Question about HP Pavilion F1703 17" LCD Monitor
Hp pavilion F1703 17" LCD Monitor
When I boot up my monitor will come on then it will go black. If i turn the monitor on it will only stay on for i second. HELP
  • 2 more comments
  • Greaves Nov 15, 2007
    Monitor flashes on/off/on/off in the brief second it is on in the centre of the screen you canmake out the word adjusting.But it never seems to come on and stay on.Any Ideas?
  • HairyJ Dec 24, 2007
    monitor stays on for about 10 secs and then goes black. Power on button/light remains blue. if i switch it off and on again, the same thing happens 10-15 secs later. very frustrating. any ideas?
  • mathisman Mar 29, 2008
    when i turn on my computer it comes on for a second then goes black then i turn off then back on it stay's on then goes black again.
  • reymily553 Aug 06, 2008
    I have a similar problem ,with the exception that now is completely black or dead, does anyone have a copy of Service Manual for HP 1703 monitor that would include schematics and troubleshooting, if anybody has the more complete version of service manual like for Lite-On U170ATA , you can send me a copy to www.reymily@bellsouth.net Any help would be appreciate it very much , regards Reinaldo ( Ray )
    Problem Solver:
  • 3 Answers
Sounds like cold soider joints on your video board. If you take apart the lcd screen and get to the video board, theres 4 capasitors with cooper coils around it. you can add soider to it. theres 2 pins for each. I fixed 15 or more for that same model. Its a known problem with that model. Hope it wworks for ya
Posted on Jul 28, 2007
IF THE MONITOR BECOMES GRAY AND AFTER 3 SECONDS DARK ITS BECAUSE A SAFETY SYSTEM SHOOT IT DOWN. PROBLABLY ITS A PROBLEM ON YOUR INVERTER, USUALLY SOME WIRE OR WELD IS BROKEN.
Posted on Dec 17, 2007
    Problem Solver:
  • 10 Answers
Try turning down the brightness. Try 50% and see if it will stay on longer before turning off. This may make the screen usable in the short term. By turning down the brightness you are reducing the amount of current the screen uses and placing less stress on it.
Posted on Jul 21, 2007
    President:
  • 3,130 Answers
Sounds like the backlight voltage regulator problem but harf to say without inspection. Try this # 800-474-6836
Posted on May 07, 2006
Hp entertaiment pc problem display STAYS BLACK BUT ALL LIGHTS COME ON
If the Video Controller fails, the screen will stay black when the rest of the computer runs as it should. To test this, look to the side of the computer and locate the external Monitor attachment. It is a nine pin male outlet. Take a regular computer monitor and attach it to the connection and turn on the computer. If the Monitor acts like your normal LCD screen, then the main LCD screen is bad. If Neither the Monitor or LCD works, then the Video portion of the computer may be defective.
Apr 15, 2014 | HP Pavilion Entertainment tx2500 Tablet...
Using a HP L1506 Monitor on a HP Pavilions a 867c computer and has worked, but now receiving "VGA input: no input signal" with window on monitor, followed by "Monitor going to Sleep" and it does. Worked...
First of all, boot your system without the monitor connected to it and when you feel that it's booted upto logon screen (or if you haven't assign password it'll directly logon to the desktop, power on the speaker to make sure you can know it's done) connect the monitor. If this isn't successful, please turn off the system and remove the cmos battery, leave it outside for few minutes and again reinstall it. Boot again normally. Still having the same problem? then let's try another method. Did you see the bios loading (black screen with white text during startup) when you power on the system? If so, press F8 several times while it is booting and select "Safe Mode" and restore your system to previous state. Do let me know if this isn't possible. Good luck Thanks for using FixYa.
Jun 10, 2010 | HP Pavilion F1703 17" LCD Monitor
My HP vs19e Monitor went black, when I turn it off...
guest, If monitor vs19e acts same when connected to different "known good" pc then try this site for info: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ How old is this model? When was last time it worked correctly? 12fixlouie
May 19, 2010 | HP Pavilion F1903 19" Flat Panel LCD...
Hp pavilion f1703 lcd monitor
problem with your ccfl lamps or inverter, consult your nearest LCD repair center..
May 09, 2010 | HP Pavilion F1703 17" LCD Monitor
Hp dv1000 - lcd is black(you can see image with flashlight & external monitor works) I've checked all conections & replaced the inverter. what's weird is hat every once in a while the lcd comes on...
back light on the LCD is not working,
LCD needs to be replaced...
The Price at hp is around $398+taxes,which will give you 90 days hardware warranty..
Oct 11, 2009 | HP Pavilion dv1000 Notebook
Dropped and screen went black.still turns on but the screen doesn't work
Attach and external monitor and boot the machine. If you don't have one, ask around your friends and family... someone has a monitor.
If you can see stuff on the monitor when it boots, but when you boot with no monotor the laptop screen is blank, then you most likely have a dead lcd panel on the notebook. It would need to be replaced.
If the external monitor also shows nothing during boot then you likely have larger problems.
Aug 09, 2009 | HP Pavilion dv9000z Notebook
Monitor and LCD detection problem on HP DV6000
I HAD SIMLAR PROBLEM WITH ANOTHER MODEL TURNED OUT TO BE THE LID SWITCH WAS STICKING HOPE THIS WILL HELP
Dec 07, 2008 | HP Pavilion dv6000z Notebook
Monitor going black
My HP f1703 is almost 3 years old and started having this same problem. My fix got the display to stay on. Don't know how long this fix will work. I set the monitor brightness to 51 and contrast to 41. You may have to adjust to your levels to your appropriate enviroment. Levels may determine how long the monitor stay operational. Do NOT set your monitor brightness to factory levels it will just start to recreate the problem again. Solution: The monitor should be on with the blue button lighted. If the screen is acting up (you turn it on and the display lights up and then it turns off within 2 to 5 seconds) Try decreasing the brightness level down as much as possible. Wait 15 to 30 seconds and see if the display comes back to life. If not, turn the monitor off and on again and try the procedure again, if necessary. Cause: I believe the monitor brightness level, set at 100 by the factory setting, is over driving the display and causing the protection circuit to cut off the flouresent lamps that light the display. HP had an issue with this display, and had a notice to replace them if the problem occurred during the warranty period. They extended the warranty period from Jun 04 to Feb 06. Check with HP Technical Support to determine if your monitor is cover.
Oct 10, 2006 | HP Pavilion F1703 17" LCD Monitor
HP Pavilion F1703 17" LCD Monitor Logo
322 people viewed this question
Top HP Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
