Question about Sony FD Trinitron WEGA KV-32FV300 32" TV
Flickering Hey my tv flickers on and off black . cable comes in fine but flickers while playing. Also does this on the input channels. what do i do do fix this or what part of the inside could be harmd to cause this problem.
  • Anonymous Jun 02, 2008
    I have the same problem. The picture and sound both flickers. After running for 3-4 hours the flicker stops.
    Please help.
  • sundangela May 11, 2010
    yes sound stays on
    President:
  • 3,130 Answers
When you say flickers?? does the sound stay on or does the whole set go on then off or is it just the picture that flickers on and off and sound does flicker too? need more info please.
Posted on May 06, 2006
The projector try to started and flicker then goes out.
Posted on Feb 20, 2012
I have a 32" RCA LCD tv , rlc3210 power input says
Is it hooked up with HDMI cable?
If so try unplugging the HDMI cable and re plugging the cable in, sometimes those cables work loose and if they are not tight, it will cause your screen to flicker. Happens to my TV once in awhile.
I’m happy to assist further over the phone at https://www.6ya.com/expert/robert_54ae41aaaffbab00
Aug 23, 2013 | Televison & Video
My 32in spectre tv flickers black, when I turn it on it sometimes stays on for a lil bit than starts blinking black again and when I play my Xbox I can still see what I'm doing on the screen but it...
If you have tried using different input devices, looked for loose contacts
in power outlet, RC Jack, cable and connectors, the TV might need service.
Aug 23, 2012 | Televison & Video
Why is my tv flickering and how do i stop it
Before you go to drastic measures and since the TV section is fine I would check to see if the Xbox display format is set compatible with your source input. In another words make sure the resolution is set correctly or at least play around with that setting for the xbox input on the display. Just like the same thing on a computer screen if the refresh rate is set too low or the resolution is not set correctly the display will give you problems. Flat panels these days are nothing more than digital display panels being fed with TV or other signals. Therefore there are some common terms with that of a computer display.
You might also try a different input on the TV as that input may have a different setting on the display.
Aug 10, 2012 | Televison & Video
Tuning My Tv
If you've store the earlier channel, off the tv and on it again. Every should come back as normal.
Regards
alan
Mar 02, 2008 | Televison & Video
White horizontal flickering lines
If still under warranty, take it back. but first check your cable input connections or cable signal may have went bad. Lastly it could be the signal module inside.
Jan 02, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Certain HD settings won't work
no the set uses only two settings in the Y, Pb,Pr which it swithes back and forth. when a 480i,480p SD singal is detected it will switch to 480p, when an HD signal is detected it swiches to 1080i. when it swiches the picture scrambles for a second or two. to correct this in your cable box (if it's a motorola box) leave the tv on, press the power button on the box to shut down the box. next press the menu button on the box and the internal menu will show. use the cursor buttons on the box to select "480i overide" use the arrow to the right to select "streached" them hit menu to get out. hit the power button to turn the box back on.
Dec 16, 2007 | Mitsubishi WT-46809 46" Rear Projection...
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
Flickering
When the TV is flickering, do you notice any noise in the audio? If so, it could be a loose connection inside the set or a High voltage transformer going bad. Does it constantly flicker or come and go. If the latter, can you slap the side of the TV or jar it to get the problem to come and go? If so, it is likely a bad connection inside the set. I'm assuming that when you were playing the movie that you used the A/V input jacks rather than using the tuner on channel 3. Otherwise the tuner could have bad connections or bad grounds inside. A repair shop will most likely have to fix this problem. If the set was over 9 years old however, I'd upgrade to a new HDTV set.
Jan 01, 2007 | RCA P46812BL 46" Rear Projection...
Sony FD Trinitron WEGA KV-32FV300 32" TV Logo
1,982 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
