Question about Intel Motherboard
REPAIR BOOT PROBLEM, KEYBOARD AND MOUSE IS DISABLE. SCREEN READ PRIMARY IDE NO 80 CONDUCTOR CABLE INSTALLED.
    Scholar:
  • 45 Answers
Hello Benjamin2663,
Your error could be several things, but here is what to do to make it work....Listed in order so do them and then see if you get the error and if you do then do the next fix....
FIRST:
Load the set up defaults in the BIOS Setup. This may get it all to work.
SECOND:
Use an 80-conductor cable connected in the Primary IDE socket on the motherboard with the other end connected to the hard disk. You see you may be using an old type of cable and/or it may be connected to the secondary IDE channel. Installing the right cable in right socket will solve your problem.
THIRD:
Double check your cables and jumper settings. As long as you have confirmed them to be in their
correct positions, you go straight to the BIOS and enable Smart Drive capability for your hard drive.
Set all your drives to be Auto detected and reboot the PC.
IF the message and problem still appear you must now go to Device Manager and go to System. Open Systems and go to IDE ATA/ATAPI Controllers, and you will now see primary and secondary channels. Click on the primary channel first and open the properties box.
Next go to the advanced settings and make sure the transfer modes on device 0 and device 1 are set to DMA if available. Do the same for the secondary channel as well and allow the PC to reboot.
If all that fails, go and have your motherboard checked out for faults.
Hope this help you.
Posted on Sep 12, 2008
How to install 80 conductor cable? because when i turn on my computer it displays no 80 conductor cable installed
It means you're still using the 40 conductor cable from the MB IDE to the
hard drive. The 80 Conductor Cables are used to take advantage of the newer
Ultra/ATA-66 and up IDE drives. (They will still work with the 40
conductor cable, but slower.)
Jun 01, 2010 | Microsoft Computers & Internet
Tip
How to replace a hard disk drive.
Step 1: Back up and scout around
First, back up your critical files (don't forget your Outlook .PST archive) to optical discs, an external drive, or online storage. Then check whether a CD comes with the drive, providing drive-specific information and general upgrade assistance. It may also later help you copy the contents of one drive to another. Install this software first. Then, power down your PC, unplug all cables, and open the case. Next, ground yourself by touching a metal portion of the chassis.
Look inside—your first task is to determine where your new drive will go. Bays for internal drives are usually located below the wider, front-accessible bays that house CD or DVD drives. If you plan to replace your boot drive with the new drive and don't have an empty bay, your upgrade will involve more steps than we can cover here. But if you're replacing your boot drive and you have an empty bay, follow our steps for adding a second drive. After formatting it, use Norton Ghost (or a similar program) to clone your boot drive's contents to the new drive. Then, revisit steps 3 and 4 to direct your PC to boot from the new drive.
We'll be installing a SATA drive, but the process is similar for the other common drive type, IDE. SATA drives use a thin, seven-pin data cable; IDE drives use a 40-pin ribbon cable that's usually gray. If you're unsure which drive type your PC already has, check its documentation or label. Most PCs more than a year or two old employ IDE hard and optical drives, and don't support SATA unless they have a SATA PCI card installed. More-recent desktops may use (or just support) SATA drives but should support IDE, too.
Tip: If you transfer Windows XP from one drive to another, you may have to reauthorize Windows. Step 2: Examine data and power connections
Most hard drive kits include a data cable (SATA or IDE, depending on the drive), a power adapter cable (with some SATA drives), and screws. If yours doesn't include cables, you can purchase them separately.
First, the data connection. If you're installing a SATA drive as secondary storage, follow the data cable from your current drive (assuming it's SATA, too) to the other end. See if an unused SATA port lies nearby on the motherboard or an interface card. If you can't find one, consult your PC's documentation.
If you're adding an IDE drive as a second drive, you may be able to connect it to the same data cable as your primary IDE drive, or along with an IDE optical drive. Look for a third, free connector in the middle of the cable that connects your currently installed IDE drive to the motherboard. Note that some older PCs use 40-conductor IDE cables, not the 80-conductor ones current drives require. (Compare your kit cable to the one installed—the 80-conductor variety has much thinner wires.) 80-conductor cables are backward-compatible (both types use the same 40-pin connector), so you can swap out a 40-conductor cable for your kit's 80 if need be. (The "master" drive goes at the end—see step 3.)
Next, consider the power connection. Our SATA drive has a 15-pin SATA power connector. If you already have a SATA drive installed, follow its power cable (the wider of the two connectors) to see if an unused power-supply lead with the same connector is nearby. If so, earmark that lead for your new drive. If it can't reach the empty bay, see if any bundled adapters help.
Some SATA drives also support familiar legacy Molex four-pin power connectors—you can use a Molex or SATA connector. If so, hunt for a free Molex-style lead. Still no match? Then you'll need an adapter, such as a Molex-to-SATA adapter (some kits bundle one), or a Y-adapter that splits a lead in two.
IDE drives are simpler: They always use Molex connectors. You just need a free Molex-style lead (or a Y-splitter). Step 3: Mount and connect the drive
When installing SATA drives, jumper settings usually aren't an issue. That's not true of IDE, where a jumper indicates whether a drive is a primary ("master") or secondary ("slave") drive. Check its documentation for the proper setting. If your PC has only one IDE hard drive, it's probably set to "master." Assuming you chain another IDE drive off its cable, the new drive should be set to "slave." (You'll later have to change the jumper to "master"—and attach the drive to the cable's end—if you remove the original boot drive and make the new drive the boot drive.) Another option: Set both IDE drives on an 80-conductor cable to the Cable Select (CSEL) jumper setting. The PC will determine master/slave status according to the drives' placement on the cable ("master" at the end, "slave" in the middle).
Next, look at your current hard drive to see if mounting rails are attached to its sides. If so, screw a set onto the new drive (look inside the case for spares), then slide the drive into its bay. Otherwise, screw it directly into the bay. Four screws are sufficient. Usually, the label side points up; mimic the boot drive.
Attach one end of the SATA data cable (which is keyed for correct insertion) to a SATA port on the motherboard or interface card, the other to the drive. IDE data cables, also keyed, usually have a red stripe that lines up with the "pin 1" marking on the drive.
Next, plug the power-supply lead (keyed, too) that you scouted out in step 2 into the drive, including any necessary extender or adapter. Then close the case. Step 4: Configure the BIOS
Next, boot into your PC's BIOS-setup utility to verify that it recognizes the new drive and positions it correctly in the drive hierarchy. (Check your PC's startup screen to determine which key launches the utility.) Once there, also check that "auto-detect" is selected for the drives, if an option. If the utility lets you select the boot order, give your intended boot drive priority over any other hard drive. This information may be under Boot Options, Boot Order, or Boot Sequence.
Save changes and exit the utility. Your PC will reboot.
Tip: Using a SATA PCI interface card? It may have its own BIOS to check. Step 5: Partition and format your hard drive
Our PC runs Windows XP, which lets you partition and format drives within Windows. Older Windows versions, such as 98 and Me, make you do this from DOS.
With XP and 2000, though, use Windows' Disk Management utility. Click Start > Control Panel > Administrative Tools > Computer Management, and choose Disk Management from the tree at left. Your new drive should appear, with a black bar indicating it isn't partitioned. Right-click the bar, and choose New Partition to launch the New Partition wizard.
Click Next, and check that Primary Partition is selected; click Next again, to the Specify Partition Size screen (don't change the partition size in the "Partition size in MB" field); and click Next to advance to another screen, on which "Assign the following drive letter" should be selected. Click Next yet again (to the Format Partition screen), and ensure that "Format this partition with the following settings" is selected and that the "File system" drop-down reads "NTFS." Click Next a final time, hit Finish, and formatting begins.
Formatting could take an hour or more, depending on drive capacity. But don't be surprised if your formatted drive has less capacity than the package claims. A 320GB drive, for instance, formats to about 300GB. Drive manufacturers advertise preformatted size, but a portion of the drive is inaccessible.
on Jul 21, 2010 | Computers & Internet
Installation of a 2nd hard drive steps & tips
Dec 27, 2009 | HP Pavilion a1410n (ER890AA) PC Desktop
Whats the difference between a a 40 conductor and a 80 conductor on a ide cable
80 conductor IDE wires are designed to reduce interference and other signaling problems associated with higher-speed transfers.
Nov 17, 2009 | Computers & Internet
CAN'T START UP COMPUTER DETECTS NO MOUSE OR KEYBOARD
The Blue Screen Your Are Talking About Its UNMOUNTABLE BOOT VOLUME and in case of blue screen mouse and keyboard are not detected as WINDOWS are not loading....
There Are 3 Ways To Resolve It But For All 3 Methods We Need The MICROSOFT WINDOWS XP OPERATING SYSTEM DISK...
1st Method Is WINDOWS RE-INSTALLATION. But In This Case All Your Data Would Be Gone..
2nd Method Is WINDOWS PARALLEL RE-INSTALLATION and in this method your data would be saved but you need to install the DRIVER'S SOFTWARE'S and other APPLICATIONS.
3rd Method Is The Easiest And I Prefer Which Is To Repair The Booting Sector.
To repair the volume, follow these steps: (10-15 Minutes)
  1. Start your computer by inserting the Windows startup disks or the MICROSOFT WINDOWS XP OPERATING SYSTEM DISK if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /p, and then press ENTER.
  6. It will ask u to overwrite the boot sector so press Y and overwrite the boot sector.
  7. type FIXBOOT and hit enter.
  8. When Everything Is done and new boot sector has been written successfully... type EXIT.
  9. Take Out Windows Disk and Restart Your System..
Some things that you should know before you try this solution loadTOCNode(4, 'resolution');
  • If the file system is damaged, you can use chkdsk /r command to repair the volume. However, if you use the chkdsk /r command, you may lose some data.
  • You will need the Windows startup disks or the Windows installation disk. If you do not have them, contact the computer manufacturer for help in obtaining the disks.
  • You will need the administrator password to complete the steps.
To repair the volume, follow these steps: 40-45 Minutes Complete File Repair
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r in step 5.
Rate This Sollution Accordingly.........
May 22, 2009 | Computers & Internet
Unable to install RHEL5 in D101GGC
http://www.linux.iastate.edu/rhel5/...READ THIS IT WILL SOLVE THE PROBLEM.RICHARDM69
Nov 07, 2008 | Intel D101GGC Motherboard
MS 6712 motherboard
check the cables, and if all connection pins are on the drives or on the motherboard. Not all the needed communication routs between the drives and the motherboard are working....
U can also try another IDE slot (if more than 1)
If all checks ok, try a BIOS reset... (but most probably is just the cables ...)
Jan 20, 2008 | Intel Motherboard
MSI P4MAM2-V BIOS
Check your Ide data cable it seems 40 pin conductor cable .
Replace them with 80 pin conductor cable.your problen\m has gone.
Oct 13, 2007 | MSI P4MAM2-V Motherboard
Hard Disk and Booting issue
go into your BIOS and on the bottom of your screen there should be a (last good config) of (fail-safe config) value for one or=f the F1 to F12 buttons. also. are you running a 4gb hdd??? or is that a typo? anyhow, XP REQUIRES 2GB at all times free if your hdd is running at less that that (cause its full) your boot up could be messed around. finally make sure that the little plug on your hdd is across the Master or cable select pins not the slave as this can cause probs too. good luck.
Sep 22, 2007 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
ATA133 refusing to be accepted
Obviously mobo error, have you tried re setting bios from 'JBAT1' terminal, jumper from pins 1-2 to pins 2-3 then back on 1-2. Start up again and set time and select the auto detect HDD in standard bios settings see if correctly identified. save settings and restart pc
Jan 15, 2007 | Samsung SpinPoint P80 SP1604N 160 GB Hard...
Intel Motherboard Logo
421 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
