Question about Fisher and Paykel DEGX1 Electric Dryer
Dryer takes too long to heat
Model DEGX1 electric dryer
Dryer is taking too long to dry. The dryer heats but only 1 of the elements seems to be turning on.
In this model, there is a control module with two relays. Upon removing the cover, I found a red power wire melted and disconnected, with the plastic plug fused to the metal connector at the relay. A yellow wire is also attached to this relay but with no visible damage to it. I replaced the red wire and connector, hooked to the relay and tried the dryer.
I can see the elements through a space in the aluminum shielding but it seems that only some of the elements actually heat up. I've checked voltages on the wires (red and yellow) and I get 120 on each. The dryer will dry the clothes as some of the coils heat up and turn orange.
Here are my questions:
Do you think the relay is bad? I'm not sure but I can hear some relay switch on and off (click) and the elements that do turn orange will stop. Later they come on again, after another click. Everything else seems to work fine on the dryer at this point -- other than slow drying.
Would current flow through a damaged heating element without heating it? I check the current at both sides of the element and both sides read 120. I have two sets of wires to check, violet and yellow. Also, there are three sensors on the heating unit, two small ones wired in what looks to be a sequence; and a slightly larger one with the reset button. I'm guessing these are the temperature sensor and/or the overheat safety switches.
I guess I need to know if I should use the dryer or if I should replace the control module and/or heating element. I am capable enough to replace the parts myself, I just want to know what I should replace.
  • Anonymous Mar 26, 2014
    Wasn't heating. Yellow wire from heating element had melted. What could cause melting?
  • 5,911 Answers
Okay...I'm not familiar with the configuration of Fisher and Paykel dryers. I am familiar with many other dryers, though. If the wires become melted this is usually caused by excessive current flow or a loose connection. When wires at a terminal become loose the intermittent connection can cause arcing which leads to the generation of heat, which causes the wire or connector to burn open. I have also seen heating elements short out against the casing and cause an excessive current flow problem.
Just so we're clear here, current is the force that causes electrons to flow. It is usually measured in amperes (or amps). What you are measuring is the voltage. Voltage is the difference in potential between two points. If you were to measure voltage between two points (such as through a simple wire coil) you would read 0 volts because there is no differnce in potential between the two points, as the coil should read a short. Now, if you have a RESISTIVE coil, or a coil that is open (broken) the same measure would yield a voltage reading, because there is now a difference in potential between the two points. Does this make sense to you? I know it can be confusing at times because you normally associate a voltage reading as something being good. In a nutshell: if you measure across a wire coil and read voltage - the coil is open. If you read 0 volts - the coil is good.
Who knows what caused the melted wire in your appliance. The one thing I am sure of is this is not normal. If you want to replace the relay to be sure, that is your judgement call. Relays do go bad. I would strongly recommend replacing the heating element as it appears that this model has a dual element that will still work (to some degree) if one side fails. Very ingenious design, by the way.
In addition, a lot of heat related problems associated with dryers are attributed to poor ventilation. A dryer requires proper air flow in order to work efficiently. If you have not cleaned or inspected your dryer vent ducting recently (or ever), you may want to. This is the source of many dryer malfunctions and can create a fire hazard or habitat for rodents. The rule of thumb when it comes to ventialtion is: The SHORTER and STRAIGHTER the ventilation, the BETTER. Every bend or rise you put in a dryer exhaust vent line creates resistance against the blower motor and possible choke points for lint to accumulate. The lint screens in dryers are not perfect and they do not collect ALL the lint. Simply cleaning the lint trap in many cases is not enough. Cleaning after every use, however, does cut down on the potential for your ducting to become clogged. If a dryer is allowed to run in a condition where it has poor air flow, the heating circuits will actually overheat to the point of failure. I mention all of this because I don't want you to replace parts only to have the appliance fail again due to poor ventilation.
I hope you find some of this information helpful. Let em know if you have any further questions.
Posted on Sep 12, 2008
I have a fisher & Paykel electric dryer. D-DE62T27D that works but won't dry. Any solutions? Thanks Rick
Disconnect the power source to your dryer before you conduct this or any other test. Either unplug the unit from the wall outlet, remove the appropriate fuse from the fuse box, or flip the appropriate breaker in the circuit breaker panel.
Dryer heating elements come in various shapes and sizes. They are all strung with a coiled wire made of a nickel and a chrome alloy. This wire receives, but resists, a controlled electric current and as a result, the wire heats up. The heat produced is used to heat and dry the clothes in your dryer.
Once you have gained access to your dryer's heating element, set your multimeter to the R x 1 resistance scale. Touch each meter probe and to one end of the element. If you receive a reading of infinite resistance, then your heating element is no longer functioning properly and you will have to replace it.
Jul 12, 2011 | Fisher and Paykel DEGX1 Electric Dryer
The dryer turns on seems to work fine except it doesn't heat. Takes at least 2 hrs to dry a load.
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101';';
Jun 29, 2011 | Fisher and Paykel DEGX1 Electric Dryer
The dryer is not drying the clothes
there is only 1 reason as to the unit still running but not heating if its running then all thermos must be intact so it has to be the heating coil take the unit appart make sure the two heating points still have the cables attached if you can do a polarity test on the element that will define its blown then replace the coil in most cases when the coil blows you can see a burn mark were it did
best luck
Dec 02, 2010 | Fisher and Paykel DEGX1 Electric Dryer
My ge wont dry clothes it takes 2 hours
Check the exhaust duct. It's best to have a short run and no obstructions. It's also possible that a heating element could have been damaged in the move.
Dec 31, 2008 | Fisher and Paykel DEGX1 Electric Dryer
WHERE TO BY DUAL HEATING ELEMENT FOR DEGX1?
try sears .com..use parts link type in model #
Sep 07, 2008 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Stays Warm
Yes, get a new element. The reason it's on all the time is because the element coils have broken and one of the coils is touching the canister that encloses it. This creates a direct short to ground. By the way, the element has 120 volts to it all the time. It will only HEAT when 240 is applied through the centrifugal switch of the motor. Your 120 volts is shorting to ground... not enough amps to trip the circuit breaker, but enough to glow the element.
Aug 23, 2007 | Fisher and Paykel DEGX1 Electric Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
170 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
