MKJ32022805 REMOTE CONTROL
Hi, I have a 32" lcd tv,the remote has stopped working & I have replaced the batteries but still will not work,I have checked the input manually but it will not work on either tv or av.Do you think I need to replace it,I have the TV about 13 months.
Thank you.
Eddie.
obrienej@eircom.net
  • Anonymous Dec 28, 2008
    same
  • Anonymous Mar 21, 2009
    Same problem.
SOURCE: green screen vizio lcd
My 37" vizio I bought in Dec 2007 did this (green screen at start-up on all inputs). At first it went away by itself after you left the unit on for 15 minutes, but then 2 days later the whole thing DIED. Luckily Costco has a 90 day return policy on TVs.
Vizio tech support suggested this (before it died that is):
Please try to reset all setting and then to see if the problem is solved. 1. Press the Menu on your Remote Control;
2. choose Set up on the OSD;
3. then choose Reset All settings;
4. Press the Exit on your Remote Control to remove the OSD.
Posted on Jan 09, 2008
  • 14 Answers
SOURCE: Sharp Aquos 32"
TV is under warranty. Get a tech to look at it. It could require a new IR sensor, a firmware upgrade or a system reset that only a tech can do called an Industry Initialization that is in the service mode only
Posted on Jul 25, 2008
  • 56 Answers
SOURCE: remote control code for 32 inch lcd EMERSON TV
http://www.hifi-remote.com/ofa/codes-tv.shtml#tv t
Posted on Feb 02, 2009
  • 36 Answers
SOURCE: neewd remote control number
well you say that you need to get another remote for you TV..you can buy it here at this link..http://www.amazon.com/Akai-LCT3701AD-Panel-Built-Player/dp/B000WEODRU ..ok
Posted on May 27, 2009
I succeeded is using the DirectTV remote control for the Emerson 42" plasma TV, by using a Samsung code. On my TV, was 10060. If this one does not work, there are a bunch of others that might work. Good luck
Posted on Dec 31, 2009
My remote control for Haier tv stopped working, despite good batteries
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
Nov 19, 2014 | Haier HL32R 32 in. LCD TV
I have a 32" insignia LCD TV. My remote stop
You can reset your remote control by removing the batteries, pressing all of its buttons, and installing new batteries. Also, ensure that your TV's sensor is clean and unobstructed. If the problem persists, try using a universal remote control as a troubleshooting step. This will help identify whether the original remote or the TV is at fault.
Oct 20, 2011 | Insignia IS-LCDTV32 32 in. Television
Remote control for 32" TV
If you try a universal remote, such as from cable company or satellite provider and it still does not work with remote, you need an IR receiver module #DUNTKE264FM02 for your tv. this can be found at encompassparts.com and retails for about $22.00
Jul 11, 2011 | Sharp LC-32SB24U 32 in. LCD TV
Remote will not control the tv. batteries is good, but nothing happen when pointing at the tv five feet away. what is cause/
hi, it could be either 1 of 2 things.
1.remote is faulty, if the remote used to work but now doesntand you are sure the batteries are good, its probably not that.
2. a faulty IR / Remote Control Sensor Board . very common problem with an easy cheap replacement. here is a link to one for $20, just remove the back of the tv and remove and replace the new board. be careful when working inside the tv, lots of fragile things in there!
http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1165163&Click=54985
good luck!
Feb 10, 2011 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My sharp 32" LCD stopped recognizing the remote, b...
I had the same issue with my Sharp Aquos 52 inch LCD TV. I called Sharp. The tech had me unplug my TV, take the batteries out of the remote (TV remote not cable) and press all buttons on the remote (including the buttons under the flip top at the bottom of the remote). I did this, put the batteries back in and plugged in the tv and everything worked. I had gone 4 months having to use the surround sound for volume and turning the TV on and off by hand. This took 2 minutes to fix.
May 20, 2010 | Sharp AQUOS LC-32D44U 32 in. LCD TV
L32W761 32 in. LCD TV: my channel changer stopped working only the power ...
Channel changer from the remote? or from the TV? if it is from the remote, that's an easy fix, take off the batteries open the back of the remote, clean the circute board the one that is painted green, clean the remote contact pads as well the one that has a black dot like thingy with cotton balls slightly damp in rubbing alcohol, let it dry put it back together and replace with a new battery.
May 18, 2010 | Envision L32W761 32 in. LCD TV
Remote control
Be sure to check all your menu settings for the remote control function. Shake the remote a little bit if you hear some rattling inside then its broken. It could bee the IR eye that's has developed a problem with-in the remote or the tv itself. Try a universal remote to see if its the tv or the remote that's not responding.
Nov 03, 2009 | Soyo DYLT032D 32 in. LCD Television
The remote control for our Technika lcd 26-207 doesn't work.
Sounds like maybe the remote receiver on the tv itself has gone faulty if a replacement remote doesn't work.
email me on markiexxxx (at) gmail (dot) com
for more info...
Sep 29, 2009 | Televison & Video
Vizio L32 HDTV 10A-remote
Try a new Remote control, and if that doesn't fix the problem, it may be a remote sensor in the set. Hope this helps. Have a great weekend
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Vizio L32 32 in. LCD HDTV
Televison & Video Logo
285 people viewed this question
Top Televison & Video Experts
Electro Med Services...
