Hotpoint WDM73 won't drain, e15 error code.
5 yrs old, now won't drain. I've had all the hoses disconnected and if I keep putting spin only programme on I can get enough water out of the drum to remove the very wet clothes. I'm assuming it is the pump that needs replacing?? Or is there anything else I can try first? If it is the pump I see they are £40 ish from hotpoint, is it necessary to get someone to fit this for me or would I be able to do it myself. I only ask as due to the age of the machine and the fact that the door hinge snapped over 2 yrs ago I'm thinking its probably not worth the money to fix. Thanks
  • zebakhtar Jan 05, 2009
    got told by an engineer that it is the circuit board.hard to get.
SOURCE: Hotpoint wf860 - H2O Error Code - Machine is asking for water but draining it straight out
Check that your outlet pipe rises above the stated height on the back of the machine (about 3/4 of the way up). If it is too low, it will siphon the water out of the drum. If you're not sure what height it should be at, raise the top of the pipe (ie where it bends back into the outflow pipe) above the top of the machine (if you have room) or as high as you can. It must be above the height of the drum.
Good Luck
Posted on Jan 23, 2008
SOURCE: Hotpoint ultima extra washer dryer WDM73
i found this manual,if you know what your problem is this might show how to change the faulty bit. I dont know what machine this is but they all seem pretty simular, i used this to change my door lock.
Posted on Jun 16, 2008
  • 43 Answers
SOURCE: machine keeps stopping
if its right at beggining of wash could be pump blockage chack for coins or ffluff blocking filter
Posted on Nov 12, 2008
  • 2692 Answers
SOURCE: Close door error on display when door is closed on WDM73
Th eswitch that teel it that door is open is out of position or bad.
Posted on Jun 19, 2009
  • 662 Answers
SOURCE: wf310 hotpoint aquarius washing machine wont spin or drain
Power off the mains. The filter is located behind the silver plate at the back of the machine at the bottom. Four screws hold it on. Drain out all the water. The filter is inside the big black rubber hose attached between the pump and the main drum. Remove the plastic clip holding it to the pump unit and then the metal cir clip holding it to the main drum. Inside is a white molded cone and a big white ball which floats. You will find a lot of junk here, clean out thoroughly. To refit put white cone back inside just as you found it, at the bottom, fit ball back into the cone. Attach to the bottom to the drum and re-fasten the cir clip. Finally reconnect the gator to the pump unit and tighten the plastic clip. Check out the pump too before reconnecting.
And rate me nice pl for the free help!
Posted on Jun 08, 2010
My Hotpoint wdm73 won't drain. how do I fix it?
  1. You will need to gain access to the drain pump through the bottom of the Washing machine. Remove the Drain hoses from the pump, clear any debris, change, etc. If it is clear, or the error continues after clearing, replace the drain pump.
  2. If you replace the drain pump and it still won't drain, you will need a new Control Board.
Feb 27, 2011 | Hotpoint Ultima WDM73 Front Load Washer /...
What does f-5 mean when flashing at me and won,t let me have my washing out the machine also washing really hot after a fast spin programme
if water is in drum then door wont open,drop drain hose to floor level into bucket to drain manually, then check filter or pump is it running ok if not is it stuck some thing in it , hot wash is cold water inlet ok or is this due to again faulty pump ...
Jun 25, 2010 | Hotpoint Aquarius WD640 Front Load...
MACHINE STICKS WHEN SPIN PROGRAMME REACHED
The 03 error code is the drain. Disconnect the drain hoses and check for blockages. If no blockage "time" the drain interval. If it's more than 6 minutes it's the pump. Also make sure you're using the correct type of soap so the ball check valve on the bottom of the outer drum isn't getting fouled with excessive suds. Also disconnect the drain hose from your house plumbing and let it free flow on it's own. This will tell you if the block is in your plumbing, and not in the machine. Assuming that your filter is clean.
Pl rate me ‘very helpful’ for the free help!
May 31, 2010 | Bosch Classixx WFL 2066 Front Load Washer
My Hotpoint Ultima WMD 960 displays "F04" on the display panel before the programme ends. Have cleaned the filter and it worked OK in spin mode and finished normally but now have put in a washing load, it...
Error code F04 means pressure switch jammed on empty.
Do the following.
Remove lower rear panel of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside the hose.
Remove the hose on to the pump, and check for blockage or obstruction here as well.
Please rate my solution.
Thankyou.
Jan 25, 2010 | Hotpoint Ultima WF860 Front Load Washer
E15 code on display of Hotpoint ultima extra WD72.
E15 means that it is not draining fast enough. As well as checking the outlet pipes, check the filter leading to the pump. Disconnect the power and pipe. If possible take outside because there will be a residual amount of water. Remove the back panel, then disconnect the locking rings holding the tubes on. Your main target should be the big downflow rubber tube from the drum, in here is a plastic filter. In mine I found a child's sock... plus buttons...plus slime. Problem solved.
Dec 20, 2009 | Hotpoint Washing Machines
Machine keeps stopping
Nov 12, 2008 | Hotpoint Ultima WD72 Front Load...
Hotpoint WF860
here is the list of code meaning from hotpoint.
  • F10 - No cold fill. Check that the taps are on or if the drain hoses are kinked.
  • F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
  • F12 - No mixed fill. It is likely that the water is not turned on at the taps.
  • F13 - Check the water supply, inlet valve and hot and cold hose connections.
  • F14 - A fault with the water heating has occurred. Book a service engineer
  • F15 - Water is not being pumped out and a flood condition could occur. Check that the drainage hose is raised to the recommended minimum height and that the pipe is not blocked.
  • F16 - Extremely high water level Disconnect or turn off the water supply and ensure that the water level does not rise any more. Then Book a service engineer.
  • F17 - Door not closed properly. Close door firmly at the 3 o'clock position.
  • F20/1 - The thermistor resistance has drifted or the temperature scanning sequence is incorrect. The ambient temperature could be below freezing. Book a service engineer.
  • F30/31 - A motor drive problem has occurred. Try running the programme again. If the problem persists book a service engineer.
  • F40 - Water below protection level during a heat step. Book a service engineer.
  • F41 - Water level detect sequence incorrect. Book a service engineer.
  • F50/51 - Customer language and wash programme have not been saved. The system will run with default conditions (1000rpm max and English language). Book a service engineer to re-programme your product.
please do not forget to rate and comment about your experience with fixya.
Aug 17, 2008 | Hotpoint Ultima WF860 Front Load Washer
Aquarius Hotpoint WD440. 1400 Spin
The next step should be the pump out. If it is not pumping check your pump filter for obstructions. Check the drain hose and also your drain in the wall. If all are clear you may have a bad pump. You should have an error code coming up when the machine stops also, please let me know what it is. Thanks and I hope I can FixYa.
Mike
May 09, 2008 | Hotpoint Aquarius WD640 Front Load...
ERROR MESSAGE ON SCREEN STATES CHECK OUTLET PIPE E15
It probably needs a new Pump, the wm72 has what they call a magnet pump and they can give false readings to the programme. Anew pump will cost sround 20 GBP. For an engineer to do it will cost around 50 GBP.
Nov 18, 2007 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
348 people viewed this question
Top Washing Machines Experts
