Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Hi - the machine works fine except that it leaks into the drip tray and kicks beans out, sometimes onto the floor. I have lots of tools and feel good about taking it apart, but need to know what parts (gaskets, o-rings etc.) if any I should have on hand. Thanks.
    President:
  • 1,952 Answers
Oily coffee residue on the grinder prevent the bean from going down be carefull push coffee down in the grinder with anything except our finger by forcing coffee down will making expresso it should grind if it does remove the coffee cointainer little star screw driver after removing the container inside the grinder where the coffee go down you gonna see a steel piece the coffee goes down the slot remove the old coffee residue on that part clean it good with a tooth brusch or somrthing like that put back without old coffee stuck on the grinder you gonna see the coffee gonna go down in the feeder cheers and if it help you dont forget to rate this cheers
Posted on Sep 12, 2008
How do I remove the drip pan from under the freezer? It's full and leaking onto the floor?
There should be a decorative kick panel underneath that will snap out revealing the drip pan which will then slide forward and out to pour the water off.
Nov 25, 2011 | Whirlpool 25.6 cu. ft. Side-by-Side...
Condensation is forming on the glass door and dripping onto floor boards. How do we stop the condensation. It does say to empty drain tray but we cannot find it and instruction manual does not tell you...
The drain tray is under the fridge often times set back a little bit. Remove the kick plate by pulling from one side then the other side, strait forward till it pops off. The kick plate is a plate as close to the floor as you can get on the front side of the fridge going the entire width of the bottom of the fridge. Now get eye level with the underneath of the fridge. Center your view on the underneath of the fridge. The drain tray is right there. Pull it out, carefully as it is probably full of water, and dump the water out of it. Replace the drain tray and then replace the kick plate. Check the drain pan once a week or so and you should have no more water leaking on your floor. Hope this helps.
Mar 22, 2011 | Refrigerators
Drip tray is overflowing water onto floor.
Hi Mickey, You have a bad water valve. Turn the water off to your unit and turn off the ice maker. Replace your inlet valve.
May 22, 2010 | Whirlpool ED2FHEXN Side by Side...
Hi - a couple things... 1-Coffee is bitter + not creamy (I know it is not the bean b/c it produces nice a smooth creamy coffee in another machine) 2-water leaks into the drip tray (sometimes grind too)
One possibility is that the grinding is too fine and the coffee is running slowly. Turn the coffee grinder udjust so the coffee will be more groase and the coffee will run faster. For a 30 cc coffee need around 20-25 sec.
Jan 02, 2010 | Saeco Vienna SuperAutomatica Coffee...
Roper Dishwasher leaks from float or float switch onto floor
you could be usiong way to mauch soap try filling only one of the soap trays or even try doing one wash without any soap at all
this unit tends to do this if you have to much soap in the unit left over from the last load...
beyond that your machine is proibaly tilted to far forward you can lift it, by lowering the front legs begind the toekick
Oct 25, 2009 | Roper 24 in. RUD4000M Built-in Dishwasher
Empty Drip Tray message
Try to clip off the tray contacts and clean behind them. If they are dirty and wet on the backside the machine will keep asking you for Empty tray. Use a small screwdriver and clip them off from the inside of the tray
Aug 17, 2009 | Franke Saphira Espresso & Coffee Maker
Beans fall from inside into the tray, sometimes onto the floor unable to find problem
the only thing i can see the cooffe bean container there a rubber seal that seal beetween the grinder and container you need to empty the beans remove container 2 screw that hold the container black seal is there let me no pierre
Aug 02, 2009 | Saeco Vienna De Luxe Espresso Machine
Steamvac drips when tilt to pull back
May have a problem with the seal at the bottom of the tank, the valve and seal sometimes go back and need to be replaced(#43513026).
Feb 22, 2008 | Hoover F7431-900 SteamVac Vacuum
Leaking Water shorts out machine
I had the same problem. What may be the problem is the tiny water drip hole that feeds the drip tray is blocked with coffee sludge. Open the machine and remove the dump bucket, drip tray, and the brew group. Behind the brew group is a flat plastic piece which has a small drip hole at the bottom of it. This may be blocked which causes the water that should go into the drip tray to build up and overflow inside the machine running onto the countertop. Clean out the area behind the little drip hole and the hole itself. This should cure it.
Nov 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
94 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
