Question about Fuji FinePix A310 Digital Camera
Finepix A310 MY CAMERA'S LCD SCREEN IS ALL GREEN AND WHITE LINES, THE CAMERA WASN'T DAMAGED AND WORKED PERFECTLY THREE WEEKS AGO. PHOTOS ARE GREEN AND PINK AND ONLY VAGUE OUTLINES OF PICTURES ARE VISABLE.
  • 3 more comments
  • Anonymous Nov 05, 2007
    all was ok had a few snaps on disc but when switching on then the problem started when the camera started up and the screen came up all I can see is aa mishmas of mouve colours and white, its seeing the objects and will record them just the same, but picture is same as screen problem.
    Any help
    Please
    NORMAN
    HI. I HAVE THE SAME PROBLEM WITH THE SCREEN LOOKING ALL GREEN AND WHITE. I HAVENT USED THE CAMERA MUCH SO I AM DISSAPOINTED IN THE CAMARA AND WONT BE BUYING A NEW ONE.
  • gwood6 Nov 20, 2007
    Get the white fuzzy picture in the video mode also
  • Anonymous Nov 23, 2007
    my camera screen is working fine and suddenly after 10 min when i start again to take some pic the screen was pink and white
    give some solution please
  • Anonymous Mar 27, 2014
    You can see that the photo is not being lined up and started again properly when the printer is in process.
    President:
  • 3,130 Answers
Dose the video out look the same as if it does then you have a faulty ccd processor or lcd itself is bad. It may be time for a new camera.
Posted on May 05, 2006
SOURCE:
Get the blue and white lines of my screen
you can go to the service center may be your display is not working properly
Sep 13, 2013 | Fujifilm Finepix Hs30exr black Digital...
Image purple in viewer. Photo reproduction green on screen.
Go into the setup menu and scroll to "reset" and follow the on-screen instructions.
Sep 22, 2009 | Fuji FinePix A310 Digital Camera
FinePix S5700 LCD Screen Problem
you need to send it to fujifilm for repair. i dont think its too expensive at all. this is a common problem with many cameras
Apr 14, 2017 | Fuji FinePix S5700 Digital Camera
Lcd screen problem
HI, this is isolated within the LCD screen. the input ribbon may be defective or, the entire screen could also be damaged. you will have to replace the lcd screen in this case due to the integrated design. you can confirm my diagnosis by, pulling the battery or plug for 5 minutes. if this screen is still not operating normally after you re insert the battery, this will confirm LCD screen failure.
May 24, 2009 | Fuji FinePix S5700 Digital Camera
CANT TAKE A PHOTO
Your CCD-chip is failing.
No spares for DIY available from Fuji.
Jan 19, 2009 | Fuji FinePix S5000 Digital Camera
Damaged lcd screen
D&H Cameras in Chicago can supply the part or fit it for you. See item 320257883455 on eBay. $54.99 plus postage to wherever you are.
Aug 05, 2008 | Fuji FinePix Z10fd Digital Camera
LCD screen white.
it is a good point to buy a new one,because the replacing of the lcd screen costs more than the camera..
so..its better to buy a new one.
bye and thanks for rating this
Feb 04, 2008 | Fuji FinePix Z5fd Digital Camera
Blurred Images/ Photos
Check out the Fiji Tech support team. Depending on the age of the camera there may be a swap out option. Independent repair will not be an economic prop.
Jul 04, 2007 | Fuji FinePix F450 Digital Camera
White Screen
I have Fuji FinePix 2650 Digital camera with same problem. I can almost guarantee this is not a firmware problem. I went mountain biking a few months ago and take pictures. I take out camera and turn on. I get lines then white screen. I banged on camera and fixed it. Later a few weeks ago I turn it on and white screen. i beat this thing and get bad menu selection screen for a moment then white again. It takes pictures well and talk to computer no problem but no LCD picture. I thinking it is loose connection for LCD. Send it for repair or if you seek adventure try to fix it yourself!
Nov 12, 2006 | Fuji FinePix S5000 Digital Camera
Finepix A310
It could be the CCD, fuji has admited a few of their models have the faulty CCDs and there is a list of serial numbers you can look and see if yours is in the list. You may want to call them and see what they say. Ide try and call a few different times if they say it isnt, try again later and see if you can talk to a different opperator. Some may or may not know so dont just take the first pesons word for it if they say no. If you bang on the side of the cammera does it work ok again? usualy if its the CCD problem a bang on the side of the camera fairly hard is enough of a shock to cause it to work again.
May 04, 2006 | Fuji FinePix A310 Digital Camera
Fuji FinePix A310 Digital Camera Logo
150 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Azam Ali
Level 1 Expert
KJ Soni
Level 1 Expert
Are you a Fuji Camera Expert? Answer questions, earn points and help others
