Question about Canon EOS 400D / Rebel XTi Digital Camera
Flash not firing properly
I have an canon rebel xti camera. when i use on auto mode or even manual mode, the pop up flash which is supposed to be i-ttl doesnt fire an evalutive burst to analyse the lighting condition- hence the pictures appear underexposed.
What is the problem and solution to the same.
sometimes when i keep my hand in front of the lens and half press the shutter button- it gives an evaluative burst of flash
  • 23 Answers
Could be the metering mode you are in. Could be the subject is too far away. Could be ISO is set wrong. Could be the lens aperture can't open up enough. Could be the exposure compensation isn't set correctly. Could be FE Lock is still on and the composition has changed. Does the <flash> icon continue to blink? Then you are too far away.
Posted on Dec 06, 2008
Canon rebel xti flash pops up but says it was obstructed
This is a problem known by Canon, you will have to have it serviced.
Oct 30, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I recently bought a used canon EOS 400d which was
Be aware that the built in flash does not pop up automatically in all picture modes. Try it when in the different modes (on the mode dial) and see what I mean. Does it popo up when manually opened ?, (small button on front left hand side of the viewing pentaprism/flash housing.)
Oct 02, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
The built-in flash on the Canon Rebel XTI won't flash.
i am having the same problom try this i just found this ... http://www.fixya.com/support/t1021194-flash_not_working
Aug 20, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
I just bought the 430ex II flash and it won't fire on my Rebel XTI.... i read the manual but I'm not sure whats wrong, have any advice?
I assume that flash is turned on. 430ex flash will fire automatically only in AUTO mode. On manual modes you mus manually force the flash to fire.
If flash doesn't fire at all, consider to claim the vendor or let the vendor to check the flash mounted on your camera.
Aug 04, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
EOS Rebel XTi 400D flash not popping up
Flash will automatically pop out only in AUTO mode, if the camera needs some additional lightning. In manual modes, you should use the flash button located at the left down side of the flash compartment, to manually force the flash to pop up
Jul 13, 2009 | Canon EOS 400D / Rebel XTi Digital Camera
Built-in flash does not work
DO NOT MESS with a new camera (or any other new equipment).
Take/send it back to the vendor, The purchaser has rights also. Number one it must work.
I don't know your location but in UK (& Europe) we have very strict consumer legislation.
Mar 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
My camera can't flash My flash pops up but does not go off.
The camera will determine whether the flash will be used in auto even if it is up it may not go off.
TRY THIS:
Put it in "P" (program) mode. Then hit the flash button the the left side of the camera so it pops up. This manually turns on the flash. This will tell you right away if its broke.
Mar 04, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Pop-Up flash - Rebel xti
You will need to send the camera for servicing. There's a lever mechanism inside the flash unit which is responsible for popping up the flash. Since it is a mechanical device, it is sometimes prone to failure. I suggest not to put manual pressure to force the flash to come out, as it may cause permanent damage. Instead, send the camera for service.
Dec 30, 2007 | Canon Rebel XT / EOS 350D Digital Camera
How to switch on Auto Flash in Auto mode
Put the camera in "P" and press the flash button above the lens release. If the flash pops, than you probably just have too much light to need it when you are in auto. The flash button is not active in auto so if the xti doesn't want the flash in auto, u can't make it fire. If the flash button does not make the flash pop in "P", search this site for another post about flash not working and u will find that this could be the flash deactivation button in the hot shoe sticking. Not likely though with a new camera unless u have had a speedlite mounted alot.--
I found the answer and fixed my flash. Look on http://photo.net/bboard/q-and-a-fetch-msg?msg_id=00ODWf
This will describe how, if you have been using a speedlite alot, than the little tab under the shutter release side of the hot shoe can get bent down thus constantly pressing down (toward the bottom of the camera) the small button which deactivates the pop-up1.gif flash even when the speedlite is not attached. Just bend the tab up a little with a jewler's screwdriver, turn the camera off and on and voila!! Fixed!!! Dan describes pushing the tab down, but on the xti, the tab needs to be bent up to release the flash deactivation switch and fix the problem. Thanks to Dan D on photonet for saving me a service call.
Dec 26, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Flash override
You can use the camera in the P,Tv,Av, or M modes without the flash popping up or firing. P would be the easiest to use.
Oct 18, 2007 | Canon EOS Rebel G-II 35mm SLR Camera
Canon EOS 400D / Rebel XTi Digital Camera Logo
198 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
