Question about Video Game Consoles & Games
Picture comes on and off and sometimes i cannot get a piture at all) i have a brand new lcd tv and a new hdmi cable i thought it might be the cable so i tried av and still it did the same thing. also i am not getting a sony logo screen when i turn it on! when it plays it plays fine never had a problem with it before and it has not been over used. very worried please reply soon thanks
    Genius:
  • 1,239 Answers
Hi.. sir..    there may a power card problem of ur LCD DISPLAY ... so that u could not see the sony logo..   if it is in a warrenty period please give.. or   please dissamble it and see the power card till the the power board the supply is comming through the multimeter.. if is comming. and see the thermal fuse is burn or correct..just verify if it is burn.. replace, it..
if any assist i am to solve..  thaku..  dont forget to rate it..
Posted on Sep 12, 2008
    Genius:
  • 1,665 Answers
Try another cable or check for loose or bad connections.
    Genius:
  • 3,422 Answers
Can you please let me know about which gaming console you are facing this problem with?
I will be waiting for your reply.
  • 1 more comment
  • Priya darshan Sep 12, 2008
    You can add a comment here you don't need to keep posting new problems.Just let me know if you are getting sound or not?
    If you are using an HD cable (i.e. VGA, Component, HDMI) then is your tv set to display HD, and with the right video input?
    If you are using SD cables (i.e. compose, s-video) Is your PS3 set to send that SD signal?
    ---- Try turning on your TV, turning on you PS3 and holding the PS3
    power button for 10-15 sec. then it should set to what cable you are
    using.
    and of course make sure your TV is on the right 'channel' or input, so that the siganl from the ps3 will be shown/heard
    using.
    The last thing you can do is hold down the On/Off button on the front
    of the system and then the system will go into standby mode. You will
    see the light will go from red light to green light then back to red
    light.This will ensure that you have held down the On/Off button long
    enough to reset the Video Output Settings.If you still face the problem
    then you will have to get it repaired because your video card is
    blown.If it is under warranty get it replaced or else the repair can
    cost upto $150.
    Goodluck..
Vizio E470VLE HDMI inputs not working
its the antanna don't go on your roof you probs bumped it
Aug 31, 2016 | Vizio E470VL 47 in. HD-Ready LCD TV
Picture in picture operation & connection to dvd player
Now--first--connect the DVR cable box HDMI output to the HDTV HDMI input (use the lowest numbered one e.g. HDMI 1) for this connection. Use a standard (not Monster brand) HDMI cable for this connection. Then turn on the TV, turn on the cable box and switch the TV to the HDMI input. A picture should come on. You may even hear the audio on the TV speakers. If so, that is OK.
Then--connect the component video output of the DVD HT to the TV component 1 input. Use a three wire component video cable with red, blue and green connectors on each end. Connect color to color on both ends. Then turn on the DVD, put a DVD in the player and start it running. Switch the TV to the component input and it should show a pix. The audio will come from the DVD player speakers.
If your DVD player does have an HDMI output, you can use it and just connect as above to the second TV HDMI input.
To get audio from the cable box out of the DVD player speakers, you will need to connect an audio cable from the cable box go the HT amplifier. Use a set of RCA patch cables and go from the analog audio output of the cable box to the rear panel audio inputs of the DVD player. The owners manual for this unit will give directions on using this input. Since your HT unit does not have any other inputs, you will not be able to get Dolby Digital audio.
Hope this gives you food for thought. If so, and you have more questions, just come back in with a follow up.
Good luck. Remember, the owners manuals all have hook up connections diagrams. Sometimes they will help.
Dont forget to rate me as fixya..
Jan 30, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
PS3 HDMI
the tv more than likely the most sensible thing to do would be to check its not your cable by trying someleses that you know works. its sometimes the tv resolution or the playstation because some tv's do that, my laptop would sink and a say out of range but try someleses cable or different tv screen resolutions on picture settings
Jul 25, 2012 | Sony Video Game Consoles & Games
I have the same issue with my new LG 47lv5500. I too have time warner settings of 1080i but the sound on hd channels comes and goes. Picture is fine. When I switch back to non hd channels the sound is also...
That tv HDMI hub output for the HD tv signal are could be a bad HDMI cable should tries it with another new HDMI cable.If still have the same problems tries it with another HDMI tv hub hook up.That tv HDMI tv hub the one u using now might have a intermittent shorting like lose or dries solders joints that why sound come an goes.
Aug 25, 2011 | LG 47 47LV5500 47 LCD TV
Does the Sylvania 22 HDTV require a special cable when connecting to my cable service. I do not have HD cable service.
Not necessarily. You can use the normal connecting cable but you may not get HDTV picture. Better is to connect through HDMI cable where you can view HD pitures on the channels transmitting HD programmes
Jan 06, 2010 | Sylvania LC-225SL9 22 in. LCD TV
My vizio tv has red lines all over the screen sometimes. It goes away but it comes back at times. It is brand new. I have an HDMI cable hooked up for gaming purposes and it just started doing this lately.
IF IT IS NEW, SO IT SHOULD HAVE WARRENTY, TRY TO GET THE DEALER AND TELL HIM ABOUT THIS PROBLEM. SEEMS TO ME, COULD BE THE RETRACE LINES ARE SHOWING UP AT TIMES WHEN THE PICTURE FRAMES ARE HIGH
Oct 16, 2009 | Vizio GV42L 42 in. LCD Television
Bad picture
  1. Hello boss, here is d way to make best use of it.
    step 1.Make sure ur LCD or Plasma HDTV has an HDMI port. Hopfuly u bought 1 with it, if not, you may be stuck using component cables. Not bad, but not he best. Component cables change d digital signal frm the cable box into an analog signal. This conversion allows for signal degradation. U want to keep the digital signal transmitted frm the cable company 2 go directly into ur HDTV. An HDMI cable will provide u wid this capability n with d clearest picture.
    2. Make sure ur cable box has an HDMI port. Most cable companies do not offer a cable box with an HDMI port on the initial install. You may need to upgrade by calling your cable company and asking if they have a cable box wid HDMI capability. Ask them 2 send u 1.
    3.Purchase an HDMI cable. TIP - The longer d distance between the cable box n d HDTV, the better d quality HDMI cable. This is due to degradation of d digital signal over long distances, wiz could result in a poor quality picture. ne distance over sixteen feet should be compensated 4 by using a heavier gauge HDMI cable. Oh yea, don't get taken by buying the most expensive cables. From what I have read, companies are cashing in on this relatively new technologymag-glass_10x10.gif. I bought my "gold-plated" HDMI cables from an Ebay Store, "eforcity" for about a quarter of the price found at the local electronic store. Connect one end of your HDMI cable into the HDMI (out) port on the back of your cable box and connect the other end to the HDMI (in) port on the back of your HDTV.55
    Read the instructions that came with ur new HDMI compatible cable box. These instructions will explain the download process the cable box needs to go through before use and the Setup Wizard that will program the cable box to send the correct picture format to your HDTV. If u did not get instructions, u can get them at the cable box manufacturers website. Scientific Atlanta's website: http://www.scientificatlanta.com/products/consumers/new_cableboxes.ht64. Adjust video, audio, and screen settings to ur liking. The explanation for these settings can be found in ur HDTV's user's manual.75.Push ur "source" button on ur remote control or HDTV n select HDMI. Tune to a Hi-Def channel. Most Hi-Def channels r in the 700 channel range. Check cable company listings 4 d specific channels.
  2. Have a nice time!!
Aug 19, 2009 | Sharp LC46SB54U 46 in. LCD TV
I am tring to connect my PC to my philips 32pf9631D plazma TV useing HDMI to HDMI cable but cannot get a piture up on the TV. Tried another monitor usung same cable, it works. Is there some special setting...
for the plasma tv, go to the menu and try to find some options about the HDMI on the menu or go through the user manual you will definitely find some solutions. or try to change the HDMI cables.
Aug 10, 2009 | Philips 32PFL3504D 32 in. LCD TV
How would i know if my HDMI ports are working or not?? Tried to connect a PS3 to it but nothing. Thought it may have been the cable so checked someones that i know is working and still nothing. Checked...
As you already checked PS3 and HDMI cable,
select HDMI input in TV and connect PS3 via HDMI cable. TV should show PS3 picture.
And if still no joy then HDMI input port in TV is bad and need to replace input board/ main board.
Jul 08, 2009 | LG M227WD-PZ LCD TV
Can not get picturew on TV
Hold the power button until you see the picture come up. I think it's around 10 seconds.
Jun 02, 2009 | Sony PlayStation® 3 (60 GB) Console
Video Game Consoles & Games Logo
19 people viewed this question
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
