Hi there, My 50 watt MG series marshall amp keeps making a loud rattling sound when its turned up loud. Any ideas why this is and how i could fix it? Ashley Fields e-mail: ashley_ibanez@yahoo.co.uk
  • 4,234 Answers
You need to determine whether the amp is creating the sound or the speaker itself has a problem. based upon your description, I think that the speaker is blown. The voice coil probably has come loose from its form. Try using the speaker out jack to connect the amp to another speaker. If that sounds good, the problem is the speaker itself.
Dan
Posted on Sep 12, 2008
  • 682 Answers
Bring spray contact cleaner from radio shack near you and clean volume control for amp while you are moving it forward and backward---do not put your mic in front of your speakers because this will give you more trouble.
Hi i have the Marshall MG15FXMSDM Dave Mustaine Megastack and i also have the programmable footswitch. the other day, i was plugged into a big surge protector and the footswitch was working fine. i...
First thing is to verify the MAIN power source is getting to the amp. It may not be the fault of the footswitch at all. Connectors and cables are the usual cause of these problems. Seating of connectors is a common problem...
Mar 02, 2011 | Marshall Amplification Marshall MG Series...
Ihave a marshell dfx 100 guitar amp...as i play it the volume lowers and will eventully fade to nothing... any ideas..
For a test in troubleshooting, see if level from the headphone jack fades or not when this happens and get back to us.
Sep 02, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
Hi i am john... i have a 100dfx mg series... it is
There are MANY more likely components than the transformer that will cause the fuse to blow.
Most common are filter capacitors, rectifier diodes, and shorted components in the power amp section.
Transformer failure is very UN-likely. Have a competent electronic tech troubleshoot the unit.
When testing the unit, put a 150 watt light bulb in series with the power line... saves fuses during troubleshooting. This limits the current so one can analyze the real cause of the problem.
Jul 12, 2010 | Marshall Mg100dfx 100-Watt Combo Guitar...
By mistake i plugged the speaker jacks from another amp into the speaker jack on my mg 50. i was trying to test the other anp with the speaker on the marshall but i did it wrong. i didnt turn the marshal...
If you connected an external speaker plug from one into the same type plug on another amp, you have driven signals backward into the amp that was off... NOT into the speaker in that unit.
The usual result is blown parts in the amp that is off.
Some amps have their own speaker cable that you can unplug to connect to another amp and that is fairly safe. NEVER run an amp without a speaker load on it.
Feb 20, 2010 | Marshall Mg50dfx 50-Watt Combo Guitar...
Hi,I turned on my Marshall mg series 100 dfx and there is no sound,just static comes on.Its starts with a kinda bad feedback sound than turns to loud static.
I suspect the power supply for the effects processor has failed. The effects unit will "go crazy" when power supply is too low voltage.
If the amp has loud noise, then the power amp portion is PROBABLY OK.
I had a similar problem in a Behringer amp caused by a bad electrolytic filter cap.
Aug 11, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Mg 50dx no sound
Contact Marshall on the web or try a search for exactly what you need, most companies will help you with there products no matter how old they are .
Mar 01, 2009 | Marshall Mg50dfx 50-Watt Combo Guitar...
Guitar amplifier
Hi thecross
I have fixed so many of these amps over the years... Marshall Valvestate series of amps are notorious for dry solder joints developing on the main PCB. If you have the skills(or an old mate that does)Remove the PCB from the chassis and resolder any suspect dry joints and you will fix the problem. Check particularly about any components there the PB has changed colour. This is an indication of heat in that area, and heating and cooling is a major cause dry joints.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Jun 16, 2008 | Audio Players & Recorders
71 people viewed this question
 Grubhead
Grubhead
