Question about GE 106591 Coffee Maker
GE coffee maker model # 169164 making too much steam, not coffee
Hello, I bought this coffee maker at Wal-Mart a few days ago, most of the time it just makes huge amounts of steam, from the drip head area. It acts as if it is out of water when there is lots of water in the tank.
It shoots steam 3 or 4 feet into the air, and boy, is it hot!
Thanks for any help.
  • GE Master
  • 5,568 Answers
If you look at the bottom, you'll probably find 'China' on it.
The problem you are having normally doesn't show up for a couple of months after the lime has had a chance to roughen the ball in the check valve that makes up the pump. Your pump isn't pumping.
I suspect you have some particulate matter that has made its way to the primitive check valve and the ball is not moving freely as it should. The copious amount of steam you are getting is from the bit of water that makes it to the heating element before the (yet to fail) thermal switch that cycles the heater element.
If you have a clean turkey baster, you may be able to flush whatever crud there is in the water path through to the outlet over the coffee basket by sticking the tip into the water chamber's exit hole. We have a large veterinarian's hypodermic that does the job nicely when it is time to flush it again and soaking the water path with vinegar every few weeks overnight will help keep it pumping properly too.
If the flushing doesn't work, take it back before GE gets completely out of the appliance business.
(Whatever happened to Silex??)
Posted on Sep 28, 2008
I need to purchase new filters for GE coffee-maker model number 169164
I'm not sure whether you mean the charcoal filters or the basket filter for the coffee. I have the exact same basket that I bought years ago as a replacement for a different pot, so I doubt that would be a problem. You can try your local Walmart for the charcoal filters since this model was sold exclusive contract with that chain. Depending on the size of your Walmart, you might have to special order those. Otherwise, they are available at most super centers. Just as an added measure, you might want to try washing the filters and using a coarser coffee grind before you buy new ones.
Dec 19, 2009 | GE 106591 Coffee Maker
Broke glass carraffe, need to replace model 169164
I replaced my broken carafe on model: 169164 by purchasing a RIVAL 12 cup coffee maker PIL-HC08104 from WalMart for $10.24 and simply put my black handles on the new pot whaic had white handles. The pot appear to be exactly the same.
Nov 01, 2009 | GE 106591 Coffee Maker
Past 2 mornings, coffee maker only brewed 10 out of 12 cups.
It's probably time for a good cleaning. Follow the procedure in the manual, or get some commercially available coffee maker cleaner. When the minerals build up enough, the water flow and heating is reduced enough to keep it all from passing through.
Please take a moment to rate this solution if it's what you needed, and thanks for asking here!
Jan 27, 2009 | GE 106591 Coffee Maker
GE Model 169164 Paper Filter Size?
# 4 coffee filters made by militta. I have the same maker and i hate all the coffee grinds in the pot
Oct 20, 2008 | GE 106591 Coffee Maker
GE 4 cup coffeemaker Replacement Pots
I found them on amazon, click here and take a look: Amazon com ge 4 cup coffee pot replacement. have a nice day
Oct 04, 2008 | GE 106591 Coffee Maker
GE coffee maker
If it failed after working a short while, the thermal fuse used in all drip coffee makers is frequently failing and we have had exactly the same experience with another brand. Our toxic Chinese friends are making crappy thermal fuses along with about everything else.
Replacing these is impractical since they are in a small metal case, pointed on one end with two coaxial leads permanently attached. Further, they are welded  to wiring under the warming plate to the heating element. The area is too hot for solder and ceramic wire nuts have to be used to replace the fuse and these are tough to find anymore.
Bypassing them is a really bad idea since I know of one case where the thermal switch that causes the machine to cycle, failed, the heating element melted through the aluminum plate on the bottom and set fire to a kitchen counter.
With the cost of labor being what it is, hardly any of these drip coffee makers are worth repairing.
Apr 15, 2008 | GE 106591 Coffee Maker
Kenmore replacement carafe
Replacement carafe can be found on amazon, here: Amazon com Kenmore replacement carafe. Wish you best of luck. Mike
Nov 16, 2006 | Kenmore KBC12 Coffee Maker
GE 106591 Coffee Maker Logo
644 people viewed this question
Top GE Coffee Makers & Espresso Machines Experts
Joseph Hoffmann
Eric Taylor
Are you a GE Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
