reach the the above said points, contact me at my mail address which is given below. I will guide you. You must have the schematic digram of your tv also beside you. Ok.
gopakumarg43@ymail.com
Oct 19, 2010 | Sony FD Trinitron KV-28FQ75 28" TV
I have a Vizio VX37L, the volume will turn up by it self and you can turn it down but the volume will go right back up. The volume will also decrease as well on its own. Sometimes it will change channels...
check to see if the buttons on the side are stuck in the down position, kinda hard you have to feel it. Vizio buttons do get stuck. sometimes you have to unscrew the back of the tv and replace it correctly so the buttons are not pushed down. if the buttons are not pushed down you have to buy a button control board. if you were able to unscrew the back, you should be able to see the board where the buttons are, look online for that board, they usually cost less than $30 but you need the right board. once you replace it (make sure power is off when taking back off) replace the back of the tv and you should be set. there is also some kind of spongy material that will get stuck, but if you're experiencing the problem with two different buttons then i suggest they are stuck or the board needs replacement.
Aug 20, 2010 | Vizio VX32L Television
Want to know what the control button are on my steering wheel
good day, volume control and radio control frequencies are usually attached on the steering wheel. hope this helps, have a nice day
Feb 07, 2010 | 1996 Ford Probe
I have a dell Vostro 1510, Ive had it for about a year and havent had any problems...until now. As you know above the keyboard there is a row of touch sensative buttons; eject button, volume contol, play...
After a long use, some keys get stuck i.e. it seems normal but the button under the key remain in contact. Your problem seems like this. Try to open the key board and check the button. It may solve your problem.
Aug 02, 2009 | Dell Vostro 1510 Motherboard System Board...
Volume stuck in high position
Make sure that the volume + button on the front is not sticking. If it is spray a little WD40 on it and free it. Then you should have control over the volume.
Apr 05, 2009 | RCA F32648 32" TV
Volume stuck in 100% flashing
try to reset the lcd tv but if reset will not fix it then the unit should be taken to the nearest repair service center to fix it.
hope this helps.
Sep 08, 2008 | Akai LCT3285TA 32 in. LCD Television
I am having problems programming the remote
Programming a GE Universal Remote Control takes about seven steps. Step One: Manually turn on the device you wish to program. Step Two: Press the Code Search button on the remote until the indicator light turns on. Step Three: Release the Code Search button. Step Four: Press and release the button for the device you are programming. Step Five: Enter the three-digit code for the device using the number buttons on the remote. After the code is entered, the indicator light turns off. Step Six: Aim the remote at the device and press the power button. The device should turn off. Step Seven: Press Channel Up on the remote with the device on. If the device responds, no further programming is required. To look up a device code to enter directly into the remote, visit the GE Remote Code Locator Website. http://www.jascoproducts.com/support/dow... http://www.jascoproducts.com/support/dow... Hope this helps, Good Luck :) Please Vote
Jul 01, 2007 | GE JASRM24977 Remote Control
Volume/ channel/ remote not working
I just used the following instructions from this site on my 'totally dead' Ilo remote and it worked like a charm! I did step 2 twice on each key and put the batteries back in and it worked great! Hope this helps you too. "Dead" Remotes Can Be Saved How to Re-Start Your "Dead" Remote Control This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls. Good Luck! Step 1- Pull the batteries out of the remote and leave them out until Step 4. Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once! Step 3- If your remote has slide switches, you must move the switch to each position then repeat the button pushing in Step 2. (When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!) Step 4- Put the batteries back into the remote, being very careful to install them correctly. New batteries should be used if you're not sure about the old ones. Step 5- Try the remote. If it works, Great! If not, it's time to call 1-800-Remotes or use this website to order a new remote.
Dec 01, 2006 | iLO 2600 Television
Rio Sport S35S MP3 Player Logo
Top Rio Audio Players & Recorders Experts
Mohammad Abumuailek
Mohammad Abumuailek
Marvin
Marvin
Joseph Hoffmann
Are you a Rio Audio Player and Recorder Expert? Answer questions, earn points and help others
