Question about Hotpoint 24 in. HDA1000G Built-in Dishwasher
How to fix a panel to a semi-intergrated dishwasher
The panel that matches the dishwasher with the rest of my kitchen units fell off and I lost the fittings. How can I re-fit the panel without them? Thanks.
  • Anonymous Mar 20, 2014
    semi intergrated
  • Anonymous Mar 23, 2014
    hygena semi integrated dishwasher, I can't get the door off the front and need to swap it so it matches the rest of the kitchen, but can't work out how it comes off.
  • 641 Answers
Contact the following address of G.E for their assistance http://www.geappliances.com/service_and_support/contact/ Good luck
Posted on May 05, 2006
Can it be fitted with a stainless steel door panel to match new kitchen?
Jerry,
You would have to look up and see if that particular model was even available in Stainless when it was manufactured. If it was, then you might be able to change it over. You will probably have to change the plastic housing that holds the control panel as well if you are wanting it to blend in with the rest of the kitchen, I assume it is white as well. Hope this helps!
Nov 23, 2015 | Dishwashers
I was told that my Tecnik SE6TIE1GB/17 Dishwasher is a bosch. I have seen the news today that some models have been recalled can you tell me the full E-NR number please
The recall is only for freestanding or semi intergrated d/w. If your control panel is along the top of the door it is not subject to the recall.
Mar 15, 2013 | Tecnik 24 in. TKD795/3 Built-in Dishwasher
How do i change the door panel on an intergrated neff dishwasher
check out www.applianceart.com./ You may not need to change the panel just cover it. They have hundreds of designs and colors and even a stainless steel option
Apr 09, 2010 | Neff 24 in. S5443X2 Built-in Dishwasher
The LED display on my AEG F88070IM is blank but
yes a new display is the most likely solution but check connections from input to lcd display card 1st..
Jan 04, 2010 | AEG 23 in. Favorit 88070IM Built-in...
How do I take the intergrated door of a busted whirlpool ADG 7540
open the door and inside you will see some screws, some of these screws hold the dishwasher door together and some (about 4) hold the integrated kitchen unit door on, trial and error
Apr 05, 2009 | Whirlpool 24 in. ADG7540 Built-in...
Ge pdw7880j10ss dishwasher lower roller fell off and melted on lower heating element. need to know part number of lower roller and plastic clip that affixes the lower roller to lower rack?
(http://www.geappliances.com/service_and_support/parts/)
the correct # for your unit is pdw7880n10ss
just enter your model #(under repair or replacment parts)the site will walk you thru the rest.when you get to the parts list make sure you use the diagram to match your part exactly(click the red box at top of page)hope this helps.thanx for using fix-ya!!!
Nov 29, 2008 | GE 24 in. Profile PDW7800 Built-in...
Fitting a new front panel to the NEFF 54432 integrated dishwasher
My Neff integrated dishwasher has two holding screws in the top corners and then two hidden screms half way down the side behind plastic covers. Loosen these side screws, remove the top two corner screws and then the door cover/panel should lift out of two lugs at the bottom.
Aug 13, 2008 | Neff 24 in. S5443X2 Built-in Dishwasher
Electrolux ESL6114 built in dishwasher door
Although it is a different model than yours, here is the link to the installation manual for an Electrolux DW and it is likely similar. The custom panel instructions begin on page 22 and show templates and how to remove and reinstall the factory door and a custom installation panel: http://www.electroluxicon.com/Files/International_English/0-999/EDW5505ESS_install_en.pdf
Jun 25, 2008 | Electrolux 23 in. ESL6114 Built-in...
How to make a panel, install it and a handle for Kitchen Aid model KUDU03FTPA panel ready dishwasher
Hello babies5 what it means by panel ready is a cabinet door style front to match the cabinets. I have installed many of these panels, however they where always supplied by the cabinet shop who built the cabinets. As to handle, that also always matched the cabinet pulls on the rest of the kitchen. The idea of this unit is to hide the dishwasher. In my kitchen, simple doors, so I would use 3/4 inch plywood and paint it white with the same pulls as my current doors and drawers have.
May 10, 2008 | Dishwashers
Hotpoint 24 in. HDA1000G Built-in Dishwasher Logo
302 people viewed this question
Top Hotpoint Dishwashers Experts
Archie Ferrarini
Archie Ferrarini
Marvin
Marvin
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
