Dryers Logo
Posted on Sep 05, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Aeg tumble dryier drum not turning motor ok belt ok drum free please help
Anonymous
Level 3:
  • Dryers Master 43,501 Answers
  • Posted on Sep 11, 2011
Anonymous
Dryers Master
Level 3:
Answers
43501
Questions
0
Helped
10844146
Points
101584
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
I have a 14 yr old AEG 3200 dryer. The drum has stopped turning.Could this just need a simple belt replacement or wld you recommed a new dryer. Thanks
If you can hear the motor run when activated replace the belt. You should check or have checked the rollers that the drum is supported by. Check the belt tension-er replace if worn. While the unit is disassembled the rollers are easy to replace.
Vacuum all loose lint out from around the motor while disassembled.
These simple older machines are reliable and very durable and only have a few moving parts.
Hope this helps?
AEG LAVATHERM 60750225500 Tumble Dryer Section Spare Parts Diagram
Jun 21, 2017 • AEG Dryers
Hi, I have an AEG T35850 tumble dryer. The motor makes a buzzing sound as it slowly gets going when empty. If it has a really hard time getting started, most of the time failing to get going.
The most likely cause is a slipping drive belt from the motor to the drum. Check the tension on the belt, but if the belt is worn, replace it. If the belt has been slipping for a period of time , it will probably be worn out.
Motor making a buzzing sound, is the motor actually turning? If so it is probably the belt.
If motor not turning, try taking the drive belt off and if the motor now runs, you may have seized drum bearings = expensive, buy a new dryer !
2answers
1helpful
2answers
Drum not turning
Hotpoint tumble dryer not turning? How to replace a hotpoint tumble dryer belt
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. 9 rib stretch tumble dryer drive belt Contitech 144001958 9PHE 1860 How...
1helpful
Beko Tumble Dryier - Model DRVS 73 W the Belt 9PHW 1967 has broken. Is there a step by step guide on how to fit the replacement belt.
Very easy on all tumble dryers.
UNPLUG FROM POWER FIRST!
This is simply a case of:
Take the top off the machine (Usually a couple of screws holding the lid on at the back).
Or - Rempove the inspection panel from the back
Drop the new belt over the drive motor spindle
On some machines you may need to thread the belt around a tensioning wheel
Now take the belt and place it on the side main wheel that drives the drum and simply spin the drum wheel with your hand, guiding the new belt into place as you spin the wheel.
It should simply stretch a little and work its way onto the wheel as it is hand turned.
Note, once it is on, take a look at the drive motor and make sure that the belt is sitting in the same place as the old one. Most of these motors have a slotted spindle and you can see from the clean and shiny surface where on the spindle the belt used to sit. If it is a little out of place, once again just take hold of the belt and pull it toward you or push it away as you spin the main drum wheel in order to move it into the correct slot.
Jun 23, 2011 • Dryers
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
3helpful
2answers
How to change a belt on hotpoint tdl54 tumble dryer
The belt goes around the pulley of the motor after fitting it around the drum first.
I have a kenmore 80 series dryer that heats up and will not tumble. The model # is 66822692. Can you please help?
Open the back panel to access the belt. There is a motor to make the drum tumble by the belt. If the belt is not intact then motor turns but not the drum. If the belt is in good place then motor is not working. Check out the continuity of the motor, if there is then there is a problem with the circuitry. If there is not continuity from the motor terminals then the motor is burnt.
Dec 28, 2009 • Dryers
2answers
Tumble dryer drum won't turn
Hotpoint tumble dryer not turning? How to replace a Hotpoint tumble dryer belt.
Jul 06, 2009 • Dryers
2answers
I need the procedures on how to change the drive belt on my Hotpoint VTD00G Tumble dryer. I've opened the top & front covers, placed the belt round the drum but I couldn't stretch the belt over the...
Apr 06, 2008 • Dryers
Top Dryers Experts
john h
