Question about Acer TravelMate 2300 Notebook
Bios password for acer travelmate 2410
When laptop is turned on it goes to bios password can not enter computer at all,was purchased second hand,have upgraded hard drive,computer tech. wanted $200 to put in new cmos chip,please help me
  • Anonymous Mar 26, 2014
    I have a panasonic CF-51 which have a bios password on the bios chip coz the cmos is already remove we've already flash some chips but the main bios chip don't want to flash what can I do plz help
I have had just the same problem, i took my laptop apart removed the cmos battery its just to the side of the trackpack on top of the motherboard, but this did not work, HERE is the solution with out stripping the all the laptop make sure the battery is out and no power to the laptop all you need to do is take the plastic part with the power button on off and underneath you will see a small switch called SW1 move the number one switch to on then power up the laptop press F2 and there you go your in the bios, save all settings turn off put the switch back to where it was put you plastic facia back on replace the battery power up now press F2 and do what you want all is good
Posted on Aug 09, 2010
  • 2 more comments
  • computerg446 Nov 27, 2010
    this worked!, travelmate 2410 couldnt get to bios, password protected. got plastic cover off and lo and below a sw1 switch (yah!) change setting to on and restarted f2 and im now in the bios screen!...thanks very much
  • simmo365 Nov 28, 2010
    glad you got it sorted, hope it all works for you now
  • Wilddog_AUS May 24, 2011
    Customers laptop had similar issue, 3 owners on and no clue about password. System needed reloading but no way to boot dvd without BIOS access. This method worked 100%. Was a bit nervous with cover clips near power button but they proved more hardy than I gave them credit for.simmo365 thanks for saving me from endless hours or reading/googling and my customer thanks u also you a legend.
  • wilbert_1991
    wilbert_1991 May 26, 2012
    Sweet mother of god, you're a lifesafer! :D
Dear sir
i have a acer travelmate 2410 and my in this laptop bios password is forgotted, so i am not entering in the bios . so take solution for that
Posted on Mar 18, 2010
    Guru:
  • 558 Answers
Hi Robboman,
Thanks for your email in the forum.
Disable the Bootup Password is quite hectic work and need extra Hardware knowledge, if you have, then you can do it.
You can get some more helpful information by visiting this link:
http://www.tech-faq.com/ibm-thinkpad-bios-password.shtml
http://www.tech-faq.com/reset-bios-password.shtml
Regards
Ellin
Posted on Sep 12, 2008
  • Puneet Jain
    Puneet Jain Oct 17, 2008
    Reply please if the soluton work for you.
    Give your rating to the solution either Helful or Fixya.
    If you dont fix the problem yet by the solution given then I would suggest you more options, let me
    know for it.
    Since your voting is precious to me in providing the help for others.
    Have a Nice day.
    Regards,
    Ellin
    New Friend:
Thank you my friend simmo365!
Posted on May 23, 2016
    New Friend:
MANY THANKS SIMMO365 yoiu are genius
Posted on Jun 09, 2013
    Scholar:
  • 135 Answers
You need to reset the BIOS password. One way is to dismantle the laptop. Once you can see the board, look for a battery that is similar to watch batteries but is much bigger (the circle flat kind). Remove it then put it back again. It will reset the BIOS settings on the computer. The tech guy would be just doing the same thing.
Hope this saves you $200.
Fijustu ah530 corei 5 bios password
BIOS on a Fujitsu C-Series LifeBook b> Resetting the BIOS system of a computer can help revitalize the computer's usage. Oftentimes computers are "broken" when they are misconfigured in the BIOS menu of the computer before it boots up. When the settings are improperly selected, the BIOS prevents the computer from working properly. To get the computer back up and running again, the BIOS needs to be reset. The Fujitsu LifeBook C2111 has its BIOS system located on the motherboard beneath the keyboard.
Turn the Fujitsu laptop over with the computer powered off. Remove the AC adapter and push the battery release latch in and pull the laptop battery out of the Fujitsu. Remove the screw holding the hard drive in place and slide the cover off of the laptop. Remove the two screws underneath the cover that holds the hard drive onto its bracket. Slide the hard drive out of the laptop. Turn the computer back over and lay the screen down so that it is parallel to the surface on which the laptop is resting. Remove the small screw above and to the left of the keyboard with the Phillips screwdriver. Push the keyboard toward the screen until it disengages. Fold the keyboard over the screen and rest it there with the keys facing the screen. You will now see the motherboard of the Fujitsu C2111. Locate the small, round lithium-ion battery on the motherboard and remove it. This is the BIOS battery that stores all of the settings and password of the BIOS when the computer loses power. Hold the power button in on the computer to drain the BIOS system and leave the battery out of the laptop for at least 30 minutes. Place the BIOS battery back into the motherboard and reattach the keyboard. Tighten the keyboard screw that you removed earlier, and turn the Fujitsu back over and reattach the hard drive along with the covers for the hard drive and RAM. Push the computer battery back into place and attach the power cable to the computer. Turn the Fujitsu back on and the BIOS menu will be reset.
or b> Start the computer and press the "F2" key while the system boots, if the computer is currently off. If already on, restart the computer and press the "F2" key while the system boots. The BIOS setup utility will appear. Press the right arrow on the keyboard and scroll over to the "Exit" tab. Press "Enter." A drop-down menu will appear. Scroll down to "Default Settings" using the down arrow key and press "Enter." A dialog box will appear, asking if you are sure you want to load the default settings. Scroll over and select "OK" using the arrow keys and press "Enter." All BIOS settings will reset to the default value. Scroll back to the "Exit" tab using the arrow keys and press "Enter." Scroll down and select "Save Changes and Power Off." Press "Enter." The computer will save the default BIOS settings and power down. Fujitsu Lifebook T Series b> Restart your Fujitsu Lifebook T Series computer. Press "F2" as soon as the computer starts booting. Enter your current BIOS password if prompted. Use your right arrow key to select the "Security" menu. Use your down arrow key to select the password you want to reset. Press "Enter" to select the password. Enter the current password when prompted. Enter your new password or a blank password if you want to clear the password. A blank password resets the BIOS password completely, meaning you do not have to enter a password to enter the BIOS or boot your computer. Press "Enter" to save your password settings.
Repeat the process if you have multiple passwords set. Press "F10" to save all settings and exit the BIOS.
Jan 30, 2013 | Fujitsu LifeBook AH530 NoteBook
Reset motherboard bios
remove the bios battery for arounf 30 minutes to an hour. if you can locte the bios jumper, just turn the PC on the , unplug the jumper then the pc off, put the jumper back and you are good to go on the next reboot.
Aug 10, 2008 | Intel D865GLCLK Motherboard
Hi i have a acer 2410 laptop i havent used it for a while so i went to put it on and enter password comes on when i type in my password it shows invalid password so i knocked it off and put it back on...
If you don't want to open up the laptop and find the BIOS password jumper on the motherboard, you'll need to send it in to the manufacturer (or a good local tech) to get it reset. There is no other way to reset/remove a BIOS password.
Jun 29, 2011 | Acer TravelMate 2300 Notebook
Acer travelmate 2410 model: MS52177 bios password
if you dont have the bios password you will need to take apart the laptop and de-solder the bios battery leave it of for 10 minutes resolder it making sure the polarity is correct and there will be no password when you re-boot it
May 30, 2011 | Acer TravelMate 2300 Notebook
How do i reset the bios password for my lenovo a310?
User passwords:
Power on
BIOS execution can be controlled by a Power On Password. This password is set in the BIOS Configuration screen, accessed by pressing the F1 key after pressing the power on switch to turn on the PC. If the person at the keyboard does not know the Power On Password, then BIOS execution halts.
Hard drive
The hard drive is controlled by the Hard Drive Password. After the Power On Password is entered, the person at the keyboard must be able to enter the Hard Drive Password, otherwise the disk drive will not spin up for use. Like the Power On Password, the Hard Drive Password is set in the BIOS configuration screen.
Administrative passwords:
Each of the two user passwords can be controlled by a Master or administrative password. If the administrative password is not set, then anyone who knows the user password can change it in the BIOS configuration screen. If the administration password is set, then it is impossible to reset the user password unless you know the administrative password. The Supervisor Password is the administrative password for the Power On Password. The Master Hard Drive Password controls the Hard Drive Password.
Password Recovery is a feature of Client Security Solution 6.0. This makes it possible for an end user to recover from the problem of "I forgot my Power On Password or Hard Drive Password."
c.gif fw.gif Client Security Solution
Mar 13, 2011 | Lenovo IdeaCentre A310 Laptop
Can't unlock My Essentials 1TB Hard Drive Asking for password and I don't have it.
to remove the hdd password do the follwing
1) Restart your computer. Note that during computer restart, the screen goes blank for 3 to 5 seconds. Text then appears and the operating system boots up.
2) As soon as the first text lines appear on the screen, press the "Del" key on your keyboard to enter the BIOS setup
3) Navigate to "Security" in the BIOS menu using the arrow keys on your keyboard
4) Navigate to the option "Hard Disk User Password" and press "Enter
5) Navigate to a hard drive, press "Enter" and select "Disable" to remove the hard drive password.
6) Press "F10" to save and exit the BIOS settings. Computer booting resumes.
this will remove the hdd password
Jan 26, 2011 | Western Digital My Book Essential Edition...
I forgot my password to unlocking my WD external hard drive 2 TB? How can I unlock it without loosing all my data saved?
Jan 26, 2011 | Western Digital Elements 2 TB USB 2.0...
I forget my password in u3 what can i do??????
Jan 25, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I forget the hdd password
Jan 15, 2011 | Computers & Internet
Reset bios password acer Travelmate 2410
I know some methods to reset bios password.
1. The best and easiest method: Close OS and shut down the electricity power of computer. Open your computer box, take out the cmos battery from the mainboard. Then the bios password will be reset to blank. Put it back after a few minutes.
2. Follow some tutorials. For example the tutorials:
Reset ACER Aspire 3610 BIOS Password - Only 8 Steps
Top 3 methods to crack bios password!
3. Use the bios password recovery tool , but that is not free!
So I would suggest you the 1st method. Hope it helps.
Jan 09, 2011 | Computers & Internet
Computers & Internet Logo
3,365 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
