Question about Cameras
Camera switches on and the zoom lense works, the screen does not light up or allow me to take phto's
  • 74 Answers
What model is your camera have you tried the reset switch inside the battery housing?
Posted on Sep 12, 2008
My sigma lens will not zoom all the way
Be aware, most camera's only allow AF to work as long as the aperture is greater than 5,6 (greater aperture means smaller number) So your lens only works from f 5 to 5,6. The last part where the aperture goes to 6,3, the AF won't work. So as long as your setting is on AF, the camera can't focus from a certain focal lenght. Switch over to MF and you should be able to use the zoom all the way.
Jan 28, 2014 | Sigma APO 170-500mm f/5-6.3 DG for Minolta...
Why are my pictures blurry when focus is all the way out, and focused when all the way zoomed in? this is also visually obvious on the lCD screen. zoomed out( out of focus)..zoomed in( in focus).
your camera's lense is clear? try clean it with suitable cleaner for lense. If still not working, check your user manual for setting
May 09, 2011 | Cameras
I was shooting pictures with my camera at a concert. I used the zoom feture to zoom in, and it caused a zoom error in the camera. I turned the camera off to reboot it, but the lens stayed out. When I...
Hi it sounds like the lense has got knocked whilst the camera was one and the lense out, the damage may all ready be done but what you can try is when you switch it on get the lense and try pulling it out slightly and then when the camera is switched off try pushing the lense back in it may need turning slightly to allow it to go back in
if none of the above works then this means the lense motor has either been put under strain and shorted and no longer works or it just means the lense motor has packed up through no fault of your own.
now if pulling and pushing the lense dont solve the problem then it all depends on the make wether its worth repairing or not, if its a high end camera then most camera shops will repair it as the cost would work out worth doing,
if the camera is a mid to low end price range then knowbody will touch these as the cost would far out way the price of the camera so you need to think is it worth paying to get fixed and would the cost be more than the price of the camera.
if its a high end expensive camera then you will be able to get it fixed and it would work out cheaper than buying a new camera, if its a mid range to low end price range then you wont be able to get it fixed as they are classed as a throw away item,
if you let me know make and model i will be able to tell you if its going to be cost affective to get it repaired or if it will be better to sell it on the auction site as spares and cut your losses and get a new camera
let me know then i can assist you further ok
plz rate this solution as i have a whole page of unrated posts, thanks
Aug 29, 2010 | Cameras
I need a manual for AF 35-70mm f2.8 D zoom nikkor - no idea how to use this lens.
i was not able to find a manual - this review may help http://www.kenrockwell.com/nikon/3570.htm
The lens consists of
  1. Zoom
  2. Focus
  3. Aperture
  4. Macro
1) Zoom - this is by push pull - so you push the lens out to wide angle 2) To switch to manual focus - will need to be done on the camera and then you can use the front control ring to focus - 4) also you can use the button to switch to macro mode - BUT only with the Zoom at 35mm - lens fully extended 3) You have an aperture range of 2.8 - 22 this varies the amount of light allowed into the lens - 2.8 is the most light - F4 to F5.6 to F8 - each change halfs the light allowed in - so changing from F4 to F5.6 half the light
Mar 29, 2010 | Nikon 35-70mm f/2.8D AF Zoom-Nikkor Lens
Have a brand new EOS 100D with Canon image
Have you actually cleaned the contacts or are you just looking at them and they "look" clean? Clean them with a cotton swab lightly dampened in rubbing alcohol.
Feb 28, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Zoom Error
hi thanks for using fixya!
On this kind of error, I suggest that you bring your camera to a service center or to your retailer to further check the hardware problem of your camera.
Regards!
Apr 30, 2009 | Fuji FinePix A500 Digital Camera
Jammed lens
would be best to send to repair center
Sep 17, 2008 | Olympus FE-210 Digital Camera
Sony DSC-w50 zoom not working
switch on when the lense extends take the end of it and gently twist and pull the lense you may hear it click be gentle do not force it then switch off and on again and this will solve the problem 98% of the time.
Jan 25, 2008 | Sony Cyber-shot DSC-W50 Digital Camera
Panasonic DMC-FZ7 digital camera.
I believe the FZ7 determines that the lense cap is still on when it can't extend the zoom lense because the lense cap is in the way. I would check to see if your zoom lense housing is somehow stuck (could be sand or dirt in it) which is creating enough resistance to make the camera think the lense cap is impeding the zoom lense from extending.
Jan 03, 2008 | Panasonic Lumix DMC-FZ20 Digital Camera
Cameras Logo
74 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
