Question about Zanussi ZWF1440 Front Load Washer
Zanussi zwf1631w jetwash front loading washing m/c
Error code E30 Start of cycle drains (that works ok) then jumps to end of program and switches off bleeps shows drain light only (RHS) and error code E30
can you please help
regards richard
  • zigopy Feb 12, 2009
    I have the same problem with my washer, I have had an engineer out to look at my washer, E30 error code relates to pressure switch problems. However, both the switches have been changed and the error code and problem still exist & the engineer is now scratching his head as he has tried everything possible with the pressure system. Have anyone any other suggestions.
Had to call an enginer out, the problem was down to a faulty motor rota, to identify if e30 is this fault, rotate the drum (so the motor rotates) and try to start the m/c. if it runs ok you know to change the rota. hope this may help someone
Posted on Sep 16, 2008
New carbon brushes
Posted on Oct 22, 2008
  • 157 Answers
Carbon brushes needed
Posted on Oct 05, 2011
Start/Pause light flashes, won't start. No error code. Pump or hose blockage?
It is a common fault that the drain fails to work in most machines in a period of time and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged. Now remove the drain hose clamps and remove the drain pump/valve, clean the drain pump/valve, use back flushing to clear off all dirt. Now test using power to see if this works and can be simulated. When refitting, the hose must be tightened properly. If the pump/valve does not work even with power then it must be replaced. If there is intermittent power to the drain valve/pump then the program controller unit is a suspect.
Cleaning a pump:
Finally the washer must be placed with a tilt- use a spirit level- so that all water will drain to the outlet port and thereby there is no residual water remaining.
Replacing the pump on a Bosch machine, please check this link for tips:
Jun 28, 2012 | Zanussi FJS1225W Front Load Washer
Zanussi zfw 1631 w skipping through programmes straight onto drain from wash. has been coming up with an error code e30
I'm going to take a stab at the filter on the empty pump being blocked.
I have tried to find an error code that matches for you and loads of forums talk about a possible blocked pump filter (Though I have seen a motor fault mentioned too!).
Try checking the filter out, it's the biggest cause of questions being posted on this site for washing machines
Jun 29, 2011 | Zanussi Washing Machines
My Zanussi zwf1650w comes up with a message draining 0 0 after about 30 seconds of starting a wash cycle. The machine the stops and bleeps saying cycle ended, is there a solution to fix this?
zanussi zwf1650w washing machine. when starting any program after a few seconds machines stops and shows draining 0.0. have done diagnosis test and shows fault E91 & E48 fault codes also shows E34 code. any help much appreciated.
Nov 05, 2010 | Zanussi ZWF1650W Front Load Washer
E30 use washer once the second time the machine starts and jumps to the end leave for appox 30 min it then starts
E30/31 - A motor drive problem has occurred. Try running the program again.
Many times simply checking the motor's wire harness plug - it has vibrated loose.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 17, 2010 | Zanussi FJD1266W Front Load Washer
Machine stops half way through program
One looses touch with all the codes available, but normally if washer stops mid cycle its due to a blocked or faulty drain pump. OR incomming water is to slow or defective inlet sensor. Switch off and start from the beginning. See if you can get machine to drain by moving the timer etc. If not, rectify pump problem. Take note where in the cycle the problem arises.
Jul 21, 2010 | Zanussi ZWD1680W Front Load Washer / Dryer
Error E20
zanussi error E20 suggests a pump/draining problem. remove pump/filter and clean it all out. its located at the end of the drain hose at the bottom of machine. power off. it might need replacement.
Nov 01, 2009 | Zanussi ZWF1430W Front Load Washer
Zanussi washing machine zwf1437w error code e30
E30 indicates a pressure system fault. There can be several causes but the most frequent is a blockage in the system.
First thing to do is check the filter on front of machine.
Please do this and report your findings.
Jan 29, 2009 | Zanussi FJS1225W Front Load Washer
Zanussi zwf1631w error code e40
E40 is the fault code for the doorlock, these are relatively cheap and easy to fit and if an independent (non zanussi) engineer was to fit it, you will probably be looking at around £40-£50 all in as a rough guide.
hope this helps
please dont forget to rate the helpfulness of this reply, thanks kj
Nov 10, 2008 | Zanussi ZWF1440 Front Load Washer
Washing machine displays E30
I have just had the same fault on a ZWF1631W machine. The machine overfills and goes straight to drain.
The level is controlled by an air pressure switch.
Remove the machine top, the switch is the round white plastic one. On mine, one of the wires had broken off. I had to replace the connector with .25" crimps.
If not, the switch may need replacing.
Mar 07, 2008 | Zanussi ZWF1630 Front Load Washer
Zanussi ZWF1440 Front Load Washer Logo
1,993 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
