Question about Nikon Speedlight SB-600 TTL Flash
Batteries got discharged
Hello everyvody:
I had forgotten to take off the batteries from the flash and now its not working. When I put the batteries in the compartment the sound starts and nothing else happens. This is a 5 month old flash. Anybody has any solution? Thanks in advance for your help.
Mahuya Mukherjee
  • 62 Answers
Posted on Nov 28, 2008
Something inside popped when I fired it up after several years
Likely the capacitor that stores the electricity used to make the flash. Replacement may be more expensive than the flash itself.
May 16, 2015 | Vivitar 2800 Flash
Hello. The batteries on my speedlight discharge
if you are using regular batteries I can't help you, but if your using rechargeable batteries then the cause is old batteries, after many charges they don't charge well anymore. and you need to replace them
Mar 19, 2011 | Nikon Speedlight SB-800 TTL Flash
Camera flash is not working. Batteries in the
If camera flash is not working it must be the high - intensity discharge (HID )lamp of the flash assembly that got busted which needs to be replaced. Parts are available in every local camera shops and they are not that costly. So consult your nearest camera repair shop and have it replaced with a compatible HID flash lamp.
Take care!
Jul 08, 2010 | FUJIFILM instax mini 7 Digital Camera
Sigma EF-500-DG, does not charge and does not become ready
Thank you for using FixYa for your problem
Always check the batteries first - make sure they have full charge (in the wrong way can discharge them) but if is it still giving the same fault, your flash is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Sigma EF-500 DG Super for Canon EOS TTL...
Flashing red light on the Kensington wireless mouse base
I still have the manual for my mouse.  Model number 64321.
When this mouse was manufactured it used NiCad batteries which developed a memory much more than the newer batteries.  The older NiCad batteries needed to be conditioned occasionally so Kensington provided a way to do that with the charging base.
The red light is for indicating discharge status of NiCad batteries.
The red light will flash quickly when you press the battery discharge button on the bottom of the base.  This indicates that you now have 5 seconds to place the mouse in the charging base for battery discharge.
The red light will flash flash more slowly when the battery is being discharged.
After the battery is fully discharged, the base will then charge the batteries.
It should be noted that very few manufacturers of products that utilized NiCad batteries provided a "battery conditioning" feature.  Kensington was unique in this regard.  Battery conditioning allowed NiCad batteries to have a longer useful life.
Now maybe you can help me....  I lost my power supply that plugs into the USB connector.  If you have yours, can you tell me what the output voltage is and what the polarity is of the inner pin.  This will be marked right on the power supply base.
I plan to just get a generic power supply from Radio Shack, but I need the voltage value and polarity.  Until then, I can still use the mouse, but it won't charge.  FOr now, I'm just using standard AAA batteries.
Mar 17, 2009 | Kensington StudioMouse Wireless
Alkalines won't work in my 360 controller.
there are units designed to run on rechargeable batteries and some that run on alkaline batteries
the difference is the current draw required
alkaline batteries have a high discharge rate available but for short duration while the others have a smaller discharge rate but over a longer period of time
you should only use the type of batteries recommended for the unit
Apr 12, 2017 | Nyko Charge Station 360 For Xbox 360
Flash working inproperly
The battery contacts are not making proper contact to the battery, or there is a cold solder connection in the circuit board inside of the flash unit.
There are photo shops that can have flashes serviced, or you can send the flash to the manufacture service department.
Unless you are able to do electronics service and are used to working on high voltage electronics at the component level I don't recommend opening the flash yourself.
Inside the flash they use very high voltage at very high discharge current. Even though the flash looks innocent and works only on a few simple batteries, this can be dangeriously deceiving. The discharge current can be very high, and the main flash capacitor can hold a lethal charge for many days!
Servicing and safety for photo flash units:
Jerry G.
Apr 19, 2008 | Nikon Speedlight SB-600 TTL Flash
Flashing light
cycle the batteries in a external charger a fex times (charge then discharge) I suspect that over the years of using then putting it in its dock the batteries have had a very erratic charge discharge cycle cycling them as I suggest should bring them back.
Jul 25, 2007 | Logitech MX 700 Mouse
Battery Problem
Hi, thsi indicate the internal short in circuit which draining excess current and battery get discharged. You nee dto chek internal circuit from technical expert. some component must be short . let em knwo when it solved. thanks Sangita
Jul 08, 2007 | Fuji FinePix A360 Digital Camera
Speedlite 550EX Speedlite Flash
Let the flash rest for two weeks, to discharge the cap.
Buy Energizer Lit. Batteries.
Do not touch batteries ends with fingers.
Cleans 4 batteries with an Ink Eraser.
Apr 21, 2007 | Canon Speedlite 550EX TTL Flash
Nikon Speedlight SB-600 TTL Flash Logo
78 people viewed this question
Top Nikon Cameras Experts
Are you a Nikon Camera Expert? Answer questions, earn points and help others
