Question about Technics SL-1210 Turntable
Poor low frequency
Hi there, one of my dek does not give me full low frequency, i have replaced the lead+connectors, aswell as tonearm,and still nothing as changed, when i unplugged on of the leads connector from the mixer, then the low frequency are coming back but plays in either speaker accordingly, but only mediums and high frequency will be played when plugged back on, is it the printed circuit board or else???????
  • 515 Answers
Nope, the circuit boards have nothing to do with transmitting frequencies. There are only 4 items on the Technics 1200 that transmit frequencies...
1) Stylus/Needle
2) Cartridge
3) Tonearm
4) RCA Cables/Leads
If you've already replaced 3 and 4, the problem lies with either 1 or 2. Or the RCA cables you replaced were not done properly, or you used poor quality cables. Double check the work.
- OPTiC.
Digital Analog Therapy
www.djprolab.com
www.1200s.com
Posted on Nov 04, 2008
Marantz 530 skips after playing only 30 seconds the tone arm won't progress. It consistently stops (skips) regardless of whatever album at the same place
Make sure that the wires leading from the tone arm are not binding. And you might also want to check for bearing friction in the tone arm. Under light stylus pressure conditions, low friction is mandatory.
Mar 22, 2015 | Marantz Audio Players & Recorders
After an album side is finished, my Thorens TD 185 turntable disc refuses to stop spinning.
Some turntables do not return the arm to the rest. However if it did so previous then something could have broken or become out of place underneath the turntable. The only way to check is look under the turntable by removing the base and looking for signs of damage.
Aug 19, 2013 | Thorens TD 185 Turntable
My headshell will no longer lock onto the tonearm locking nut both my headshells lock on my other turntable. Does this mean i have to replace the tonearm
Hi, there is no need to replace the entire tonearm. I can supply you with the very end part which is held in by two screws. Styluscity@gmail.com. John
Mar 26, 2011 | Technics SL-1200MK2 Turntable
Technics SL-1210Mk2 Sound is very clear but low frequencies are very POOR.Other sources are checked i think the problem comes from the turntable. I replace my old phono pre amp with rolls VP29 and i check...
Possible that the negative feedback amplification is not compensating to the preamp.
The cartridges must match with the preamp so that the full frequency response is received.
If you can add along an equaliser to you phono path on way to the amplifier , the compensation can be set up to the room accoustics and taste.
Alteration of the input impedance to the amplifier with a network can also help but an equaliser might be tthe best for you
Sep 15, 2010 | Technics Audio Players & Recorders
I replaced the stylus with needle and now when i try to play a record, it makes a terrible crackling noise and the record sounds completely blown out. just bought a new tuner preamp too, so its probably...
Unplug everthing. Reseat all connectors, Did you replace the cartridge when you replaced the stylus? If so, verify that the 4 tiny tiny wires and connectors are on tight. Also, some of these turntables have a 'knob' built into the tonearm that you need to twist to release/lock the whole head assembly of the tone arm. Try to see if you have a removable tonearm cartridge assembly and then twist this tight. It sound like its in the wiring from the cartridge to the connectors to your preamp. The levels are so low, that any loose connection will be amplified 100 times.
Aug 10, 2010 | Sony PS-LX300USB Turntable
I have only one side of the signal coming through from the deck
More than likely either your RCA cables need to be replaced, or the tonearm is damaged. Do you use Ortofon Concorde cartridges by any chance? If so, the tonearm could be faulty, or the connection from your cartridge to your tonearm might be loose. Just tighten the nut a little bit more.
If you use different cartridges, then the issue is probably your RCA cables and need to be replaced.
IN either case, professional assistance is highly recommended.
- OPTiC
Turntable Repair Expert
A DJ PRO AUDIO Co.
Nov 23, 2008 | Technics SL-1210 Turntable
Turntable skips during playback
The only thing I can say is to make sure you set up your cartridges correctly - click HERE FOR INSTRUCTIONS on BALANCING YOUR TONEARM properly.
If, you've balanced your tonearm, and set up your cartridges correctly, then you should not have any problems. Unless, your tonearms are damaged. But this is highly unlikely. I just think you need to balance properly.
Another note, Ortofon Concorde have a design flaw, in that they don't connect very well to the Technics tonearm. The Concorde's, have short and stubby connections on the rear, making for poor connections to the tonearm. Ortofon has addressed this issue by releasing the Ortofon OM series cartridges, and mount them to standard Technics Headshell.
If you still can't figure this out, feel free to give our techs a call 24/7 @ 1.866.668.1596 ext 1 - they can walk you through setting up, and properly testing your tonearm to see if it's damaged or not.
- DJ PRO LAB
www.DJPROLAB.com
May 12, 2008 | Technics SL-1200MK2 Turntable
Technics Sl-1210 MK2 GOES MONO
Check to make sure you have a nice solid connection on your tonearm from your cartridge. The problem is either your tonearm or your RCA (red/white) cables.
Neither are easy repairs, unless you have soldering skills/experience. The tonearm replacement is the more difficult and more costly of the two.
Parts for the unit can be purchased HERE. If you have any questions about testing your unit on the exact cause, please feel free to give our TECHS a call - they are available 24/7 for your convenience @ 1.866.668.1596 ext 1
- DJ PRO LAB
www.DJPROLAB.com
May 08, 2008 | Technics SL-1210 Turntable
Single sided sound from my RCA/Phono leads
If you are certain the new leads/RCA cables and the soldering work was done properly, and you've determined that the issue is from the turntable and not your mixer.
Then there are 2 other factors that could be causing this issue:
1) Bad Tonearm - look inside the tonearm, where the cartridge/headshell mounts. You'll see 4 prongs. Make sure those prongs are protruding and they all look even. They must also be a nice shiny brass color. If they are dull and/or black, try cleaning them out with an contact cleaner (CAIG Lab DE-OXIT works good) made for electronic components. If any of the prongs appear to be pressed in, try to see if you can get it to bounce back. Those prongs are spring loaded, and sometimes the springs get misaligned. Of course, they also tend to dislodge. If that's the case, then you will need to replace the tonearm altogether.
2) Faulty Cartridge / Headshell - Make sure your cartridge & headshell work properly. The easiest way to do this, is to swap your cartridge with a working one. If you have 2 turntables, just swap them out, and see if that changes anything.
I am going to say, it's more than likely a tonearm issue. There really isn't anything else, other than the Tonearm and RCA's which would cause sound issues. The Circuit board will not affect your sound, unless you burned it, or damaged it in some other fashion when replacing the RCA cables.
As for a Service Center in the UK, not sure of any, but you can contact Panasonic, which is the parent company of Technics - www.panasonic.co.uk - go to the Support Section for a list of auth service centers in your area.
- TWEAK AV LAB
The ORIGINAL TURNTABLE Technicians
Nov 30, 2007 | Technics SL-1210 Turntable
Sound cuts out on one side when playing record i have checked the rca connectors they seem to be fine
The issue will mostly likely be the tonearm, rca's and/or the rca leads.
Reverse the connections on the mixer to eliminate the input rca's on the mixer and isolate the channel at fault.
Reseat the headshell/cartridge assembly.
Replace the stylus.
If after these 3 steps, the issue persists, then it is actually is an internal issue, and the RCA's and/or tonearm may need to be replaced.
Check it..
http://www.djproaudio.com/cgi-bin/Help/kb.cgi?do=read&id=17&lang=en
Nov 02, 2007 | Technics SL-1200MK2 Turntable
Technics SL-1210 Turntable Logo
79 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
