Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water line keeps snapping at inlet valve on refrigerator
I have a 89 Amana 3 door, and the vinyl tubing keeps snapping every few years where the tubing loops to the inlet valve - it has a spring inside to reduce pressure on the line, but it still snaps causing water damage to lower neighbor - I was told because this area gets hot, it weakens the tubing. Is there something better I can use that will thread to the inlet valve, such as a stainless hose or copper tubing for a few feet, then use an adapter of some sort to attach to vinyl tubing going up the back wall of the fridge?
  • Dennis Sep 17, 2008
    Final solution, as sent to repairclinic.com, and Amana - Problem pretty well solved - Appliance Rescue came out, young tech studied problem awhile - could not find copper nut to fit on inlet valve - he ended up not installing inlet valve in place where Amana had it, but sitting short distance away - the way Amana had it, the inlet valve has vinyl tubing pointing straight down, towards the floor, forcing vinyl tubing to make an immediate 90 degree loop, by having vinyl tubing instead of short copper piece behind fridge, and changing inlet valve this way, fridge can be pushed back, and vinyl tubing stays almost straight, and a bit aways from the compressor. I will still be ordering and installing a Flood Stop on this next payday.
    Genius:
  • 1,122 Answers
Just go to home depot to the a/c heating section and get a piece of insulating foam this should do it,mike
Posted on Sep 12, 2008
HOW TO HOOK UP AND START THE ICE MAKER ON JSI_23
Good Morning Le Morrer,
I see that you are trying to hook up and start the ice maker on your Frigidaire refrigerator, model# FRS3R5EMB.
To connect Water supply Line to ice Maker inlet valve:
1 Disconnect your refrigerator from the electric power source.
2 Place the end of water supply line into sink or bucket. Turn ON water supply and flush supply line until water is clear. Turn OFF water supply at shutoff valve.
3 Remove plastic cap from water valve inlet and discard cap.
4 If you use copper tubing - Slide brass compression nut, then ferrule (sleeve) onto water supply line. Push water supply line into water valve inlet as far as it will go (1/4 inch/6.4mm). Slide ferrule (sleeve) into valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
If you use stainless steel tubing - The nut and ferrule are already assembled on the tubing. Slide compression nut onto valve inlet and finger tighten compression nut onto valve. Tighten another half turn with a wrench; DO NOT over tighten.
5 With steel clamp and screw, secure water supply line (copper tubing only) to rear panel of refrigerator as shown.
6 Coil excess water supply line (copper tubing only) about 2 and 1/2 turns behind refrigerator and arrange coils so they do not vibrate or wear against any other surface.
7 Turn ON the water supply at shutoff valve and tighten any connections that leak.
8 Reconnect your refrigerator to electrical power source.
9 To turn the ice maker on, lower wire signal arm (side mounted) or set the ice maker's ON/Off power switch to the "I" position (rear mounted).
After connecting the water supply, you will need to prime the water supply system.
To Prime The Water Supply System:
1 Begin filling the tank by pressing and holding a drinking glass against the water dispenser paddle.
2 Keep the glass in this position until water comes out of the dispenser. There will be noticeable spurts and sputters as the system pushes air out through the system and dispenser nozzle. This is normal. This may take about 1 and 1/2 minutes.
3 Continue dispensing water for about 3 minutes to flush the system of any air and impurities. Empty the glass as needed.
The water dispenser has a built-in device that shuts off the water flow after 3 minutes of continuous use. To reset this shutoff device, simply release the dispenser paddle. Hope this is helpful.
-Best Regards-
WP
Mar 14, 2014 | Frigidaire FRS3R5EMB Side by Side...
No water being delivered to the ice maker tray . Water in the door works, new water filter. Tried disconnecting power for 5 mins. Can the water intake freeze. Should I let the freezer defrost ???
There is a tube that feeds the icemaker if you follow the water line from the inlet valve up the back of fridge and remove full tube you can see any ice buildup or try these.
There are only 3 things that will prevent an icemaker from not making ice.
1) Temperature in freezer. Most icemakers require that the temp in the freezer is at a minium of 6 degrees. If the thermostat in the icemaker is not reading this temp or below it will not let the icemaker call for water to make ice.
2) Icemaker. Is the arm on the icemaker in the correct position. Most models the arm should be down to operate and up to be off. Faulty icemaker. The internal components of the icemaker may have went out.
3) Water inlet valve. If the silinoid for the icemaker on the inlet valve is stuck it will not allow water to the icemaker. Over time inlet valves wear out.
Troubleshooting- Check the temp in freezer. If not 6 degrees or below you have another problem with your freezer. If at 6 degrees or below and you have ice and water through door unplug fridge, switch the two hoses from the inlet valve (NOT Possible on all inlets so check to make sure you can remove the hoses by pushing in on the cylinder that hose feeds into and pulling hose out) Switch the hoses than press the water through door feature. If you get water inlet valve is good. If you dont have ice and water though door than have your inlet valve tested. If inlet is good and temp is good replace icemaker. If you have any questions or need further assistance please respond. Thank you
Aug 01, 2011 | Amana 22.6 cu. ft. Side-By-Side...
No water flows to the ice maker. Good pressure, level, switch on, cold enough, lever down, unit snapped in. 1 year old
I like this you have covered most of the things that would stop ice harvest / s o ck the water delivery tube for ice build up if blocked defrost with hot water and turkey baster . new type tube is a shute not a tube . and water valve that drips through will caus this .. hope this helped mm . also but very rare is there is a fuse in the wire harnes on side of icemker . ck this , mm
Aug 11, 2010 | Amana AFI2538AES Stainless Steel (256 cu...
Ice maker stopped working
Good day,
A step by step procedure should resolve your problem. If the dispenser is working, you can skip that step.
First step is to take a small paper cup of water and fill the cavity until it is near full. With the ice maker turned on, close freezer door and wait 3 hours to see if it harvests. If not, the ice maker is bad, and must be replaced. If the cubes harvest then.......
Three possibilities.
1. The water supply from the house is not delivering water to the water valve. Shut off the house at the meter, disconnect the line going to the water valve, and with the line pointed into a bucket, have someone turn the valve back on for a 15 second count. The water should come out smartly. If not, the line and it's fittings will have to be replaced.
2. The fill tube from the back of the machine that feeds water into the back of the ice maker is frozen up. You will have to remove the ice maker to visually inspect that tube. If blocked, it needs to be defrosted, but use caution. Too much heat too fast will start to melt plastic and vinyl parts you don't want melted.
If this is the case, then once cleaned out, you will have to change the water valve located in the back bottom rear of the machine because it is leaking during the off cycle.
3. If everything checks O.K. up to this point, you will have to purchase and install a new water valve, and install it.
P.S. Under very rare occasions the electric circuity in the ice maker will fail to send a signal to the water valve. Although rare, it can happen, in which case the best option is to replace the ice maker and water valve.
May 25, 2010 | Amana 22.6 cu. ft. Side-By-Side...
I have an Amana ARB8057CSR Bottom Freezer Refrigerator and the freezer stoped making ice and there is still water coming out of the tap.
Good day,
As long as your sure the temperature in the freezer is within it's normal range, the best procedure is to follow a step by step trouble shooting method to correct your problem.
May 18, 2010 | Amana ARB8057CSR Bottom Freezer...
Water dispenser is flowing super slow, almost a trickle. Takes forever to fill a glass. Kids won't even use it anymore.
HI. This will happen if the filter is near its filtering capacity limit. You will need to replace the filter in this case, asap. This will correct the issue.
Note( If the filter is not the issue, a more uncommon issue will be a faulty water inlet valve assembly)
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush
or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.
Oct 10, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Amana ARS2665AW side by side ice maker not filling
Is the freezer cold enough? Should be close to 10 degrees.
Is there water or ice in the ice mold? If not put water in it and see if it dumps the ice after it’s frozen. If there is ice, lift the cut off arm and let it drop to see if it will start.
If it does dump the ice but don’t refill with water.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Aug 27, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Water icing in ice maker tubing
Replace the water inlet valve . Water is seeping thru the valve when closed . Drops of water seeping thru and freezing inside the fill tube . After replaceing valve , be sure to remove the ice from the fill tube .
Aug 12, 2009 | Amana ASD2526VES Stainless Steel Side by...
The icemaker overfills and the water keeps running and runs out of the fridge onto the floor
Hi, If the ice maker is overflowing, you will need to change the inlet valve. The inlet valve should only draw water when 120V is sent to the solenoid to open it. The inlet valve is located in back and has the water supply tube attached to it.
I hope this helps you. If I can assist you further, please let me know.
Vic
Jun 05, 2009 | Amana ASB 2623 Side by Side Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
103 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
ka4iup
ka4iup
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
