Acoustic Solutions TFT LCD TV - Red Lines
Hi
I have an Acoustic Solutions TFT LCD TV. When turning the TV on, Red Lines appear instead of the picture. They gradually move around the screen. Eventually the picture appears and the TV works fine until the next time it's left off for a while and turned back on. The problem then reoccurs.
I'm using Freeview Digi Box and DVD player on the Scart Inputs and an Xbox 360 on the HD Input. The problem occurs on both the Scart and HD Inputs.
Does this mean the TVs on its way out? Or is there something I can do to correct this?
Any help much appreciated!
Thanks
James
  • 4 more comments
  • Anonymous Sep 28, 2008
    I have a Sharp Aquos 52 inch lcd screen - the red lines appear in strands along the left side. They extend about 1/6 of the way over (left to right). Sometimes when HD picture is off (commercial for example) the blacked out portion on the left is good and black - sometime the lines become blue/green. Once TV on for a while and I turn it off and on, the problem goes away.
  • sikafo Nov 12, 2008
    red lines accross with sound but no pictures at all
  • doyle22 Nov 17, 2008
    i have exacltly the same problem with my acoustic solutions. dont know what to do. email doyle22@hotmail.co.uk
    thanks
  • Anonymous Jan 09, 2009
    when tv turned on and set up with digi box, xbox dvd player the picture is visible but with lots of red in sections.
  • billybirtles Jan 09, 2009
    when tv turned on - red appears on the screen in relevant sections
  • davcham Mar 18, 2009
    I have a 37" Acoustic Sloutions LCD TV thats about 6 weeks old and has just started the red lines issue when turned on.. We get two thin horizontal line appear one at the top of the screen and one on the bottom againts a black back ground with no sound.. At the moment if we turn the set off and back on again it sorts it's self out..
    Guess it's gonna go back to Argos...
Get it repair
Posted on Apr 02, 2009
Tv power cuts on power light lit no picture then Tv turns it self off, when picture appears there's waves in picture and tv turns itself back off and on with no picture just black scree
Hi Patty
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
If your TV, flatscreen, or monitor is more than 5 years old it is more like to have suffered a component failure.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
May 14, 2015 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Power light turns green then red no pic or sound
Hi David,
- Flickering screen
- Dim screen
- Slow start
component failure.
May 13, 2015 | Televison & Video
Acoustic Solutions LCD37805HD. When I turn on the main power button on the TV, instead of the blue standby light only coming on, the screen turns on and flashes alternately between red, green and blue
In most cases, scree flashes will be due to a faulty main power supply regulator board. If the DC voltage comes out from it is abnormal, this could happen. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 10, 2014 | Televison & Video
Acoustic solutions lcd tv astv15id last used 2 months ago perfect ,switched on today perfect picture but no sound
Hi I know this was posted months ago but the answer may help others, I found the capacitor C852 1000Uf ,35v was bulging at the top which is on the power supply board the number C852 is for the acoustic solutions model lcd42762f1080p tv (but this info would apply to most acoustic tvs: WHEN TESTED THE CAPACITOR ON THE ESR METER READ OK, but cos it was bulging at the top I knew it was faulty, it seems that it was breaking down under load hope this help regards celestica
May 18, 2010 | Televison & Video
Bush lcd tv has sound but no picture when switch on tv screen is blue then goes black and you can hear the proggramme that is on
acoustic solutions lcd tv when i switch it on the screen flashes blue, green then red no picture??? it was working ok last night any ideas?
Jan 23, 2010 | Polaroid FLM-2632 Television
Acoustic solutions lcd 22''tv turn it on then it turns it self of
Acoustic Solutions 32 lcd hd Tv screen has green/blue contrast shadows all over the light images on the screen. I have tried changing all the picture setting to no avail.
Aug 22, 2009 | Televison & Video
Acoustic Solutions backlight comes on then resets TV to Standby
Probably a burned out transformator in the backlight inverter
Jul 16, 2009 | Televison & Video
Screen shows blue patches on white also red lines on dark colour
Replace the video board, if you can find one. Letting it cool down will not help any.
Nov 13, 2008 | Televison & Video
Televison & Video Logo
855 people viewed this question
Top Televison & Video Experts
