Question about Refrigerators
How do I change the door on my Zanussi Freezone Larder fridge to the other side?
  • Anonymous Mar 31, 2014
    zanussi freezone
  • 1,122 Answers
First you have to see if you have all the same fitting on the other side,top and front,let me know and we can go from ther,mike
Posted on Sep 12, 2008
Zanussi freezone fridge freezer
Try adding freeon made for refrigerator. Can get at any hardware store. Hope this help.
Sep 09, 2013 | Microwave Ovens
Why does the fridge part of my zanussi freezone fridge/freezer, keep freezing the food?
Hi,the problem you are encountering is as a result of the fact that the thermostat which regulates the cooling temperature in the fridge/freezer is bad hence there is no regulation of the cooling temperature in the fridge/freezer section, hence the food in the fridge freezes up.
The solution is to replace the thermostat of the unit,here is how you go about it;
1.You have to disconnect the fridge from the power source.
2.Locate the thermostat at the bottom of the unit,at the top left corner above the condenser.
3.Now you need to locate the wire ends or wire harness and unplug them.
4.Replace the thermostat,reconnect it back,put the back cover back and you have completed the job.
Take care of yourself
Jun 24, 2010 | Hoover HCA390FFK Bottom Freezer...
Possible Air Lock in Zanussi Freezone larder fridge
leaving it switched on should settle the unit down can take a day or two should have fully defrosted the unit and dried out as best you can before that any build up of semi defrosted ice was removed...hope this helps....
Feb 25, 2010 | Refrigerators
well asuming you already thought to turn the thermostat down, i would check to see if you have a freon leak. with the fridge running, paint the coils with soapy water untill you see bubbles. mark that spot and dry off the area around it. generously apply electronics grade solder to the area where the leak is. (be sure you don't melt the copper and unplug the fridge first) then continue untill you have checked the entire length of coil. when all ieaks have been stoped recharge with recomended freon.
Aug 17, 2009 | Refrigerators
How to fit a Zanussi fridge door seal
You mean you have a door gasket. A good, step-by-step article on this pesky concept of "panel-screw" gasket installation is found on this handy page:
This should help!
May 21, 2009 | Refrigerators
Item is secondhand and i was not given the book
You can download the manual from this link, the manual is of a similar model---
Zanussi User manual
Please click on the above link and click on the link that says zanussi manual(150k)
Please ask for further clarifications.
Please rate this solution as fixya if found useful.
Mar 03, 2009 | Refrigerators
Larder section of fridge not functioning
check the drain that is inside of the freezer compartment at the bottom. you may have to disssasemble the covers to get to it. if its clogged the water turns to ice real quick and blocks air to the refrigerator
Dec 29, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
Beco larder fridge - excess of water in drip tray at rear - fridge cold but items in fridge are heavily condensed
you have air leaking into the fridge. check door seal by trapping a slip of paper between seal and cabinet all way round
Sep 17, 2008 | Refrigerators
Refrigerators Logo
123 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
