Question about Nokia N-Gage QD Console
Memory Card Locked and cannot "Format"?
Please help.
Thanks
It is a SanDisk 8 GB card.
Can you please walk me thru it?
The "locked\' position on the card appears to be in "Unlocked" position.
The 2MB card is working fine with same unlocked position.
Please email to :Albert
Thanks...I am on a friends pc.
The memory Card Is lOCked And Can\'t Be formatted...
Would you tell me to format it..
The password I forget..
Please..
If you don\'t mind, tell me more how to formatted this memory card..
the Memory Card is Kingston tipe 512Mb...
U cn buy a memory crd lock breaker.this will cost around 50 rs.
Posted on Sep 12, 2008
I have a Canon PowerShot A540 Digital Camera I got a new memory card it is a sandisk SDHC 8 GB but I am getting a memory card error message.... What can I do?
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common cause is having the tiny slide switch on the side of the card in the wrong position. The second most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Please note that your particular model camera can only use up to 2GB standard SD cards. These are relatively inexpensive these days, and may be purchased on Amazon if your local store no longer carries them. There are also other common causes if the above didn't help, with troubleshooting steps for this problemlisted here.
Oct 01, 2011 | Canon PowerShot A540 Digital Camera
Andiyi had a memory card of sandisk 8 GB in which the windows was unable to format?
never don't use windows utility for flash drive formatting. use only manufacture's format utility. http://kb.sandisk.com/
Aug 17, 2011 | SanDisk 4GB microSD High Capacity Memory...
My 2 gb Micro sd card can not format and 0 byts memory card
dont worry ............please connect your card with pc and press right key then select property after its please disable read only property and format .............then your card will be format..........
Jul 10, 2011 | SanDisk 2GB microSD Memory Card
I cannot reformat my 2gb Sandisk thru my laptop and thru my LG KS360 phone because it is right protected and i forgot my password. Thanks
your adaptor lock button slide is slipping to locked appy small peice of tape and should be good
if it helps please thumbs up
May 08, 2011 | SanDisk 2GB microSD Memory Card
Hi, I am not able to open my sandisk 2 gb memory card though my pc is detecting it and asking me for format but also it is not formatting
I think the card is locked, look at the card closely either on the front or the back of it there will be a small black square that can be moved either up or down or left or right. Slide that square over to unlock the disk and you should be able to use it now.
I hope this helps you out and if it does please leave me some positive feedback.
Apr 04, 2011 | SanDisk 2GB microSD Memory Card
I have a 4.0 GB SanDisk. When I insert into my camera it give me an error "Memory Card Error" then says the card is locked. I have checked the slide button on the card and it is in the unlock position and...
Yes it sounds like the disk is defective and I have seen these bad so its definitely the most likely possibility. Sounds like the switch itself to unlock it is bad. Good luck and thanks for using fixya, please take a moment to rate my solution I hope you fin it fixya appropriate.
Thanks,
Lee
Dec 07, 2008 | SanDisk 2GB Secure Digital Memory Card
Unlock 1 GB micro sd memory card of Kingston Made
hi this is Aravind , i'm having 1 GB micro sd memory card for my mobile nokia 6233 ..... and it is password protected ... bit actually i have forgotton the password and now i'm using another phone ... in other phone the memory card is not openinng its asking for password .... i have tried also by connecting the data cable but in nokia pc suite its showing that there is no memory card ...., i had also tried thru card reader's but its not opening ./... is there any solution to unlock this card without losing the data in memory card ... plz help me out ........
i have microsd card 1gb card of kingston. it is locked & i want to unlock my memory card without losing my data. so pls send me tips for unlock the meemory card
i forgot my password...pls help me unlocked it without losing my files n data... i forgot the password of my micro sd memory card 1 gb , i don't bother about data, how to open , pl explain.
Jul 19, 2008 | Nokia N95 Cellular Phone
Nokia N-Gage QD Console Logo
88 people viewed this question
Top Nokia Video Game Consoles & Games Experts
matt
matt
Arizona Information...
Are you a Nokia Video Game Console and Game Expert? Answer questions, earn points and help others
