Question about Sony Playstation 3 (PS3) Console
Hey :) new ps3 cuming up mode not supported on tv
  • azbanshee22 Dec 30, 2008
    I have the same problem ,mode not supported.
Stupid ******
Posted on Sep 13, 2008
Trying to connect PS3 to Samsung HL-S4676S tv using HDMI cable. I get message saying mode not supported
So I had this same problem. I found that when I hooked to a 1080p TV my PS3 was working, however when I hooked to my 1080i it said Not Supported Mode. So I then hooked to the 1080p and told my PS3 to limit it's self to 1080i mode and hooked it to my Samsung TV and it worked just fine. Give that a try and it should solve the problem. Hope this helps.
Oct 09, 2010 | Samsung HLS4676S Television
Hey guys i gave my ps3 to a shop in st neots to get my hd working and he blew out all the dust with a air gun and changed the settings and said the ps3 is set up for hd now and it worked on the shop tv but...
When changing the display mode of the PS3 you must be in the correct mode and be using the correct wire. If in the shop it was last set up in HD mode, then you must be using an HD cable (component cable(wire with red/yellow/white) will not work. Also, make sure that your TV can handle the resolution it is set in. If your TV at best handles 720p and the PS3 is set in 1080, then you will have to hook it up to a TV with 1080 to change it back or you will not get a picture.
Aug 27, 2010 | Sony Playstation 3 (PS3) Console
Cannot connect my ps3 to my tv. keep getting (mode not supported)on a black screen. anyone help ?
Check the supported modes in your user's manual for the TV. Check the output mode of the PS3 from its manual. Can you find any that match? If not, then you can't make it work....
Apr 23, 2010 | Samsung LE32R72B 32 in. HD-Ready LCD...
Mode Not Supported
Set the PS3 to 1080i for your HL-P5663W. I verified the owners manual and this TV does not support 1080p even by PC input.
Mar 14, 2010 | Samsung DLP HL-P5663W 56" TV
I have a new ps3 slimline,cant get a connection t my samsung HDTV
What you need to do is use a different tv or scart/av cable first, go to settings and reduce the resolution its because the tv cannot handle such a high res, if this dosent work, please post back, Regards
Dec 25, 2009 | Sony Playstation 3 (PS3) Console
PS3 will not work on new tv using HDMI cable ?
you have to re sync your playstation when you go from HDMI to regular wires.
after you connect ps3 to tv.
hold down the power buttondown on the ps3 for like 5 seconds (1 beep then another ),
after you hear a second beep the ps3 automoatically adjusts itself to whatever it's connected to.
Feb 26, 2009 | Samsung Televison & Video
Blue ray wont play movies on new tv
Are you sure the tv is 1080p capable? Usually when "mode is not supported" is displayed, it means that the tv can not handle the signal format that is being input to it. If you are using HDMI, then signal formatting is usually handled automatically. If you are using component video, you will probably have to tell the PS3 to step down the signal to either 1080i or 720p.
Jan 10, 2009 | Insignia 37" LCD Flat-Panel HDTV
Ps3 locking up brand new ps3 & new tv
hey i have an older ps3 one of the first ones during assains creed it says that it is unable to save and then it will freeze up what is wrong? kreft_james@yahoo.com
Sep 03, 2008 | Sony Playstation 3 (PS3) Console
Sourondsound hook up
Hey jessyqadir,
If your home theater system's speakers still aren't functioning, you may want to make sure that your TV is correctly set to an external speaker mode. This can typically be done by accessing your TV's audio menu and choosing an option titled "Sound Select" or something similar. Many TV's will have a variety of speaker configurations they are able to support by default, but must be correctly set in order for audio playback to be heard through external speakers.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 20, 2008 | Samsung LN-S4041D 40 in. LCD HDTV
Sony Playstation 3 (PS3) Console Logo
73 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
