Question about Samsung YP-T8 Digital Media Player
Samsung MP3 512MB
The headphone jack seems to be loose, does not work. Is there a way it can be taken apart so I look to see if it is connected.
    President:
  • 3,130 Answers
Loose headset jacks are a very common thing and sometimes easy to fix. First thing make sure you know how to take apart the device as they all dont have screws as some units have snaps and you dont wanna break them. If you do get it apart, see if the solder connections are loose or broken. If you know how to solder then touch the solder iron with a bit of solder and let it flow only on the one tab. Next resolder the other two as there are usually three terminals. If the flex board or printed curcuit board seems to come off with it then your gonna need to run a small(26-28 gauge)wire from the jack connection to another part of the PCB thats along the same line as the terminal. If all this is a little frightning then take the unnit to a pro as this is a minor repair MOST of the time and should'nt cost much. Good Luck
Posted on May 05, 2006
How to use headphone? I entered the headphone socket but the sound is not come out the Head phone
MAKE SURE STATION IS ON AND VOLUME IS UP. CHECK FOR CRACK WIRING AND LOOSE CONNECTION AT BOTH ENDS. PLUG JACK FITS PROPERLY AND NOT LOOSE.
Aug 16, 2013 | Samsung I9100 Galaxy S2 Speaker Headphone...
Headphones broke off in jack
Sounds like it will have to be taken apart to be removed.
Aug 07, 2012 | Apple Ipod Touch 4th Gen 32 Gb, Nice...
I think I have broken my headphone jack on my sony vaio VGN-CS320J because headphones plugged into this jack do not work, unless held at a certain angle, otherwise sound continues to come from the laptop...
It might be the plug on the headphone that's bad - try it on another laptop. If it's the jack that's bad, then it will need to be taken apart and that's not easy to fix - recommend having a repair shop fix it.
Dec 24, 2010 | Sony VAIO VGN-CS320J/P Notebook
Left side is quieter than right side and when pushed on makes crackling noises and sound gets louder
most likely cable is very loosely contacting the jack or earpad. Will need to be taken apart and soldered.
Nov 13, 2010 | Pioneer HDJ-1000 Professional Headphones
Bad connection?
sounds from the description that one connection on the jack is either loose or the connection in ear is faulty if the jack can be taken apart you could try and resolder or the earpieace could be done the same.
Aug 11, 2009 | V-Moda Vibe Headphones
Loose headphone jack
if there isn't screws to take the MP3 player apart then their are clips on the inside
Unscrew the screws (or if you have clips from the on/off switch use a screw driver to open it. this isn't the most safest way to open it i could break so this is a last opption.)
ussing a sodering iron resoder the conection between the loose headphone jack and the curcit board.
(you can pick up a sodering iron at Radio shack for as low as 10$)
Oct 19, 2008 | Samsung Yepp YP-P2 Digital Media Player
Mp3 player repair
I just took mine apart using this: http://www.anythingbutipod.com/archives/2006/11/sandisk-sansa-c200-disassembled.php
If this doesn't work for yours, I suggest using the model name/# with "disassemble" or even "take apart" as search terms in Google.
Sep 10, 2008 | Audio Players & Recorders
Short in headphone jack?
your headphone jack is loose if you take it apart and solder it back it will work fine.
Jan 17, 2008 | Samsung Yepp YP-T7JZ MP3 Player
Headphone issue on Zen Micro.
you have a loose connection on your headphone jack, need to solder the jack back in place.
Dec 07, 2007 | Creative Labs Zen Micro MP3 Player
Headphone jack
Try cleaning out the headphone jack with a Q-tip and a very small amount of glass cleaner or rubbing alcohol. That seemed to work for me.
Sep 21, 2007 | Samsung YP-T8 Digital Media Player
Samsung YP-T8 Digital Media Player Logo
78 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
