Since it is likely dark already, if you haven't fixed it yet you will need to fix it before the next party. There are two issues, finding a new fusable link and figuring out why your fusable link opened. If I am correct, the fusable link opens when heat from the heater goes past it instead of out the exhaust vent. For this reason, if you only replace the fusable link it will also open when heating unless whatever causes it to open is not repaired also.
I hope this helps.
That will usually be when to much air comes into the chimney that results in the flame going out, or, the blower assembly is not good anymore which will result in less air flowing thru the boiler.
I solved the chimney issue with raising the chimney above my outside wall (if it isn
