Question about Dryers
Condenser sensor dryer not very hot
My dryer is only a few months old but is nothing like as hot as the one that it replaced. Does the unit have more than one heater element and perhaps one might be faulty? or does this model not get very hot?
Is a maintenance manual available , or wiring diagram?
    Genius:
  • 1,122 Answers
The heationg elements are tied together so they either work or don't work,it sounds like your hose vent might be clogged,also check power coming into the dryer on the terminal block,make sure you have 115 on each leg,mike
Posted on Sep 12, 2008
Beko condenser dryer not drying clothes it is
Well the bad news is this is a extremely cheap unit. It was thought that a sensor that would know when your clothes were dry was a good energy saving idea. Well it wasn't This is a very common issue in these dryers. The Sensor needs to be replaced.
Sep 29, 2014 | Dryers
Tip
KNOWING ABOUT CONDENSER
What is a condenser?
Is a device or unit used to condense vapor into liquid. A condenser is simply one component of an air conditioner. Whether you have an outdoor air conditioner or a window unit air conditioner your air conditioner contains a condenser.
Condensers are used in outdoor air conditioning systems as well as heat pump systems. Condensers in an air conditioning unit have very few controls. They will have an on and off switch. Occasionally these air conditioners will also have a brown out option. This option shuts down the compressor when the electrical current is low.
A condenser is simply a heat exchanger. It compresses refrigerants into a hot gas to then condense them into a liquid. A condenser is a major component in a air conditioning or heat pump unit. It moves air across the coils to facilitate the transfer of heat.
In a heat pump unit the condenser has a few more features. It will have a reverse valve that allows the unit to switch back and forth between air conditioning and heating. Even when the unit is heating, it uses the condenser for defrosting the coils. If the coils become layered with frost it will effect the units effectiveness this is defrosted when the reverse valve switches to air conditioning mode to move the hot gases through the coils melting the built up ice. It will automatically switch back to heating mode once the ice is cleared to once again heat the home.
To keep your unit in good operating condition it is vital to keep the area around the condenser clear of all debris as well as keeping the filter clear of dust and dirt. A clean machine makes a happy machine. A happy machine will keep you cool during the summer months and warm during the cold months. It is suggested to change the units filters when they become dirty, depending on your area and conditions near your home this may be as often as once a month or as seldom as every 3 to 6 months. You will have to pay close attention to your units needs to decide the right time to change or clean your unit’s filters.
It is very important no matter what type of unit you have to prevent the blockage of the condenser. If the condenser becomes block it can effect the units efficiency or even cause the until to completely fail. For this reason it is one of the most important components of a cooling or heating system. A condenser allows the maximum airflow to the unit.
Keeping you condenser in good running condition will not only prolong the life of your heat or cooling system but also provide you with the most efficient heat and cooling system saving you money on heat and cooling.www.victorwod1234.blogspot.com
on Apr 08, 2010 | Heating & Cooling
Water sensor light keeps coming on even tho tank empty have checked hoses and cleaned large filter at front
try cleaning out the condenser unit, instuctions are on pages 2 and 3 of your manual, if you dont have it download it from the indesit website.
fluff and old stuff gathers in it, if you leave it too long it will burn out the thermostat
instructions below.
Step 1
Open the condenser cover
- grip the handle and pull
towards you.
Step 2
Remove the condenser by
turning the 3 catches, then pull
the condenser towards you. (It is
normal for some residual water
to be left in the tubes).
Step 3
Clean the condenser with running
water over the rear side to
remove any fluff deposits.
Step 4
Replace the condenser unit;
make sure that the unit is
securely in place, that all 3
catches are fixed and that the
position arrows on the front end
of the condenser are pointing
upwards.
Nov 15, 2010 | Indesit IS70C Electric Dryer
Our kenmore eliite HE4 gas dryer keeps shutting off after a few minutes of running no mattter what heat setting we put it on. On air dry mode it works. Is this a high heat sensor problem? The unit is 4...
You didn't mention if the dryer is getting hot.
If is getting hot, then shutting off, I agree with you.
If it is NOT getting hot, I would suspect the IGNITER ASSY
Dec 13, 2009 | Kenmore Elite HE4 Electric Dryer
Dryer not hot
Tht means that the element is not heating on.
You need to call a technician to test the element, the thermic sensor, and the control assembly.
The most likely is a defective heating element, that must be replaced.
Jan 31, 2009 | Kenmore 73952 Gas Dryer
Zanussi condenser drier: tank full light on even though empty
its either going to be fluff in the float which you can get at by taken the side panel off .or its fluff in the valve behind the water tank
Jan 11, 2009 | Zanussi TC7114W Electric Dryer
Hotpoint condenser tumble dryer aquarius cdt00- wont dry
I am not familiar with this particular unit, but I have a condensing dryer (Malber) which pumps out the water by itself. I am guessing that your unit requires you to empty a bin manually. Even if the bin is empty, I think the unit thinks it needs to be emptied and that is why the dryer will not work to give you hot air. If you do have such a bin, it might have a weight switch which the unit uses to detect if the bin needs emptying. See if the weight switch is working. The same weight switch idea is used on dehumidifiers.
Mar 09, 2008 | Dryers
NO HEAT
either the secondary coil is bad or the flame sensor. more common is the coil
Jan 30, 2008 | Frigidaire FGR231A Gas Dryer
Dryers Logo
Top Dryers Experts
