the screen has like waves going across,it comes and goes,ive tried different cables,and i moved it to another room,and tried it on another pc but it still the same.
3 Other Users Have The Same Problem
Comment by CITYWEB, posted on Dec 31, 2007
MODEL L1552S LG MAKE
WAVES IN TH MONITOR
Comment by Guest, posted on Dec 31, 2007
MODEL L1552S LG MONITOR
Comment by Carol49, posted on Nov 11, 2007
I just bought this monitor today. There are waves that go across the screen from left to right continuelly. I called the store. They think that the cable is not tight. I checked the cable. It was tight. I swapped cables, but it the waves (ripples) are still going across the screen.
Was this solution helpful? Show your Appreciation by rating it:
measure the ESR on them, the higher it is, the more likely you are to get ripples.
If this doesn't say much to you, take it to a lab. Use the warranty if you have it offcourse.
Good luck
Rating: 0%, 0 votes
and try not to place monitor next to microwaves, magnets or high power electircal devices.
I think I've fixed it!
I went into the display settings where you can control the screen refresh rate (display properties > settings > advanced > monitor).
The only option listed was 60 MHz. Bummer. I was sure that was it.
Then I unchecked the box that says only display settings that this monitor can display (or something like that). I then selected 75MHz. Bingo!! It worked
Post a New problem for HP D5060A 14 in. Flat Panel LCD
Email this problem
