Question about Microsoft Xbox 360 Console
My Tray Door popped open after two red lights shut down console and won't close!
Please help, my tray door popped open after two red lights shut down my 360 console and won't close. I finally closed it manually and when I turned it back on the center green light was blinking and the screen says "Opening" on the dashboard. I eventually opened it manually with a paper clip to get the disk out and after it was opened all the way the center green light quit blinking after I pressed the eject button and the dashboard says "Closing". My Warranty is out since April 2008 and I'm ready to pop this thing open, so Please help!
  • 344 Answers
Here is a great page that has a step by step process for opening your unit. (they also sell parts and mod equipment)
http://www.llamma.com/xbox360/repair/Xbox-360-Disassembly.htm
You may need a new drive, but I doubt it. After you get the Xbox open, peel off the silver tape thats on the bottom front of the DVD player, unplug the 2 connections, and lift it out. Turn the player upside down and remove the 4 screws, flip it back over and make sure that the try is lined up correctly with the mechinism.
I hope this helps. Good luck and happy gaming!!
Posted on Sep 12, 2008
Magnavox ZC320MW8 door stays open
f the tray won't open or close properly, check the belt for dirt or wear. Then check the tray for misalignment. If needed, remove, clean, lubricate, and reinstall the tray following the instructions in the owner's manual.
God bless you
Sep 27, 2012 | Magnavox ZC320MW8 DVD Recorder Refurbished
Bypass Tray Troubles
Has your copier got a door that opens an closes if it has switch it off then press and hold the door or flap down and see if this removes the message doing this would tell you that the problem is not with the door then we can look at other possibiltys let me know what happens ok
Feb 12, 2008 | Office Equipment & Supplies
CD DOOR WON'T OPEN
Just below the CD/DVD tray there is a tiny hole. Insert a straighten paper clip in this hole and gently push the paper clip until the CD/DVD tray pops out. You can now pull the tray out until it is in the fully opened position to remove the disc.
Try pushing the eject button to see if the tray closes, then push the eject button to see if the tray opens.
If this foes not work then the CD/DVD drive is faulty and it needs to be replaced.
Mar 06, 2012 | Dell Computers & Internet
Output tray is closed
Hello.
This is the door on the very front of the printer. When down it acts like a paper tray to catch printed paper.
This door must be open before you start printing. to open it simply push the top of it slightly, and it will pop open.
I hope this helps, Regards GM
Jul 28, 2011 | Canon Pixma iP4500 InkJet Printer
Xbox 360 Console: My xbox 360 will keep opening its tray and it won'...
The very first thing, I would suggest you is to check the CD cover, as sometimes labels on CDs prevent tray to close.
If that does not work then do the following.
Remove disc from the tray, make sure the faceplate is on correctly.
The faceplate is the plastic piece on the front of your console.
• Press firmly around the edges of your faceplate to snap it into place (make sure it is flush with the rest of the console). If the faceplate is not on correctly, the disc tray won't close.
• If you find that the faceplate is the problem, please contact Xbox customer support to order a replacement faceplate.
If this does not resolve your issue, please try step 3 and other steps from following link.
http://support.xbox.com/support/en/us/xbox360/kb.aspx?ID=907590&lcid=1033&category=hardware
If you wish you can also use following link of interactive troubleshooting wizard, which will assist you to narrow down on the issue.
http://support.xbox.com/support/en/us/Solutions/wizardhost.aspx?wizardid=xdds
This solution is absolutely free. If your issue is still not resolved, please feel free to ask.
Please rate and give your feedback.
May 03, 2010 | Video Game Consoles & Games
Sony PlayStation 2 Slim disk only spins if door is a little bit open, I even put something on it so that it won open or shuts completely, because if it does, then it doesn't work,for reference, it was...
tray problem can be solved by opening the ps2
1. unscrew all the screw open the body
2. on the upper body u can see a spring on the tray
just clean the spring (dust particles)
3.cover the tray check whether it is working
Mar 22, 2010 | Sony PlayStation 2 (PS2) Console
When game put in screen says tray is open?
something may be blocking the drive door such and paper or dust build up. try pushing on drawer a little after it shuts to see if that helps
Apr 18, 2009 | Microsoft Xbox 360 Console
My 360 elite makes me open and close the disc tray
DVD Drive failure most common problem, this ranges from dirty disk error (DDE) message to inoperable drive door, skipping in movies, slow load time or no load or the call customer service errors 10, 11, and 12. To replace the drive it will have to be reflashed.
Feb 17, 2009 | Microsoft Xbox 360 Elite Console
DVD DOOR WILL NOT OPEN YOU CAN HEAR DVD TRY TO OPEN
the dvd or game could be stuck. try turning the console upside down and eject the tray. or try tilting it to the sides and eject it. if all else fails then you might want to open it up and manualy eject it because its a pc dvd drive so you can pop the xbox tray guard off and stick a paperclick in the hole and push into the mech to pop the tray out to retreave the dvd
Jan 22, 2009 | Microsoft Xbox 360 Console
My xbox wont stay shut
push it in until it closes .i know it sounds crazy but it worked for my ps2. i dont know about xbox though.
Nov 13, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
124 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Tre Elkins
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
