Question about Ricoh FT5832 Copier
Ricoh ft 4522
Dear Sir This Machine is ghoasting real bad the machine as a count 184103.00 the Drum seems to be in good shape, maybe is old developer
or the scanner is burning out, thanks for your support Gordon Abbott
gabbottcw@aim.com
Probably just dirty optics, and/or a dirty PCR.
Clean all, and then set manual exposure with SP4-001, and then calibrate auto exposure with SP3-105 , and 4-201
Posted on Nov 27, 2011
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Ricoh Master
  • 1,362 Answers
Check the fuser first, it should be clean and shiny otherwise it's coming from drum area
Posted on Sep 12, 2008
Error code F 26-3 on Konica 7022
Sir/mam, you might have a bad drum density sensor or it was not cleaned or was destroyed by static electricity, if a vacuum cleaner was use to remove the old developer, NEVER use a vacuum cleaner for that procedure. Remove the drum and will see a small sensor near where the cleaning blade sits need to clean it replace it. Worse case the main control board is bad that what sensor talks to .Was the L Detect procedure run after the developer was replaced, and before you replaced the developer did you clear the developer counter, to let machine know it has new developer, because clearing the counter is the only way the copier has new developer, did you clear the counter for the new drum? The machine use the counters to determine voltages for certain assemblies. If L detect was not run and copies or prints where made get new developer and start over.
Jul 12, 2014 | Konica Minolta 7020 7022 7025 Copier Drum...
Displays c-1 on front panel and front switch is good. Rocoh FT 4522
Hello sir; On the front door there have a door actuactor may be it broken. or door switch loose.
May 18, 2009 | Ricoh Office Equipment & Supplies
Dear sir i have problem in ricoh 2045 its give the sc 990 after making copy may be software problem but i have not software for this machine how i can repair this machine with out change or update software...
Although SC990 relates to a software issue, it is most often actually caused by an aging drum - These machines can be strange that way. I would start by replacing the drum, and recalibrating it - Make sure to also replace the PCR.
Please let me know if it works :)
Apr 09, 2009 | Ricoh Aficio 450 Copier
Streaky copies
It probably has several issues - optics dirty, and drum, and blade failing. I would also imagine that even the Solid "blacks" aren't as black as they could be, and that would be the developer. This machine is in the 17 year old range, and I wouldn't spend dime on it
Mar 29, 2009 | Ricoh Office Equipment & Supplies
Ricoh FT7650 Printing LIghtly - Developer Problem?
It isn't a broken corona wire. If that was the case, it wouldn't copy at all and you would have a few error codes as well along with a few sparks.
Dec 22, 2008 | Ricoh Aficio 450 Copier
Ricohh 450. Error code E544 or E-5 comes up. What can I do to fix
This is a fuser error code. Sometimes it is caused by a mis-reading. Use the procedure below to reset this machine.
Press the yellow "clear modes" key then pres 1, 0, 7, then press AND HOLD the red "clear stop" key until the screen changes. After the screen changes, turn the machine off at the red switch on the front of the machine. Turn it back on.
If the code comes back you will have to call a service tech to troubleshoot and replace parts.
Nov 25, 2008 | Ricoh Aficio 450 Copier
RICOH COPYING MACHINE MODEL 3713
Your copier may need developer if the cycle count is over 150,000 copies. Once that is added to the toner the Toner/Developer sensor should be calibrated and should work fine.
Sometimes the drum can create light copies if it was exposed to light from being out of the machine or leaving the door open too long on the side of the machine letting light in.
Aug 24, 2008 | Ricoh Office Equipment & Supplies
Brother Intellifax 2920 / How to reset Drum Life ?
1.Open the front cover.
2.Press the options key on the control panel. The display will show
#REPLACE DRUM - 1.YES 2.NO#.
3.Press 1 to reset the drum count.
4.Close the front cover.
Aug 18, 2008 | Brother FAX-2920 Plain Paper Laser
Developer....
When developer goes bad you use more toner for one thing, but the main sign is a gray background in your copy. The print should be black but appears to be gray. The ricoh 350/450 was always noted to leak toner and developer as it runs. Check your machine and see if you see any small piles of toner, which also has developer in it, in the machine. Ther are small seals made of felt that need to be replaced if you have this problem. These seals rub against the drum sides....Good luck.
Jul 20, 2008 | Ricoh Aficio 450 Copier
Ricoh FT5832 Copier Logo
176 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
