Question about HP LaserJet 1320n Printer
Hi my name is Derrick, a Network Administrator.
i've been experiencing some printing problems any time i isue a print command it gives me eror printing to laserjet 1320. this printer is on a network and it was printing before. infact i changed the location and and changed the cable as well it was on usb cable but i had to use LPT. this section of the network is working perfectly but same problem has resurfaced on aother section of the network it is again on a usb cable please help me solve this problem. I believe it is solvable by an installation of a file or something. please !!!
my e_mail address is yebdee@yahoo.com. i would be most grateful to have your address so i can send you some mails in case i have some problems. Thanks and God bless you.
I did tried to to switch off and on, the 1320 printer to correct this errior reading all light on. but could not be stable
Posted on Oct 07, 2008
    Renaissance:
    An user who is expert in 3 categories / brands.
  • HP Master
  • 1,362 Answers
Solved?????????
Posted on Sep 25, 2008
HP LaserJet 1320n Printer connected with usb to pc running on windows7; faded printing; economode = off; printer Density =3; what could be the problem
Faded printing is usuallly caused by an empty or defective toner cartridge. If the toner is new and the printer was working fine before the toner change then you might have a defective cartridge, or you may not have removed the tape strip from the cartridge when you installed it.
Oct 15, 2011 | HP LaserJet 1320n Printer
I have 1320n printer but i cannot print in network plz solve
YOUR PRINTER IS NOT SHARED ON THE NETWORK FIRST GO TO THAT COMPUTER WHERE IT IS INSTALLED AND GO TO "PRINTER AND FAX" OPTION RIGHT CLICK ON 1320N PRINTER THEN SELECT PROPERTY THEN SELECT SHARE OPTION AND CHECK THE OPTION "SHARE THIS PRINTER".
Jan 19, 2011 | HP LaserJet 1320 Printer
Is there a counter for pages printed on my 1320n
No, the page count is not on the test page. You need the configuration page. Press the GO button and hold for 5 seconds. The yellow light will come on and you can release.
Apr 05, 2010 | HP LaserJet 1320n Printer
Printer wont print after ink cartridge change
Hi pater_g:
Have you tried to reinstall the old cartidge to see if it would give a different problem ( light print ect.) if not try that. If the problem stays and you just can't communicate with the printer try rebooting you computer or go to www.hp.com/support to download a new print driver. I hope this helps you.
Apr 17, 2009 | HP LaserJet 1320n Printer
How to wirelessly access HP Laserjet 1320n via Apple iBook
You need to disconnect the USB cable and set it up wireless on both units:
Since it is plugged into the router, it should already have an IP address.
Un-install the printer from the computers.
Then re-install the printer from the cd or from HP's website. When you get to the point where it ask you is the printer is attached to the computer or is it over the network. Choose over the net work and the software will find the printer IP and finish setting it up wireless.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 13, 2009 | HP PhotoSmart 1215 InkJet Printer
Hp 1320n cant print jobs simultaneously from different users
You may need to add memory to the printer so it can que the jobs. The memory is very cheap...128MB 100-pin DIMM for HP OEM# C9121A
Or...you could setup a printer server que and let the print server manage the jobs for you instead of having the printer hold the que.
Dec 09, 2008 | HP LaserJet 1320n Printer
Not working on window 2003 server as a network printer
I have had a similar issue with both laserjet 3005N and 1320N machines setup as network printers on a windows 2003 print server. Both machines install correctly and print test pages but once you push to much of a print job to it (in my case it was a 12mb pdf file) the printer stops printing and never prints again for some reason. After a quick reboot a test page will print but what gives?? Buffer issues? Not enough ram? None of this makes sense since the printer displays nothing and just stops printNo test pages or anything. I tried re-installing it and rebooting it. Nothing.
Jul 12, 2008 | HP LaserJet 1320 Printer
Light print out
plz try with new tonner
Jul 03, 2008 | HP LaserJet 1320n Printer
Unable to communicate to a 1320n laserjet printer
unistall the driver completly and install again so after that click shared printer and them try it
Sep 25, 2007 | HP LaserJet 1320n Printer
1320n won't finish print job
This seems to be a Card failure- time for a replacement? is that possible?
Jun 14, 2007 | HP LaserJet 1320 Printer
HP LaserJet 1320n Printer Logo
105 people viewed this question
Ben Johnson
