Question about Epson Stylus Photo RX600 All-In-One InkJet Printer
Can't seem to print in black only.
Does anyone know how to print using this printer when the color cartridges have run out of ink? I am getting a message on the LCD that says the ink is low and to replace the ink cartridges. The black ink is brand new and I should be able to print in black only. The message doesn't go away even if I remove the empty ink cartridges. Since this is an "All In One" it is even preventing me from using the scanner. Would they really make a printer that forces you to buy more ink (about $80) before you could scan anything. Any help would be great.
  • 6 more comments
  • yupatsame Feb 17, 2008
    My forte is text printing......not interested in color, but no printer is marketed as black text printing only. I will accept removing the color cartridges and just using the black one in my Canon mp510 3 in 1, if it is at all possible. Come on, you fix it wizards!!!
    Yupatsame
  • Anonymous Mar 20, 2008
    same problem
  • Anonymous Apr 08, 2008
    Mine the same
  • Terence Hamer May 30, 2008
    I never print in colour but when just one colour cartridge registered empty I had to replace it so I could carry on printing in Black only. A short time after, the same thing happened with all the other colour cartridges. I replaced them all and used Black only printing. After I used only two more Black cartridges all the colour cartridges showed empty so its asking me to buy and replace them again. This is ridicules and to costly to keep having to keep changing colour cartridges when your not even printing in colour. I have had to buy more colour cartridges than the black ones I use. Sorry EPSON you have got something wrong with your printers. My daughter has a very cheap printer and this does not happen to hers. Its about time we where able to buy a black print only print. I'm taking my Epsom to the local tip.
  • Anonymous Aug 26, 2008
    Same here. It sucks. All I want is a simple document...not pictures. Even though my black ink is full and one color is out, it won't print.
  • eddiedavies Nov 25, 2008
    canon i950 runs out of 1 colour ink then i have to replace it before i can print anything again, iI ONLY WANT TO PRINT BLACK. wont print even if black aqnd white printing only is selected. please help someone.
  • Anonymous Nov 27, 2008
    same exact problem... i'll never invest in an epson printer again.
  • Anonymous Mar 19, 2014
    I'm trying to replace my ink cartridges but I get an error message saying the scanner is open.
  • 64 Answers
Are ya sure it isn't only preventing scanning direct to printer output? Is it also disallowing scanning to file? Epson printers can´t operate if one of the cartridges is empty. There is no workaround for that. Epson printers actually use a LITTLE ink from ALL the color carts, even when you select "black only" in the driver. They do this to help keep the nozzles from clogging in the case of users who mostly print in black. Nobody [besides perhaps Epson] ever claimed Epson printers were the most efficient or environmentally-friendly ones in the world. for quite a while now Epson uses piezoelectric printheads, as opposed to the thermal heads used on most other printers. The enemy of piezo heads is air bubbles. They candamage the costly head, and that's why you cannot continue to use the printer if ANY individual cartridge runs out of ink. In fact, Epson designed its cartridges to signal "empty" when there's still around 15% (higher by some estimates) ink left! That's to make certain you can't run the cart completely dry and thereby introduce air into the head. If you don't believe that, carefully open up a spent cartridge over a sink, slice open the plastic film covering the various ink channels and rinse it out -- repeatedly push in the spring loaded outlet valve as well. There's so much ink left, it will take quite a while before the water begins to clear! It's incredibly wasteful and annoying, but it actually saves money in the long run, because it's even MORE wasteful to run tons of cleaning cycles just to purge the head once you've gotten air in the system. Aftermarket carts and ink can save lots of money, but they're a crap shoot. Fed up with OEM price gouging and scare tactics, I decided to try a clear-cartridge refill kit for my R200. The RX600 uses the same kit: http://www.inkjetcarts.us/servlet/Detail?no=8 Good Luck!
Posted on May 08, 2006
Never buying an epson again.
Posted on Nov 17, 2009
This is absolutely ludicrous. It has just happened to me. I had a Lexmark before and never encountered this problem I could print for month with just black. Epson , never again. And the cartridges are astronomical!
Posted on Jan 14, 2010
Summer 2010. Will not walk by an epson. Ever.
Posted on Jul 16, 2010
    New Friend:
Epson why !!!!!!!
Posted on Feb 12, 2013
Yea I have the same problem and I just want to say FU*K YOU EPSON
Posted on Oct 30, 2008
We have Canon iP4200 printer and same problem! Makes me wish that I still had my old Canon BJ-200, black only printer. Does anyone still make a simple black only printer?
Posted on Aug 27, 2008
No more Epson printers for me. This is bad business. See ya later Epson. HP does the same thing, only worse -- they have DATE expirations on their print cartriges. After that date the cartridges don't work--even if they still have ink in therm. What a pack of losers.
Posted on Aug 08, 2008
Me too... this sucks ***!
Posted on Aug 07, 2008
Mofuckin stupid solution this!
Posted on Jul 13, 2008
I can't belive it, this sucks so bad.
Posted on Jul 03, 2008
I have an epson workforce 600 and the printing has gaps in it. i have replaced all the ink did several nozzle checks and head cleaning i also have tried a can of air to clean out any dust and right now it's only showing the magenta and some yellow in the nozzle check
Posted on Jan 09, 2010
2 Suggested Answers
Basti
  • 1447 Answers
SOURCE: Scan when ink cartridge is empty?
Hi-
Chances are you can scan from the computer but if you are going to copy using it as standalone it will not scan- try running epson scan from computer.
Hope this help. Thanks for using Fixya
Posted on Jul 12, 2008
Canon MP150 consumes color ink when ''Ink Cartidge'' = ''Black Only''
In order to keep the printhead free of clogs, all inkjet printers 'clean' the cartridges (color & black) fairly often. In my experience, a printer that is used regularly doesn't need 'cleaning' as often as it is done since this is an ink-wasting procedure and one that keeps the orders coming in for new cartridges where the vast majority of the profit is. Printers used only infrequently do have a tendency to clog and produce the poor quality we all hate.
Epson printers have ceramic printheads (the models I know) which will last just about forever providing they are used regularly. In home use, they have an ugly tendency to clog and often cannot be restored to their otherwise excellent performance. Printers using the integrated printhead/cartridge are easier to keep printing but this system makes the replacement cost much higher and the manufacturing cost slightly higher.
While HP hardware and consumables were made in the US (outside San Diego), I knew employees there and the early integrated cartridges cost a whole ~ 85 cents to produce and $20-$30 dollars to buy at retail.
Printing quality has unquestionably improved but it isn't likely to get any cheaper.
Dec 02, 2009 | Canon Office Equipment & Supplies
My printer is not printing. it will run the paper
I see you don't have much knowledge about printers. It always helps to know something about your printer. It seem you have a color printer. Usually a color printer has two cartridges. Black cartridge and color cartridge. The color cartridge usually contains three colors; cyan, yellow and magenta. If the black cartridge is empty, you won't see black text in the printed paper. Print a small photo and see. If it has all the colors, but looks dull (without proper black color), that means only the black cartridge is empty. If it is greenish, the magenta ink is missing. Generally orange colored printouts suggest cyan is missing. Likewise, purple color means the yellow ink is missing. If you installed the printer properly using the CD from the printer manufacturer, you will be notified when the cartridge is empty or close to run out of ink. But if Windows automatically installed your printer, then the system won't give such information. From the information you have supplied, I believe your blck cartridge is empty or missing. Oh, I almost forgot to say, some manufactures sell some printers (for example some Canon Pixma models) with only the color cartridge. Switch on the printer and open the printer cover. The cartridges will move to the middle. You can check whether the black cartridge is missing. Do not hesitate to contact us for further help.
Aug 13, 2009 | HP Office Equipment & Supplies
I have a Pixma iP4500 printer.When I buy ink, the #5 black ink tank isn't included in the box. There are 2 black ink tanks in the printer.The #8 black ink tank hasn't been used and the #5 is out(as are the...
There are two black inks in the printer so that when you are printing only black and white such as printing a fax or when you set print in B/W for printed matter, the printer will use the larger ink cartridge. When you are printing in the multicolor mode (most people don't know the difference) the printer will use the finer black ink in the smaller cartridge. This smaller cartridge is used for photo printing and multi-color page printing. You cannot mix the two blacks since the larger cartridge is a coarser ink.
Jun 06, 2009 | Canon Pixma iP4500 InkJet Printer
I just installed a Lexmark 2500. It came with an ink cartridge (color) I purchased a black cartridge and installed it but it does not seem to be working. How do you darken the ink on this printer. It seems...
start
control panel
printer and fax
right click your printer, choose properties
go tab by tab and look for print quality and then try
something like this
choose econo mode, or ink saving mode to start.
try to print in grayscale mode and use only the black ink cartridge.
that should be your new default, and you don~t have to change it from winthin other programs
Mar 30, 2009 | Lexmark X2580 Wireless All-in-One InkJet...
Canon MP830 printing with interlacing shades of black
your printer cartridge or head unit ink channel (some of color or black ink channel) constipated, you may try:
1) if your ink cartridge is not new, take out the cartridge put the bottom surface touch cleaner liquid(special for ink printer) or water for 1 hr (you can see ink spread water), then set back and test. refill enough ink maybe necessary.
2) still trouble, you need clean print head ink channel to do same thing above, if your print head is separated from the cartridge.
Feb 05, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Repacing the color inks with black ink on the epson 1290
Well, since you say you'll be using new cartridges you shouldn't have any nozzle problems. About the worst case I can see would be the slight chance of getting too much ink on the paper resulting in wet paper and a stained platten roller. Seems like an interesting experiment over all.
Nozzle problems arise when reusing cartridges. The very thin metal film that is the nozzle assembly gets worn down as the print head moves over paper and after a number of pages printed the little holes that are the nozzles get larger making for fuzzy, wetter than it should be, streaky printing.
Enjoy,
Carl
Dec 14, 2008 | Epson Stylus Photo 1290 InkJet Printer
Question about ink cartridges
The printer will take a little quantity of color ink though you are printing in black in order to get good quality. Hence it is not possible to print with just black ink cartridge without color cartridge.
Thank you.
Dec 06, 2008 | Compaq A3000 All-In-One InkJet Printer
PRINTING WITH BLACK INK CARTRIDGE ONLY; COLORED CARTRIDGE IS EMPTY.
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Printer not working!
Usually black is provided by the black cartridge only. You might be able to setup the printer through the control panel using black and white printing until the color cartridge is replaced. That might turn the color cartridge off allowing you to print.
Jul 27, 2008 | Lexmark Z1300 InkJet Photo Printer
Epson Stylus Photo RX600 All-In-One InkJet Printer Logo
7,075 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
