Question about SMC Barricade g SMC2804WBRP-G Wireless Router
Password want set
I can login with the admin password. I want to lock the router down so that only I can access it for internet. When I try to set a password, it doesn't accept it.
How can I lock it down?
Thanks
  • Carl Navarro
    Carl Navarro May 11, 2010
    In my wildest dreams I can't imagine why you would want to do this, but try MAC address filtering.
    You will lock down the network so that only the MAC address of the machines you pick will work and all the others are denied.
    The smc web site doesn't show a box starting with SMC2804 so that's the best I can do.
  • 611 Answers
Go o the wirless opption in the router then cilk on wep or wappsk/wap2psk then give the password and enjoy it
Posted on Dec 13, 2008
What is the default user name and password
Usually found on the case.if not you will need to google make model to get IP address and default login to router settings.you can do this even without internet access from the router you are trying to configure.i.e. Netgear routers are 192.168.0 .1 with default login as admin : admin .sometimes it's with a capital A.
once you are in to configure screen you will see the routers password ther.you may need to re input your ISP settings in order to surf the internet.
Jan 26, 2015 | Computers & Internet
Establishing a password for a linksys router
Most Linksys routers can be accessed using your web browser by typing this into the address bar (Hook your computer into the router using an ethernet (network) cable):
192.168.1.1
Here are a few typical login passwords to try:
User: admin
Password: password
User: admin
Password: admin
User: (leave blank)
Password: admin
User: (leave blank)
Password: password
Once you are logged into the router, you can visit the settings page to change the login password, or the Wireless Security page to change the wifi password.
May 05, 2011 | Computers & Internet
I need to get a password so that others will not be able to use it
Wireless Router
It is usually easiest to run the install wizard, but be sure to be ready to set the items listed below. To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your internet browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit.
Things to set:
Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes.
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is not the security issue.
2. Set a recognizable system ID.
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
Mar 11, 2011 | Encore 802.11G WIRELESS LAN ROUTER...
I cant login to D-link-i have forgotten my password and i have tried 'admin' as username & 'password, admin' for the password and also tried leaving it blank, as well as the pin on the bottom of the...
The default D-link router login is admin with no password. With that said, you probably cannot login to your router because D-link requires you to change this default login the very first time you login to set it up. If you have a router you setup a long time ago and have forgotten its password and settings, you will likely have to reset D-link router password.
If you look at the back of your D-link router, you will see a pin-hole. Inside that hole is a button that resets the router. To perform the reset, insert the end of a paperclip in the hole and depress the button for about ten seconds. Leave the router on during this time. It will reboot by itself and the WAN light will begin flashing on the front.
When it stops, the router is reset and you can login to it using your web browser. Just type http://192.168.0.1 and click enter. You should see the D-link login window. Type admin without a password and you will be presented with the default d-link settings again. Configure a new password and wireless settings and your router will now be accessible again
Jan 27, 2011 | D-Link Xtreme N DIR-655 Wireless Router
How to set up a password on ASUS RT-G32 wireless router so others cannot access my internet services.
Open a browser. Type in the router IP 192.168.1.1. Login to the router using your user id and password. If you have never set up a user id or password, then use the factory default ones to access. Once into the router settings, change the admin password to avoid anyone later accessing the router and changing your settings. Once you save the admin password change, you will be kicked out and must login again with the new password. Once in, go to wireless settings. Here you will able to set a wireless password (security key) for your wireless LAN. Once you save and exit, you will need to go to all your wireless devices and modify them with the security key in order for them to access the network. Once the key is in the router, your network is secure from outsiders getting in without knowing the key.
Aug 23, 2010 | ASUS Computers & Internet
I can't access my routers administration page. It tells me to type in http://192.168.0.1 and all I get is a bunch of search results instead of the administration page
disconnect your modem from router, or turn off your modem from router...
Now try to open...
because the router admin page will be built inside the router itself... so you never require internet connection to be ON for opening the router admin page...
Aug 02, 2010 | Computers & Internet
I dont know my wep key
*For you to know your wep key you need to access your netgear router
*Open any web browser, such as Internet Explorer, Opera, Google Chrome or Mozilla Firefox. In the address bar, enter 192.168.0.1 and press the enter key. This will bring up the login prompt for most Netgear wireless routers. If that doesn't work, try 192.168.0.5, or 10.1.10.1 until the login window appears.
*Enter the username "admin" (again, without the quotes), and the password "password" in the appropriate fields, then click OK to login. If that password fails, try 1234, Password (with a capital "P"), or admin until you are greeted with the settings screen.
*Go to wireless setting then you can personalize your wep key :)
Jul 25, 2010 | NetGear DG834G Router
Cannot login and have reset....
use the console cable . By using this u can able to go inside the router and after going inside just give the respective IP and after giving the ip to the router u can access the router by using Internet Explorer .
Jun 02, 2009 | NetGear DG834G Router
Router locked. Cant remember the password.. User "root"
The only solution for u to login in to the router is to reset the router.
1.If you forgot your password, you must reset your router. Unfortunately this process will change all your settings back to the factory defaults.
2.To reset the router, locate the reset button (hole) on the rear panel of the unit. With the router powered on, use a paperclip to hold the button down for 10 seconds. Release the button and the router will go through its reboot process.
3.Wait about 30 seconds to access the router.
4The default IP address is 192.168.1.1. When logging in, type in the default User Name “admin,” and the
default Password “admin” then click on the OK button to access the web-based manager.
Regards,
Ayyasam
May 29, 2009 | Buffalo Technology WHR-G54S Wireless...
Having trouble accessing router with ipod touch and nintindo dsi
In order to Unlock Netgear router you need to know the login password for router's login page and if that does not work, you can try with a default username : admin, Password : admin, still if you are unable to access the routers page then you need to reset the router by inserting a pin in the pinhole where it says reset at the back of the router...press and hold down the pin for 30 seconds and then restart the router, this will take the router back to default settings and then apply username : admin and password : admin....it should work
Netgear address : 192.168.0.1 ( Type in IE address bar to access it )
Regards,
Anup
Apr 06, 2009 | NetGear WGR614 Wireless Router
SMC Barricade g SMC2804WBRP-G Wireless Router Logo
221 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
