This is from page 19 of the Simon3 manual found here:
http://www.safemart.com/manuals/simon3.pdfIt appears you have the "CHIME on Motion" enabled. Follow the Option 41 steps to disable it.
Option 41 - Voice Chime
The panel will verbally announce which chime sensor has been tripped if the chime
feature is on.
Add enables chime voice.
1. Open panel cover. Panel announces, Use numbered keys to enter ID.
2. Enter Access Code using the numbered keys. Panel announces, Please select from
Start Menu.
3. Press Add from the Start menu. Panel announces, Select from main menu
4. Press Option #. Panel announces, Option 1, press again for next option or done to
select.
5. Press 41. Panel announces, Option 41, press again for next option or done to
select
6. Press DONE. Panel announces, Option 41 is on.
Delete disables chime voice. The panel will not announce which chime sensor has
been tripped but will still chime 2 times for doors and 3 times for motion sensors when
a given sensor is tripped.
Start Menu.
3. Press Delete from the Start menu. Panel announces, Select from main menu
select.
delete
6. Press DONE. Panel announces, Option 41 deleted.
