Question about AEG Dishwashers
The locking mechanism appears to be broken so the OKO_FAVORIT dishwasher won't start. Is this easy to fix?
    Genius:
  • 1,239 Answers
Hi sir When your dishwasher isn't working properly, you should check several main components, such as the door gasket, door latch, switches, and timer
On many dishwashers, the latch engages a switch to activate the timer and other control components. If the latch is not completely engaged or if the switch is faulty, the machine will not operate. Here's how to test and repair a door switch:
Step 1: Latch the door and hold the latch tightly in the closed position. This works best on a unit with a lever-type latch. Then turn the control to the ON position. If the unit works, the problem is probably a misaligned lock unit. Adjust the lock unit with a screwdriver. If this doesn't solve the problem, the switch may be faulty.
Step 2: Test the switch with a volt-ohm-milliammeter (VOM) set to the RX1 scale. Remove the panel covering the door switch and remove one of the electrical lead wires of the switch from its terminals. Clip one probe of the VOM to each switch terminal and shut the dishwasher's door. If the meter reads zero, the switch is working. If the meter reads higher than zero, the switch is faulty and should be replaced.
Step 3: Replace the switch with a new one of the same type. Connect the new switch the same way the old one was connected.
thanks'''''''''
Posted on Sep 12, 2008
5 Suggested Answers
  • 668 Answers
SOURCE: Error code C2 showing on my Oko Favorit
Error Code C2 means drain line totally blocked.
Check drain valve for restriction in pump, check drain line. When there is no problem in drain line then check for a bad float switch or a bad control board . You will get this error even when there is no water in the tub . You can check the float switch with an ohmmeter. It should be open if the float is up and closed with the float down.
Hope this helps .
Thanks for using FIxya.
Posted on Dec 13, 2009
joe_lishman
  • 192 Answers
SOURCE: AEG OKO FAVORIT 6050 trips earth leakge
This is typical of a water leak onto electrical connection OR the electrical element has shorted internaly . Check this with a Ohm meter and itshould show the problem
Posted on Jan 19, 2010
joe_lishman
  • 192 Answers
SOURCE: drain pump keeps running AEG oko favorit
This seems like the anti flood system (polystireen float / micro switch) at the base of the washer is triggered,\. This puts the washer in pump out mode and stops inlet of water via the inlet solinoid. Dry the water on the base and then check for any water leaks. (pipe leak
Posted on Jan 20, 2010
  • 3247 Answers
SOURCE: we dont know how 2 turn it on just moved house n
Looks like what you need is available at
http://www.serviceforce.co.uk/pdfs/U20206.pdf
Good luck with the new house. Hope the dishwasher works well for you.
Try to run it with dishwasher cleaning kit (no utensils) to make sure everything is clean - that way you will get more life out of it. The cleaning kit (usually Finish) is sold in the supermarket in the detergent section.
Posted on Jan 31, 2010
Aeg favorit 40010vi dishwasher won't fill with water
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
Mar 24, 2013 | AEG Dishwashers
My dishwasher won't start at all
There could a number of reasons why it won't start but start with the locking mechanism first. Make sure the locking mechanism is in the "Locked" position. It will be the lever at the top of the door. If that isn't the problem try describing everything you have tried and post your question again.
Jan 20, 2012 | Maytag Dishwasher
Aeg oko favorit 40300 service manual
AEG OKO FAVORIT 40300 When switching dishwasher on no water is flowing into the the dishwasher
Please help
Jan 11, 2012 | AEG Dishwashers
We dont know how 2 turn it on just moved house n no instructions aeg oko favorit dishwasher
Jan 31, 2010 | AEG 18 in. Favorit 54750Vi Slim-Line...
Dec 20, 2009 | AEG 24 in. Favorit 60830 Free-standing...
The drain pump on the AEG oko favorit 6050 keeps running even when the on/off switch is off or the door is open.
Empty all the water from the salt resevoir, (I used a turkey baster), then rock the machine backwards and forwards a few times and empty the last few drops from the resevoir again.
Oct 17, 2009 | AEG Favorit 50500 Built-in Dishwasher
I have an AEG Oko Favorit 8081 dishwasher and it appears that there is no power getting to it [nothing light up] I have checked with a voltmeter and power is getting to the back of the machine. Is there a...
there is no fuse or breaker in appliance.
take outer door panel off and check for breakage in the wiring loom where it enters the bottom of the door. check also the door interlock is operating ok
Nov 12, 2008 | Dishwashers
Drain pump keeps running AEG oko favorit
Aug 29, 2008 | AEG Favorit 50500 Built-in Dishwasher
Dishwashers Logo
338 people viewed this question
Top AEG Dishwashers Experts
Oloyede Monsuru
Mike
Are you an AEG Dishwasher Expert? Answer questions, earn points and help others
