Question about Durabrand Audio Players & Recorders
Duraband 2.0 ch usb speakers
I have plugged these speakers in but when I reboot my system they are not listed in mu sound devices and also are not coming uo as new hardware when i rebooted
  • 108 Answers
SOURCE: speakers 2.0 durabrand not registering
If both sets work on one computer, but none of them work on the problem machine, then it's not the speakers that are at fault, but rather the computer you're plugging them into.
As you are getting a "No Audio Devices" message, and the speakers get their signal from your systems soundcard, the soundcard drivers may not be installed, or working properly (the USB plug, it seems, only serves to power the speakers, nothing else).
Open up Device Manager, and look for your soundcard, and/or any devices marked with a Question (?) or Exclamation (!) Mark. Install/reinstall the drivers for any of these that you see. If you don't see anything marked as such, locate your soundcard under the "Sound and Audio devices" header, and reinstall it.
(NOTE: You can get to device manager in Windows XP, by going to Start-> Run -> type in "Control", and press ENTER. From the window that pops up, make sure you're using Classic View, then go to System -> Hardware -> Device Manager.)
If you DON'T, however, see either unknown devices or your soundcard listed in Sounds and Audio Devices, reseat your soundcard in it's PCI slot or a different slot in your machine, boot up your computer, and see if it's recognized. if it isn't, or if you're using an onboard sound solution, you may have to replace your soundcard, as it's defective.
Hope this helps :~)
Posted on Dec 31, 2007
SOURCE: Speakers won't work
some time if your operating system does not support your usb itself.
you install its software first by try on web
Posted on Jan 04, 2008
ComputerDave
  • 128 Answers
SOURCE: acer computer speakers
Speaker issue desktop's only
1. Plug USB into USB port (any)
2. Plug Black speak cable into LIGH GREEN (NOT BLACK) connector
3. You will see a popup window - make sure it is on Front Speaker out
4. Click OK - you will a cartoon computer with speakers on either side -then click on one of the
speakers to test
5. if that does not work then follow this:
Reinstalling apps:
1. If in Windows - Start - Programs - Acer Empowering Technology - Acer E-recovery management -
click on Restore at bottom then "Reinstall apps and drivers" - look for hardware drivers that you
need. Click "install now"
Posted on Feb 02, 2008
SOURCE: DURABRAND 2.0 CH USB COMPUTER SPEAKERS
I could not get my speakers to work but i kept messing around on the computer and finally they started working. Dont really know how i did it but they work good now.
Posted on Sep 26, 2008
yooperbud
  • 8637 Answers
SOURCE: not getting sound out of speakers
Go into Control Panel and click on SOUNDS and when the Sound Properties window opens check to see if the speakers are set right.
Hope this helps. Bud
Posted on Jan 19, 2009
I rebooted my computer,& now my speakers aren't givng out any sound
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers or uninstall
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Jun 23, 2011 | Altec Lansing VS2120 2-PC SPEAKER SYSTEM...
The sound on my computer is not working. It is not muted. Can you help?
I can't hear sound from my computer.
There are a few simple things to check first:
Make sure your computer has a sound card.
You must be logged on as an administrator to perform these steps.
1. Open Device Manager by clicking the Start button Picture of the Start button, clicking Control Panel, clicking System and Maintenance, and then clicking Device Manager.? Administrator permission required If you are prompted for an administrator password or confirmation, type the password or provide confirmation.
2. Expand the Sound, video and game controllers category. If a sound card is listed, you have one installed. If no sound card is listed, You will need to install one. See Install or remove a sound card.
Note
If you think you have a sound card installed but you don't see it under the Sound, video and game controllers category, expand the Other devices category and check any devices listed there.
3. If there is a yellow question mark next to the name of the sound card, there might be a problem. Right-click the name of the sound card, and then click Properties.
4. Click the General tab, and then look in the Device status box to identify problems with the sound card.
Make sure your speakers are plugged into a working power source and turned on.
Make sure your speakers are correctly connected to the computer.
On your speakers, find the cable that plugs into your computer. Make sure that the speaker cable is plugged into the speakers and the correct jack on the computer. For example, if the cable is a 1/8 inch cable, there should be a round jack for it on the back of the computer. If it is a universal serial bus (USB) cable, it will plug into any USB port on your computer.
Make sure that the speaker volume is not muted or turned down too low.
1. Open Volume Control by clicking the Start button Picture of the Start button, clicking Control Panel, clicking Hardware and Sound, and then, under Audio Devices and Sound, clicking Adjust system volume.
2. Under Main Volume, move the slider up or down to raise or lower the volume.
Nov 17, 2010 | Computers & Internet
Altec Lansing Orbit USB IML237. We got two of these for xmas. There is no sound when these are plugged into any of three macbooks. What gives?
In order to get the IML237 Orbit USB speakers to work onan apple computer, you must change the settings in system preferences.
1.click on the apple icon
2.click on system preferences
3.click on sound
4.click on output
(veryimportant! the speaker MUST be plugged into the USB port in order to show onthe "select a device for sound output" list.)
5.the IML237 Orbit USB speakers will show up under, "USB Sound Device"
6.click on "USB Sound Device"
7.play some music on itunes
Nowthe speakers will automatically be detected when you plug in the speakers. Youshould not have to re-adjust the settings.
Jan 14, 2010 | Altec Lansing iM-237 Orbit Ultra Portable...
USB device not recognized
Check the Windows 7 Compatability list. Find it here:
www.microsoft.com/windows/compatibility/windows-7/en-us/default.aspx
Look in the hardware section of the list for your device. If it is listed, review your install procedure. If it is not listed, go here and look first for support for PC speakers ... http://insigniaproducts.com/products/home-audio.html
Then, if no success, send em a e-mail
Thanks for posting at FixYa.com
Dec 13, 2009 | Insignia 2.0 Notebook Speakers (2-Piece)
Durabrand 2.0 CH USB Speaker System
Try this, go to control panel and double click Sounds and Audio Devices. Then click advanced, under speaker settings and make sure your settings are desktop speakers. Also, in control panel, click Sound Effect Manager and do a speaker test. This should help.
Jan 20, 2009 | Audio Players & Recorders
2.0 CH USB Powered speaker System
yes.. in those types of speaker systems the usb is for just power.. and the "banana plug" is the audio jack.. there should be some kind of audio outpu on your computer .. it is usually located in the back near the middle or bottom.
Jan 09, 2009 | Durabrand DUR7 Portable DVD Player
My computer sound system
Most likely the sub has the crossover in it, most likely the 2 input cables from whatever device you want to play through the system will plug into the sub then the 2 speaker cables will come out of the sub and go to the speakers, just be sure to have everything connected into and out of the sub and make sure the power cords for the speakers and sub are plugged in, I am assuming this is a self powered system wich means the amplifiers are built into the speakers and sub.
Aug 07, 2008 | Yamaha 5.1-Ch. Surround Sound Home Theater...
No audio device detected
Ok when you plugged in the USB sound did it "see" it... did it ask for "Drivers" Because this device MUST have drivers.. also ya may have to disable any onboard sound device ya may have via the BIOS setup menu. Generally these USB sound devices are real easy to install and use.. try it on another PC to be sure it is OK.. GL
Jun 05, 2008 | Durabrand 5.1 Surround Sound Computer...
Speakers 2.0 durabrand not registering
Hope this helps :~)
Dec 31, 2007 | Audio Players & Recorders
Speakers won't work
Dec 27, 2007 | Audio Players & Recorders
26 people viewed this question
Top Durabrand Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Carlos L. Burgos
Carlos L. Burgos
SHARCNET-USA
SHARCNET-USA
Are you a Durabrand Audio Player and Recorder Expert? Answer questions, earn points and help others
