Question about Pioneer Audio Players & Recorders
Pioneer rt-901 new belt and pinch rollers but drive motors will not move. spin by hand they seem to want to move.
  • dtaylor91 May 11, 2010
    Is the tension on the tape keeping enough pressure on the tension arms to allow the switches inside to "feel" the tape? Check the way you have the tape fed into the machine.
2 Suggested Answers
SOURCE: I have a pioneer RT-909
Hello I had the same issue the take up reel tensions need to be adjusted try this thread tape so that there is no slack hold one of the tension guide reels try the right one first hold it so that it is in the 12 oclock postion this is so that it wont retract to the left which will prevent the motor from stopping or going into the cut off position if it continues to play with you holding it in this position the the tension for the reels need adjusting this can be done by slightly turning the blue adjustment knobs that read PLAY / TU 7 FWD 10 one is for 7 inch reel and the other is for 10 inch reels it's the board at the very top of deck when you take the cover off turn them slightly to the left until problem is gone this is what I did and it worked
Posted on Oct 20, 2008
My Eurika 4D bagless upright will not pick up anything. The belt is not broke but the roller won't spin and there is verry little to no suction. Still makes all the notice but won't roll as easily
You say the belt is not broken and the roller does not spin. Does the motor that spins the belt turn. If the belt does not spin and the little drive motor spins then you will burn the belt out. Try to turn the roller by hand. Could be plugged up with dirt and the roller seized. The little drive motor could be burnt out. Take all hoses and areas out that any dirt could be in. No suction means something is plugged. Even your main suction hose could be plugged.
Mar 15, 2017 | Vacuums
Why will the Pioneer RT 707 not work in playback mode?
No it is the same motor for both functions. Just check does the record/play switch operate or move when you operate the record function? I have a hunch that is the problem it may also be that the switch contacts are dirty or worn.Try to play a recording you made on another machine if it does sound and play on the other machine then the problem can only be this switch. Some more upstairs decks do have separate amplifiers for play and record .Nakamichi. Studer Revox Tandberg Uher and the such comes to mind These are those machines offering "Off tape" recording monitor. Then it will sport three heads and not only two I hope this gives clues where to start looking for problems
Sep 01, 2014 | Audio Players & Recorders
Thumping from motor reebok treadmill
Seem like your front roller bearings are knocking. Remove the drive belt. Turn machine on. Replace roller if noise goes away with drive belt off.
Jan 02, 2014 | Reebok Competitor RT 5.1 SpaceSaver...
Brush roller not spinning. belt, spindle okay. roller taken out and cleaned, no thread. replaced but no dice. ???
Use only BISSELL Style 10 Replacement Belts (#32074) in your BISSELL PowerForce Bagless.
  1. Unplug cleaner from electrical outlet.
  2. With Rotating Floor Brush removed from vacuum cleaner, grasp old Drive Belt and remove from Motor Pulley. Discard old Drive Belt.
  3. Place new Drive Belt over Motor Pulley and stretch other end over Rotating Floor Brush in the space between the bristles.
  4. Place ends of Rotating Floor Brush down into slots on sides as shown.
  5. Turn Rotating Floor Brush by hand several times in the direction of Motor Pulley. If properly installed, Drive Belt will center itself on Rotating Brush.
  6. Reposition Brush Cover and snap back into place. Check to be sure all three latches are secured.
  7. When you turn on the vacuum, do you see the motor that spins the belt spinning at the bottom? If not, it sounds like you may have a burned out motor.
If suggested solutions do not correct the problem, call:
BISSELL Consumer Services 1-800-237-7691
Monday - Friday 8 a.m. - 10 p.m. ET
Saturday 9 a.m. - 8 p.m. ET
Jun 01, 2011 | Bissell 6594 PowerForce Bagless Upright...
I've a Mitsubishi HS-U770 that has not been used for several years. When I tried to use it today, the tape loaded but would not play, rewind, or fast forward (I hear what sounds like gears slipping). The...
Mine did that, and when I opened it I found that a small drive belt (visible from the bottom with the cover removed) had deteriorated into goo. This unit had been in storage a while and the rubber just deteriorated, I guess. The trouble is that now I cant tell what size it is, or what length. I think this belt drives the mechanism that loads the tape in and out, and the rest of the mechanism is triggered by the tape cassette moving into position. Since it cant get loaded properly, the rest of the machine doesnt work right, either.
Jan 17, 2011 | Mitsubishi HS-U770 S-VHS VCR
Belt stops when I get on it
This will require a new front roller. The drive belt is usually fine when this happens. Just the roller and the plastic pulley have seperated.
Good Luck Tim
Dec 17, 2009 | Proform Exercise & Fitness
How to replace vaccum belt on a hoover tempo
Turn the machine upside down. Take the screws out of the bottom plate and remove it. take out the brush roller and old belt. Wrap the new belt around the metal shaft of the motor first and put the roller inside the belt loop and use the roller as leverage to stretch the belt up to the brush housing and slide the roller in place. Give the roller a spin by hand the make sure everything moves freely before you use it. It should spin with out much effort, if it doesn't you probably have the belt pinched, and you need to free it up before putting the bottom plate back one. It will take a little elbow grease, but it will go on.
Hoovers usually list what kind of belt they take on the serial tag.
Good Luck
Nov 22, 2008 | Hoover Vacuums
Tape adjustment
Jazzie: Your pinch rollers are worn. Put in a new set and probably a drive belt while you're at it and you'll be back in business. When the rollers are worn and tapered, the tape just rolls right off. Be sure to get the Pioneer replacements! Part---- RXB-325
Oct 29, 2008 | Audio Players & Recorders
No manual
Take the hood off of the unit, and remove the brush roller and belt. Wrap the new belt around the shaft of the motor and slide the brush roller inside the loop of the belt. Use the brush roller as leverage to stretch the belt out and slide the brush roller back into the roller housing. Once you have it installed correctly, make sure the roller and belt are free, by spinning it by hand. If that belt is pinched it will just burn it up when you turn the unit on.
Good luck
Oct 25, 2008 | Eureka Altima Upright Vacuum Model 2996AVS...
101 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
