Question about Hotpoint Dryers
My hotpoint tdc32 does not heat up just drys cold
  • 750 Answers
Friend,
huuum At your service!
You aid, my Hotpoint tdc32 does not heat up just drys cold
Sometimes this can happen when the vent line is clogged.
1. Check if the lint filter is full and needs to be cleaned.
Try this first.
2. Then check if the outside screen covering the exhaust vent is even half blocked with lint there will be no heat! This screen is to keep small animals out!
Try checking this second and if it is clogged or the spring loaded door is stuck closed try to clean the lint out of the corners of the flap door, and or remove the screen permanently!
I DID AND NO ANIMALS LIKE TO GET BURNT,IT'S HOT IN THAT TUBE!
2 years that mine is off and it's all is fine.
You will be fine
Bless You huuum
PLEASE GIVE ME A GOOD RATING BEFORE YOU SIGN OFF!
Posted on Sep 12, 2008
The dryer is not heating its running ok but remains cold
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
ioiotye
Sep 22, 2010 | Hotpoint TDC32 Electric Dryer
Tip
Common faults on a hotpoint tdc32
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning open circuit)
4 Modern tumble dryers also have sensors and pcb's (Printed circuitboards) these have programs that can fail and circuitry although most should produce an error code showing you were the fault is.
5 Faulty connections and burned wires may also bethe fault.
For Free Video help on yourHotpoint TDC32 Tumble Dryer USE THIS LINK
on Jan 17, 2010 | Hotpoint TDC32 Electric Dryer
Heats up slightly hotpoint condenser TDC32
heatman101
e76jy
Feb 18, 2010 | Hotpoint TDC32 Electric Dryer
TDC32 Dryer is running but is not heating up
Hi.
Common fault with these is the two thermostats that fit on the heater at the back of the appliance -- accessable by unscrewing the back cover (MAKE SURE POWER IS DISCONNECTED FIRST!!)
There is a choice of thermostats depending on the serial number of the appliance.
If you need any other assistance please email me on: aardvark.repairs@btinternet.com
Regards
Aardvark Repairs
Nov 01, 2009 | Hotpoint TDC32 Electric Dryer
My hotpoint aquarius tdc32 condenser tumble dryer is not heating
yes............the 2 round bits are the thermostats.......these need changing in pairs.......not just 1 of them
cheers
May 08, 2017 | Hotpoint Dryers
How do i clean the condenser on my hotpoint tdc32?
Remove condenser, and flush it out under a running tap, or hose pipe with cold water, this will flush all the fluff out of the condenser
Please rate my solution.
Thanks.
Aug 07, 2009 | Hotpoint TDC32 Electric Dryer
No heat in dryer
if you can see your heating element, use a meter to test for continuity. remove the clips or wires attached to the terminals of the heating element and put the probes of the meter.
the reading should be close to short since it is a heater. maybe 1 to 10 ohms.
tnx 4 using fixya,
drcool
Sep 28, 2008 | Hotpoint TDC32 Electric Dryer
1. see if you have 220 at the plug, the dryer will run on 110 but won't heat.
2. Check the heating coil, it could be broken.
Jul 02, 2008 | Hotpoint TDC32 Electric Dryer
Dryers Logo
55 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
