Question about Zanussi Refrigerators
I have a Zannussi ZEBF 249W fridge/freezer which needs the thermostat changing. I cannot see where the capillary tube of the thermostat goes down to and I feel that I shall have to open the unit from the side which is tight because of the foam that has been used to seal it. Before I do anything too drastic, can you please tell me the easiest way to access the thermostat so that I may replace it with a new one. Thank you. Best regards from Ian.
  • 1 more comment
  • triton 650 Sep 12, 2008
    Do I have to remove the back or the side of the fridge/freezer unit to gain access to the thermostat capillary tube, please?
    Sorry but I have just had details on how to change the defrost thermostat. It is the temperature control thermostat that I need to change. The unit itself is situated at the top of this model. When the plastic front cover is removed, the thermostat can be easiky seen. My problem is that the capillary disappears down a hole at the side of the evaporator and I cannot work out how to gain access to it. Does the side of the freezer need to come off? This appears to be held on by th foam, or can gain access by removing the back of the unit, or is there some means of removing the freezer liner to access it? Thank you. Best regards from Ian.
    Between two solutions that I have been sent, I think that I now have the answer to my question. Access is from the back and I need to cut off the old one and pull it through. Excellent. Thank you very much for your service. I have phoning around for four day's to try and solve my problem. Solved in minuts with your service. Many thanks for an excellent service. Ian.
    Genius:
  • 1,239 Answers
hi sir here is the picturitation of changing thermostat
Posted on Sep 12, 2008
    President:
  • 1,952 Answers
Www.serviceforce.co.uk/pdfs/U24490.pdf
download pdf from above link..u ll get better idea..
if ur in warranty period..better call service man and clear ur fault...once u broke seal in tat system ..ur warranty will be not valid after tat..thermostat is available oly at the rearpart of ur freezer
  • mohammed marika thambi
    mohammed marika thambi Sep 12, 2008
    switch off everythin and defrost it then replace it
    good luck ..
    thanks for using fixya
  • 958 Answers
Generally, the tip of the thermostat should be touching the evaporator. so look for a mall tubing usually covered by small plastic tube that is attached to the rear or side of the evaporator.
if you find it, make sure it is the end of the capillary of the thermostat by slightly pull and push technique.
if you are sure, then you can cut the thermostat side and hook up the new tip of the thermostat to it( make sure it would not disconnect or else you may never put it inside the wall again )
then slowly pull the old tip and slowly guide the new capillary until the new tip comes out of the hole of the wall to where you are pulling. then you were able to put a new thermostat the same way as the old one.
tnx 4 using fixya,
drcool
    Genius:
  • 3,422 Answers
HI,
Can you please tell if this is a:
Side by Side
I have a Zannussi ZEBF - redarrow.gif Freezer on Top
redarrow.gif Freezer on Bottom
redarrow.gif Under counter
  • Priya darshan Sep 12, 2008
    Here are the steps which will help you replace the thermostat.
    Before you begin to replace your defrost
    thermostat, make sure you disconnect the appliance's power supply. The
    easiest way to do this is to unplug the unit from the wall.
    Alternatively, you could trip the appropriate switch in the circuit
    breaker panel, or you could remove the appropriate fuse from your
    home's fuse box.
    1. Locate your refrigerator's defrost thermostat. In freezer-on-top
      models, it may be located under the floor of the unit, or it could be
      found at the back of the freezer. If you have a side-by-side
      refrigerator, the defrost thermostat is found at the back of the
      freezer side. The thermostat is wired in series with the defrost
      heater, and when the thermostat opens, the heater shuts off. You will
      have to remove any objects that are in your way such as the contents of
      the freezer, freezer shelves, icemaker parts, and the inside rear,
      back, or bottom panel.
    2. The panel you need to remove may be held in place with either
      retainer clips or screws. Remove the screws or use a screwdriver to
      release the clips holding the panel in place. Some older refrigerators
      may require that you remove a plastic molding before you can gain
      access to the freezer floor. Exercise caution when removing the
      molding, as it does break fairly easily. You could try warming it with
      a warm, wet towel first.
    3. There are two wires leading from the thermostat. They are attached
      to terminals with slip-on connectors. Gently pull on the connectors to
      release the wires from the terminals. You may need to use needle nosed
      pliers to help you. Do not pull on the wires themselves.
    4. Proceed to remove the thermostat. It may be secured in place with a
      screw, clip, or clamp. The thermostat and the clamp on some models are
      one assembly. On other models, the thermostat clamps around the
      evaporator tubing. In some other cases, the thermostat is removed by
      squeezing in on the clip and pulling the thermostat up.
    5. To install your new defrost thermostat, reverse the removal
      process. Reconnect the wires, replace the panel, and restore power to
      your refrigerator. For those models where the defrost thermostat is
      attached to the evaporator coil, make sure you install the new
      thermostat in the same location and position of the old one.
    If my solution no. 2 was helpful to you then please accept coolguy008's solution as fixya.
How do I adjust the temp on the freezer
Although a make / model was not specified, here is a general guide:
Upright fridges and freezers have a controller which is usually mounted inside the cavity, or at the back of the unit.
Using my own two as an example, the refrigerator / freezer combo, "Fridgemaster", has the thermostat & light assembly at top right interior of top fridge section. Clockwise is warmer and ACW is cold.
The "Kelvinator Trimwall" upright deep-freezer hides it's thermostat at the back left bottom.
The thermostat will have a capillary, a thin copper tube, leading to it.
Jan 31, 2018 | Refrigerators
KitchenAid KBRA22KL Moved houses and now fridge and freezer will not cool. Lights work. Here fridge has power but not kicking in the condenser. Is there a reset somewhere or is it fried. Pls help!
you must have laid the refrigerator down during transport. compressor oil is now blocking the capillary tube. just keep trying by plugging in for a few minutes every couple hours until the oil finally clears the capillary tube
APPLIANCE 911
Jul 24, 2016 | KitchenAid Refrigerators
I need instructions how to replace the cold control on Sub-Zero 550 Freezer.
Here is a pic of the insides. The cold control is at top right of this pic and the capillary tube goes from it across to middle and then down the centre. All this is can be reached from the back of the refridgerator.
http://www.bing.com/images/search?q=Sub-Zero+Model+550+Manual&Form=IQFRDR#view=detail&id=E7AB2341111D09E747ABB1092D17C1338277BB7F&selectedIndex=0
Dec 20, 2013 | Sub-Zero Refrigerators
How to replace thermostat
This all depends on the type of fridge. I had a problem with my fridge/freezer and it need a new thermostat.FIRST UNPLUG THE APPLAINCE FROM THE WALL SOCKET. Basically you need to get access to the thermostat and many models the control knob is on the inside and on some its outside on the top. You need to first undo the end where the capillary tube ends then remove the control knob. There is usually a nut holding the thermostat, remove that and also remove the electrical connector and simply pull until the whole of the capillary tube is out. Refit the new one in reverse order.
Feb 19, 2013 | Refrigerators
I have a true fridge mod number t55u-27-8 we keep salad in it and it keeps freezing all the salad please can you help ritchie
Hi, there are 3 likely things causing the problem.
Thermostat contacts faulty
Capillary tube(the thin tube connected to the thermostat) broken somewhere
Capillary tube not making good surface contact with the evaporator/cold plate.
A Leakey door seal is normally indicated by excessive frost buildup on the evaporator/cold plate over a short period.maybe the thermostat knob is slipping and not adjusting the temperature level of the thermostat...........
May 16, 2011 | True Refrigerators
Fridge works freezer does not Zannussi
the fridge will soon stop to! all cooling goe to the freezer first! look to see if there is frost in back of the freezer if not it might be low on charge
Apr 11, 2010 | Freezers
GE Eterna ESS25LGNA freezer side not working
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Aug 22, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Hotpoint RLA64 getting too cold.
The thermostat capillary on a Hotpoint RLA64 (and possibly RLA80) is inserted into a tube. The tube becomes detached from the cooling element and so does not sense that the fridge has reached the desired temperature. It then carries on cooling resulting in ice build-up and freezing of goods.
As you cannot remove the top or back of the fridge, you cannot fix the capillary tube back into position. What you can do however, AFTER ISOLATING THE FRIDGE FROM THE MAINS SUPPLY, is to drill a small hole adjacent to the thermostat capillary tube and another in the roof of the fridge next to the interior light and pass the thermostat capillary INTO the fridge cabinet. Use tape to attach the capillary across the roof of the fridge and down the centre of the rear wall curling the last 50mm or so back up towards the top of the fridge. As long as you have dried the wall of the fridge and stuck the capillary securely in place, your fridge should now work correctly when powered up.
Only tackle this job if you are confident and ALWAYS ISOLATE the mains supply.
Jul 03, 2009 | Refrigerators
NO COOLING IN FREEZER OR FRIDGE SECTION
yoiu are correct that the unit sounds like the compressor is low on charge and or has a clogged capillary tube. Whenever the condenser coils get rael dirty theres a chance that the capillary tubes will clog up with oil. That is the raeson that I personally do not like the refrigerant r-134a and prefer another one called hotshot or r-414b.
Apr 05, 2009 | Refrigerators
Fridge freezer thermostat
doesn't come out anywhere - just push capilliary till it hits end of the tube you are pushing it into
Oct 09, 2008 | Freezers
Refrigerators Logo
229 people viewed this question
Top Zanussi Refrigerators Experts
Charles T Nevin
Charles T Nevin
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a Zanussi Refrigerator Expert? Answer questions, earn points and help others
