Question about Amana AMV1162 Microwave Oven
Microwave runs, stops and counts down, starts again, etc.
My Amana Radarrange starts just fine. However, after 30 sec - 2 minutes, it stops heating but continues to count down. After a while, it begins heating again. It takes forever just to heat a bowl of chili. What can I do to fix it?
  • 2 more comments
  • teebeecee Feb 21, 2008
    Starts lights rotates but will not heat
  • Anonymous Mar 14, 2014
    microwave counts down in 2 seconds and never starts
  • Anonymous Mar 24, 2014
    How I can set timer to different time
  • Anonymous Mar 27, 2014
    There are 2 symbols that are flashing, one is a soup bowl and something else. THe microwave can count down but does not turn on
  • Amana Master
  • 9,149 Answers
Quite often this is due to a bad door switch. Opening the door while cooking (without first hitting the STOP button) is the primary cause of door switch failure. You can visit my Web site at _ or e-mail at _ if you'd like more in information on diagnosing and repairing this problem.
Posted on Sep 15, 2006
    President:
  • 3,130 Answers
It sounds like its over heating or the magnatron or the Hi voltage transformer. if you open it and start it a fan should be cooling off the magnatron if its not then the fan is bad and thats your problem Worse case is that the power transformers drawing too much current and over heating and shutting down the first problem i explained though I've seen a hundred times. BUT BE very carefull as there is hi voltage inside this puppy and I've seen it grab and throw a grown man across the room!!!! if you know nothing about electrical or electronic devices its best that you leave this repair to a pro. Good Luck
Posted on May 04, 2006
Microwave timer doesnt ping off
this is probaly a clockwork timer you are talking about sounds like the contackts are stuck together in the timer pull knob off take screws out probally 2 disconnect wires from timer and replace they are not so expensive
Mar 28, 2013 | Microwave Ovens
When I press the clock button, the microwave turns on and starts counting down from 30 seconds. The stop/clear button will not work to stop it. I have to open the door to stop it. I unplug it but it...
Hello :
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly .
good luck .
please rate !
Mar 30, 2010 | Amana ACO1520A Microwave Oven
Time count down on microwave oven
Unplug the Micro for about 5 minutes and plug it back in this will reset the board,it may have picked up interference from other electronics.If the issue continues have a technician look at it.
Aug 25, 2009 | Maytag MMV4205 Microwave Oven
Won't heat
I have narrowed the problem down to the door, but I have not yet repaired it nor do I know how. If I hold the door after closing, and hit start it will begin the heat process, but when I let go of the door it stops.
Jul 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
PANASONIC MICROWAVE MODEL NN524M
I have had many of these ovens and found it to be the Magnetron never try to fix a microwave yourself.
Jul 15, 2008 | Panasonic Microwave Ovens
Amana AMV1162 Microwave Oven Logo
280 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Archie Ferrarini
Archie Ferrarini
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
