Question about Cameras
Hello, I can not access the images on my SD card. The monitor says that the card is locked, however the little locking chip on the side of the card is in unlocked position. Can you help, please? Many thanks Geri
  • sunshine79gp Sep 12, 2008
    No, I can not :(
  • sunshine79gp Sep 15, 2008
    Thank you! :) will try
  • 74 Answers
Can you view the pictures on the camera screen?
Posted on Sep 12, 2008
  • c Sep 15, 2008
    you can try by moving the lock back and forth a few times and see if it has just been jammed if not you can always try formating the card in the computer and this may resolve the issue if not it may be a csae of getting a new card
How do i unlock my memory card its not allowing me to take photos.
I am assuming that your camera uses and SD card to store the pictures.
If you remove the memory card from the camera, you should see a little slider on the side of the card that says "lock," it is easy to accidentally lock SD cards.
I have attached a picture to show you what a locked SD card looks like.\:codyrt.jpg
Here is another image showing the card in the unlocked position: codyrt_0.jpg
Mar 01, 2011 | Cameras
Memory card is write protected- the only thing appearing, denying access to recording or clicking photos.
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Aug 28, 2010 | Nikon Coolpix S210 Digital Camera
Inserted new memory card and getting error message - saying it's locked but it isn't. tried 3 new cards all with same message. Tried to format but the option to do so isn't accessable
Hello
If the card works in another camera or another card doesn't work in your camera , the problem is with your card reader in your camera.
Kind regards
Andrea
Jun 10, 2010 | Canon PowerShot S80 Digital Camera
When I take a pic it says card locked...
Hello
Kind regards
Andrea
May 16, 2010 | Polaroid i737 Digital Camera
Turn camera on and I get a little lock on the screen I can't get past this
Assuming this camera uses SD card, you may have set the card to "write protected". On the side of the SD card, there's a little slider that prevents accidental erasing images.
Oct 01, 2009 | Fisher Price Cameras
Memory card locked
There is a tiny button on the side of the card - so small you can hardly see it. Just slide it up and voila All is solved.
It is frustrating as there is nothing in the manual bout this and the onl line assistance wants to charge for 20 seconds advice Mine is free dorothy
Mar 24, 2009 | Canon PowerShot SD800 IS / IXUS 850 IS...
Locked card, not because of the switch
Hello
Kind regards
Andrea
Jul 15, 2008 | Samsung Digimax S500 Digital Camera
Card Locked
If it is an SD memory card, there is a switch actually on the edge of the card. Try moving it to the other position and reinstall. Most people don't realise it's even there untill they have problems.
If this works , please rate accordingly so others may follow.
Thanks.
If it doesn't, there will be access to view the locked photo's on the camera. Selecting protect/ lock again should remove this.
Jul 09, 2008 | Canon PowerShot A550 Digital Camera
Locked Card
Take the memory card out of the camera. Look at it carefully and you will seea small tab. Move the tab from the locked position to the unlocked position. Re-install the memory card into the camera and then you're done.
EEee
Nov 03, 2007 | Canon PowerShot SD630 Digital ELPH / IXUS...
Card Error
If the memory card is not recognized in the PC or it is impossible to access the data on it, the controller on the card is damaged. There is only one way to get the data back, unsolder memory chips and directly access their raw data with a programable chip reader. Software can't help, that is a physical damage! Have a look at: http://card-recovery.biz/us/service.php
Sep 11, 2005 | Toshiba PDR-M25 Digital Camera
Cameras Logo
56 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
