Question about Thomson Lyra PDP2842U MP3 Player
HD won't connect
Big Problem. I've dropped the player and when i turned it on the text "Filed to load files Resen unit to resume operation" "Update Lyra Hd Files System if problem persists" I found the recovery program, but the player won't connect anymore to USB. I had uploaded 4000 songs, help help help! How can i fix the connection?
    Scholar:
  • 148 Answers
Whoa, i've been so busy lately, I almost forgot about this place... Unfortunately, this is yet another mp3 player HDD problem. It's broken and there is nothing you can do to fix it except replace the hard drive. I hate to tell you this, but your songs are lost. If you desperately must try everything to get the songs back, I would suggest freezing it in the freezer (put it in a plastic bag if you fear moisture getting into the unit). After removing it from the freezer, you'll have a one to two hour window to try to get all the songs off before the hard drive thaws and you won't have access to the songs anymore unless you refreeze it-the window will shorten everytime you do this. The reason freezing MIGHT work is because most hard drive failure problems deal with the actuator arm touching/scratching the platter in which case the platter is being damaged and/or information cannot be read correctly. The coldness causes the arm to contract and stop touching the hard drive. Be aware that there might be more damage than freezing can rectify and the actuator arm might not be the problem. But hey, it's worth a try. If that seems a bit extreme(and indeed it is), you can send it in to a hard drive recovery specialist such as one listed here: http://dmoz.org/Computers/Hardware/Storage/Data_Recovery/
Posted on May 06, 2006
SOURCE:
I dropped Hitachi external drive...
If you have no backup and your drive is damaged, that is it, no data.
Plug the usb in with your drive, leave your computer looking for the drive. If windows, it may take some time. If Mac it won't be long. If neither can see it, the TOC is damaged and it will need a computer engineer to try and recover the drive.
May 28, 2017 | SimpleTech by Hitachi SimpleDrive Rev. 3...
How to add videos
Don't know this unit so this is general for most players.What I know is that the problem I' ve had(and solved) is that Audio/Video files are unique in that there are many types, AVI, MP4, RM, DVIX .MPEG.FLV..... In addition resolution can vary, Then There's CODEXs . You must find out what file, files are supported by your player absolutely first.I have loaded files onto players and they don't even show up on menu folders or it's Drive. Many players have websites that you can download converters/media managers that are supported by your player.Not every file is convertable.Once you learn what you can convert to put it on your player is easy,either with media manager or drag and drop onto the unit when attached to the computer look for the new Drive letter that's your unit.This problem is frustrating but once you do the steps I've instructed it will work.Good Luck.
Sep 17, 2009 | GPX ML848B Digital Media Player
Sylvania SMP2002 Shuffle?
how do i play the songs on my songs on my sylvania smp2002 mp3 player because it wont play
Mar 09, 2009 | Audio Players & Recorders
Doesn't turn on correctly
you should reset it immediatly. you should see in an instruction maual how to do so.
Dec 27, 2008 | RCA Lyra RD2850 20 GB MP3 Player
JVC KW-AVX815 Player USB Source does not recognize 2.5'' HD
i got my portable drive to work by partitioning to 127gig fat 32 only the old fat32 not the vista version it wont read above that or recognize files if you make it larger
Nov 19, 2008 | JVC KW-AVX810 Car DVD Player
Load main image filed switch to recovery mode
you need to update the firmware on it..i had the same problem but then it started working again once i added the firmware to it
Apr 16, 2008 | SanDisk Sansa e260 MP3 Player
Downloading music onto a mp3player
I think I fugured it out. I think this should set the thing up for you. Turn the unit on. Push the button in and hold for the count of three. Wait as you count to two then push the buton in quickly. The screen should display a different "MUSIC" sign. Now the tiny file type in the upper left of the screen should say "mp3". Now make sure you are loading mp3 files. Be sure the unit is ON when you connect it to the USB port. Drag and drop files onto the mp3 player. I got it to accept 5 songs so far. I am working with Windows xp. Hope it helped!
Dec 25, 2007 | Nextar MA933A MP3 Player
The problem is...
DId u figure out how to solve it ?
Nov 07, 2007 | RCA Lyra RD2854 40 GB MP3 Player
Failed to load system files...How can I reset?
To reset you need to have MP3 switched on, THEN hold the off switch for 10 seconds.If this fails to reset.You may have some corrupted music files sitting on the harddrive.email strongjonn@aol.com if you still have problems as i had the same issue and found a workaround.
Apr 22, 2007 | Thomson Lyra PDP2842U MP3 Player
Failed to Load Files
I was able to access the play list using Windows Media Player. I was trying to get the computer to recognize the player, and it wouldn't do it. I even downloaded the Lyra Personal Audio Player updater... that didn't work or recognize the player.
Try the programs that are on your computer for playing MP3's.
Jun 12, 2006 | RCA Lyra RD2854 40 GB MP3 Player
Thomson Lyra PDP2842U MP3 Player Logo
82 people viewed this question
Top Thomson Audio Players & Recorders Experts
Damen Wong
Damen Wong
Jerry Greenberg
Jerry Greenberg
Marvin
Marvin
Are you a Thomson Audio Player and Recorder Expert? Answer questions, earn points and help others
