Question about Maytag Washing Machines
Troubleshooting maytag washer model 412 series 02
Washer is not draning completely
    New Friend:
  • 9 Answers
Needs a trap in line like a sewer trap
Posted on Dec 09, 2014
5 Suggested Answers
jyackle5
  • 8197 Answers
SOURCE: My Maytag Legacy Series washer
You also might want to check the lid switch.
Posted on Mar 15, 2009
jumptrout51
  • 3361 Answers
SOURCE: how do you remove the agitator from a Maytag
Loosen the 1/4 inch hex nut on the side of the agitator about 6 inches up from the bottom.
Then pull up on the agitator.
Posted on Nov 11, 2009
  • 4088 Answers
SOURCE: I have a Kemore 80 series washer model not filling properly
Check the inlet hoses for plugged screens at the faucet ends. The screens are usually replaceable if you can't get them clean in a white vinegar/hot water solution. Check the inlet ports to the washer for similar screens. Hope this helps!
Posted on Mar 17, 2010
Jahn27
  • 1554 Answers
SOURCE: MAYTAG FRONT LOADER WASHER WILL NOT COMPLETE A
The fault code indicates a draining problem and the display can be cleared by pressing the Pause/Cancel button twice. Either the pump filter is blocked, the drain hose is clogged/kinked, the pressure switch is stuck in the full position, or the pump itself is not working.
Disconnect power and
remove the three screws attaching the lower front access panel to the cabinet then pull the panel down and off the cabinet. You can prop up the bottom front edge of the washer or cushion and lean it against the wall to access and remove the screws more easily.
Once the panel is off, remove the filter by turning the knob counterclockwise. Clean the filter from any debris that prevents water from draining out properly. Let us know if the problem persists and you need further advice.
Posted on Jan 14, 2011
Maytag washer overflows
Remove and clean the water level tube that connects to the tub at one end and to the water level switch at the other end. Probably it is full of gunk.
May 28, 2017 | Maytag Washing Machines
A407 maytag washer getting grease on clothes occassionaly what would the replacement part
Maytag washing machine gets grease on clothes ... - Fixya
www.fixya.com/.../t14582529-maytag_washing_machine_gets_grease
Oct 8, 2012 - Maytag washing machine gets grease on clothes occasionally. ... some of their clothes ruined by grease stains from their front loader Kenmore. .... remove the agitator from a Maytag washing machine Model A407 series 02?
Aug 24, 2015 | Maytag Washing Machines
Wont pump out comes up with E3 on display
CLOGGED WATER PUMP HINDERING DRAIN AND SPIN CYCLE
Jun 11, 2015 | Washing Machines
I own a Maytag Neptune top loading washer w/ LCD screen. the washer will not power on or make any noise, its almost as if there is no power going to it. we unplugged it for 20 min and plugged it back in,...
Verify the outlet has power by plugging in a table lamp. If your lanp works, you have 120vac. Next, I would look around the unit to see if there might be a fuse somewhere in the line of power. Not being familiar with this particular washer, but having an idea about LCD controlled machines, I'm pretty certain the manufacturer would want to fuse the incoming power so as not to wipe out the LCD with a power spike.
Mar 04, 2010 | Maytag Neptune FAV6800AW Top Load Washer
NEED TO REPLACE BELT ON MODEL lde 412 series 02 serial no. 618 889 PX
its a maytag,
LDE 412 series 02, the labelling printing machine at Maytag is notoriously crappy
Unplug dryer
Remove two screws at bottom edge of front panel, under the lip facing up so they are hard to see.
  • May be TORX secure screws(star shap with a pin in the middle), TORX secure bits ~$6 at good tool shops, or cut a slot across the head of the screw and use a flat blade, throw the torx away and replace with phillips head screws, easier for next time
tilt front panel up from the bottom and unhook it from the catches
undo door switch cables
place door aside
lift drum out
motor, belt, bearings, felts, are all easily accessible.
check felts and roller bearings before you put the case back on, often a seized bearing is cause of belts breaking
While you have the case off pull all the lint n **** out of vent and motor area
Aug 25, 2008 | Dryers
Washing Machines Logo
236 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
