Question about Lite On (LTN486S) Internal 48x CD-ROM Drive
Lite on LTN486S and TOSHIBA ODD-DVD SD-R5272
I can not use my cd player or dvd player I've tried to remove and reinstall drivers but keep getting errors
  • 1 more comment
  • Anonymous Nov 30, 2007
    computer does not reconize cd drive
  • a1b2c3d4 Dec 02, 2007
    Cannot use CD or DVD
  • doniy Feb 27, 2008
    my cd-rom aren't work properly, it's can't read a cd. it's not responding
Check junpers at back of unit. Try cable select CS
Posted on Nov 21, 2007
  • 624 Answers
Specifically what do the error messages say and when do they appear.
Posted on Mar 26, 2007
    Problem Solver:
  • 10 Answers
DId you check the wires? Also your computer may not be compatible with the player.
SOURCE:
Toshiba sd-r2312 driver corrupted . how can i update it ?
There is no such thing as a specific driver for cd/dvd readers/burners.
The operating system itself has suitable drivers for those devices.
However, it can be that the driver for the IDE/ATAPI-controllers is malfunctioning.
If you have chipset drivers for the mainboard, reinstall them. Otherwise remove in
the Device Manager the driver of the used IDE/ATAPI-controller and let the Device
Manager search for the Microsoft Windows drivers and install them.
Jun 12, 2011 | Toshiba SD R2312 CD-RW/DVD-ROM (Combo)...
Can lite-on-ltn4865 48x play dvd movies
If your Drive is a CD-Rome drive, surely it cant, for the drive cant read dvd disc. Replace the drive of yours with DVD-Rom or DVD-RW in order to play dvd disc, DVD-RW simply has the added capablity to burn on DVD discs
Jan 12, 2011 | Lite On (LTN486S) Internal 48x CD-ROM...
Itunes knocks out DVD/CD driver whenever I update Itunes.
Solution 1
Check with your manufacturer to see if there are updated software drivers for your optical drive. For more information about updating the firmware of your CD or DVD drive,
Solution 2
Launch Windows Explorer.
Navigate to C:\Windows\system32\drivers\.
Check to see if either of the following 2 files are present. These files from a third-party software vendor are not supported by Windows Vista and can cause driver conflicts with optical drives:
afs.sys
afs2k.sys
If either of the files in Step 3 are present, move them out of the system32 folder. You should keep these files stored somewhere on your hard drive, as some of your older peripherals may require them. If you find that they are required in the future to use a device, you may move them back into the system32 folder temporarily.
Reboot Windows Vista.
Solution 3
Quit iTunes.
Manually remove the GEAR driver software using the steps found here.
Remove any stand alone GEAR software installers from the Programs and Features control panel, if present.
Install the updated GEAR driver.
Mar 06, 2010 | Toshiba SD-R5272 DVD±RW Burner
I have a toshiba ODD-DVD SD-R5272 that runs in win 2000 But the windows drivers it uses say its only a CD rom I have done the firmware update ...With no help What else can I do ?
Make sure you have the proper driver installed and that it is working.
Go to PCPITSTOP and have them scan your machine. It is a free service.
I hope this helps you
a
Sep 21, 2009 | Toshiba SD-R5272 DVD±RW Burner
Lite-On LTN486S issues
If you recently uninstalled or removed Easy CD Creator or DirectCD or some other CD-writing software, you might want to check out this article from microsoft http://support.microsoft.com/kb/270008/
Dec 05, 2007 | Lite On (LTN486S) Internal 48x CD-ROM...
Toshiba odd dvd sd ,wont rewrite dvds
Are you sure your drive is a dvd writer? And if it is a writer, is it a dvd -r or a dvd +r or a dvd -r/+r? Depending on the way the dvd writes to the disk, you will need to buy specific media for the writer to write to. DVD -R cannot write to DVD +R and vice versa, and even if the drive is a DVD -R/+R, they seldom write to both media with any degree of regularity or of good quality. Most dual dvd writers seem to prefer DVD -R.
Oh yeah, one other thing, if your dvd is a writer, you should check out the drive properties in my computer to verify it is set to record. If you see the recording tab, select it and verify that the box is checked to enable cd recording on this device.
Nov 27, 2007 | Lite On (LTN486S) Internal 48x CD-ROM...
Dvd - cd rom wont work
Dear friend, In your system cdrom drivers currupted for that drivers you need to install a mscdx file in drive "c" then it works fine.
Dec 14, 2006 | LG CRN 8245B (CRN-8245B) Internal 24x...
Toshiba ODD-DVD SD-R5272 not compatible with iTunes
go to My computer right click on cd drive properties - check digital cd playback recording - check enable cd recording on this drive driver - update or uninstall reboot your computer Good luck!
Dec 10, 2006 | Toshiba SD-R5272 DVD±RW Burner
Open Questions:
See all Lite On (LTN486S) Internal 48x CD-ROM Drive Questions
Lite On (LTN486S) Internal 48x CD-ROM Drive Logo
817 people viewed this question
Top Lite On Computers & Internet Experts
Pierre Laplante
Damen Wong
Damen Wong
paul shaw
Level 1 Expert
Are you a Lite On Computer and Internet Expert? Answer questions, earn points and help others
