Question about Onkyo TX-SV646 Receiver
Channels missing on Onkyo TX-SV646
I have an older late 90's Onkyo TX-SV646. I have lost all surround channels except for the right main. Is there an easy fix to this without tossing it on a busy highway. Yes it is a bit dated, but since we just moved into a new house, I don't want to afford a new 7.1 THX at this time. Mainly I don't want to start that discussion with my wife, cause her solution is to dust off her off brand college stereo receiver and use that. Which to me is UNACCEPTABLE, it has poor sound quality.
  • 4,234 Answers
These units are quality units. The fix is not the easiest. We need to determine whether the problem is the output amp sections or the processing side. Worse case, the cost would be around $50-$75 for parts plus the local labor rate. Given your description, it will be difficult to diagnose remotely. One alternative is to get a detailed repair estimate ($50 or so) and post the results here. We can walk you through the actual repair.
Dan
Posted on Sep 12, 2008
Where is the aux/tv button on the onkyo tx-sv646?
If there is no button on the front panel with similar identification, there may not be one.
Apr 28, 2014 | Onkyo TX-SV646 Receiver
ONKYO TX-SR701 - Hi When using the speaker config I can get output from all speakers but the Surround back speaker R does not work. I do get sound from Surround back L. It's a bit confusing as the...
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Onkyo-TX-SR701-Receivers-manual/id/365ag222/t/2/
7.1 would have Surround Back L and R.
6.1 would have just one back there (SB). It defaults to the Left output on the Pre-Outs if you ever go that route.
This being a 6.1 receiver it does not support two SB channels BUT you can configure those amp channels for a separate Zone supporting 2 speakers. Confused?
The manual shows a single SB speaker connected to the left side on Page 27. THAT would be consistent with a 6.1 configuration.
Jun 04, 2011 | Onkyo TX-SR701 Receiver
I have an onkyo tx sv646 and i would like to get a manual and remote for this product
remotes.com for the remote and onkyo website should have the manual available for downloads if you want the original manual you may always try ebay
Sep 24, 2010 | Onkyo TX-SV646 Receiver
Hi! I have onkyo TX-SR308 and i surround problem.
You need to tell it you have surround speakers. Page 30.
The manual is available here...
http://www.onkyousa.com/model.cfm?m=TX-SR308&class=Receiver&p=d
Apr 28, 2010 | Onkyo HTR500 Receiver
Describe your Onkyo TX-SR875 7.1 Channels Receiver Problem All right channels are not working. Left channels including center channel speaker is working. Please advise.
Recommend changing your FINAL drive AMP IC most house BOTH right and left channels, your drivers right channel input is good cuz it is used to make the left channel signal
Nov 22, 2009 | Onkyo TX-SR875 Receiver
No audio out
Have you check the button Tape 2/ Monitor not have bin set to on? If you press this botton all sound is gone no mather what other button you are pressing.
Regards
Peter
May 04, 2009 | Onkyo TX-SV646 Receiver
No sound from Left and Right front speakers
You didn't state it but I assume the other channels are functional?
The auxilliary channels are generally lower power and may even be serviced by a different voltage than the main amps. If it is so designed, you may have something as simple as a blown fuse for the main amp supply.
If the aux. channels are equal in power, the power supply may still be dividing the load so a fuse still could be at fault. The unit could also use integrated power amplifiers in which case, if two channels are operating from a single module it could be a module failure.
I don't see much chance of anyone repairing this system without examining it in the first person.
Jan 04, 2009 | Onkyo TX-DS989 Receiver
No Sound
Tell me in details how you connect your whole home theater system.Step by Step.Video and audio connection please.
I need to know does it happen only on certain component(ex. dvd player?)
solutiondoct
Oct 21, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
Onkyo TX-SR500 Dolby Digital problem
I just read over the problem you were having with your Onkyo TX-SR500 receiver. It sound like the unit needs to be setup for all five channels.Sence your symptom says the diplay shows Dolby D3/2.1. According to the owners manual with the remote control look for speaker setup whin the button is pressed the current speaker setup will be shown in the display. Press the preset/adjustment<> to change the current setting to five speakers. the listening mode will automatically change according to the number of channels you selected. Hope this helps. Radiotech
Aug 14, 2007 | Onkyo TX-SR500 Receiver
344 people viewed this question
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
