Question about Sony FD Trinitron WEGA KV-27FS100 27" TV
Sony kv-29cl11 blinks 11 times does not turn on
I understand that it is connected to the picture tube. but how much (approx) should it cost ?
is it economical to replace it ?
is it possible to do it by myself ? where can i find instructions ?
thanks alot,
kindalost.
SOURCE: sony tv no pic or sound
I'm sorry to inform you, but Sony error codes go past 7 on newer sets.
Posted on Jun 29, 2007
  • 3422 Answers
SOURCE: Sony kv-34xbr910 wont turn on
HI,
  • Unit is dead, No blinks - Problem in the standby power section. Might check fuse, R607, Q601, IC601, R612 and VDR601 (should show open).
  • Continuous blink once a second, no pausing - No reply from the jungle IC301 data bus is busy, shorted to ground, or held high), IK video path is defective.
  • One blink - not used for the self-diagnosis
  • Two blinks - B+ over current protection (OCP), unit goes to the standby mode then displays the 2 blink fault. Could be a short in the power supply of any of the circuits.
  • Three blinks - B+ over voltage protection (OVP), unit goes to the standby mode then displays the 3 blink fault. This is also a problem in the power supply circuit, check T603 and R672.
  • Four blinks - No vertical Deflection (V STOP), Screen goes to a single horizontal line then the video signal muted. Check IC1509, Q1505
  • Five blinks - AKB circuit (automatic kine bias), the timer/standby indicator blinks for about 30 seconds then goes to the self-diagnosis function. Something is wrong with the video. Check video out, Q705, 732, 761 and other components on the C board, also check Q218, 219, 220 on the A board. In addition, unit could be in IK blanking, try turning up screen slightly.
  • Six blinks - No Horizontal (H STOP), no raster, goes to the blinking self-diagnosis function immediately. Check C515 & 516 and the jungle IC, IC206.
  • Seven blinks - High voltage shutdown. The high voltage has exceeded 33k and the unit goes immediately into safety shutdown. Check power supply regulation and horizontal circuits.
  • Eight blinks - Problem with the audio (AUDIO), unit goes to standby and blinks the self-diagnosis code. Check IC406 audio amp, PS401, and 402. On some projection models of Sony TV sets, this code means that T8005 (flyback transformer), or the associative components in the high voltage circuits are defective on the D board.
  • Nine blinks - Replace D 6116 and D 6301 on the "G" board, do not resolder as this will fix the problem temporary. Or Panel Module Error or Thermal Error. If it is intermittent 9 blinks, meaning sometimes the TV comes on and other times you get flashing, then change the switching regulator on the "G" board or check connections. Make sure the regulator is -12 or -13 (negitive).
  • Ten blinks - Check Q8014 and Q8013 for shorts, leakage, or bad solder connections on the " D" board. If the transistors are bad, check R8051 and IC8005, also on the "D" board.
Goodluck,
Please don't forget to rate the solution
Posted on Apr 26, 2008
jupits69
  • 4 Answers
SOURCE: KV HR36 Sony Wega, 10 blink and turn off...
try to replace the horizontal out transistor
Posted on Jul 18, 2008
  • 61 Answers
SOURCE: Sony KV-36XBR800 won't turn on and red led on the front blinks 6 times
For 6 blinks Pls check following area.
Low HV Shutdown:
On the D Board.
Check IC8004/pin 7 should be 7.4v.
Check IC8006/pin 2 should be 2.5v if lower will trigger shutdown by causing pin 1 to turn on.
Check IC8006/pin 3 reference voltage 2.2v.
IC8006/pin 1 normally at 0v. If high
turns D5007 ON which turns the latch circuit Q6532,
Q6530, and Q6527 ON and turns the AC relay RY6501 OFF.
And NOTE: 6 blinks also can be Low B+ protection.
Unregulated 7.5 v from the power supply to 5v reg IC504 on the A Board. 5v to M Board Q2314
to CPU IC2300/pin 43. If 5v missing set will shutdown with 6 blinks.I think this will help you to solve this issue..
Dont forgety to Rate!!
Good Luck
Dals123
Posted on Oct 22, 2008
  • 4234 Answers
SOURCE: Sony Trinitron Picture Tube replacement
I think that you will find the picture tube to be more expensive than a replacement TV, if it is still available (unlikely). That being said, it is also unlikely that the tube itself is the problem, The more common problem is the horizontal output transistor or the flyback transformer. Either part should still be available for a reasonable cost. Check with a local servicer for the part numbers and costs. These are common parts.
Dan
Posted on May 19, 2009
Hi! I have a SONY KV-HR36M31(Australian model). When TV is turned on green light flashes approx.9-10 times and then shuts down.Red light blinks 10 times and then repeats. Whats the problem and can a...
Type in Understanding Sony Blinking Codes in your search bar.
Most Common Problem with these tvs is Bad Picture Tubes, First what happens is you will find Shorted Hori output Transistor,then Bad (FBT) flyback Transfomer, then after you replace these 2 parts you will find out that the Picture is leaking High Voltage and that is what caused Parts to go Bad.
Apr 12, 2011 | Sony Televison & Video
Stand by light flashes 7 times and tv will not turn on
Sony Trinitron Wega KV-34HS420 blinks 7 times it means the the Horizontal Deflection stopped.
There are two cause for this: B overcurrent is detected (IC5007 is defective) or there is a over heating is detected by the Thermistor (TH5002). Both of these parts are on the DZ Board. If you order the DZ Board from the "Partstore.com" it will cost you $395.95 minimum. The Thermistor TH5002 (part # 1-807-796-11) cost $4.95.
This IC chip IC5007 is no longer available at Partstore.com. You could purchase it from other stores. Not sure of price.
Replacing the whole DZ board would for sure fix this problem but at close to $400.00. Then what if another board or your picture tube goes out soon.
Better to go buy a new flat panel LCD from Costco for around the same price.
Hope this helps
Bobby Guel "aka poolmvp1"
May 31, 2010 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Sony wega kv-32xbr400
My sony is doing the same thing. but mine blinks 11 times. each time it goes to turn on i hear the clicking then nothing.
Jun 12, 2008 | Sony FD Trinitron WEGA KV-32XBR400 32" TV
Sony trinitron wont turn on.
your picture tube is weak.
not economical to repair.
it is cheaper to replace it.
Thanks Guy9
Jun 10, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Blinking
your picture tube is bad. rejuvenate may work ..
Apr 01, 2008 | Sony KV-32S25 32" TV
Blinking picture
TV Repairman came out today to look at my Sony KV-36XBR250 today with the exact same problem - he was able to adjust the settings through the service menu, but said it was a temporary fix only.
The picture tube is going and the Sony circuitry has a "video mute" that it uses when it senses the tube is not warmed up enough. The degraded state of the tube causes the blinking on and off as the signal from the tube wavers.
He ballpark estimated the tube replacement cost well above the price for replacing the set with a 37" LCD, so it's going to the dump...
Mar 02, 2008 | Sony KV-36XBR250 TV
Sony kv-34xbr800
I have the same problem. When using the remote, it makes the clicking sounds like it turns on, then immediately makes the clicking sound of turning off. The LED blinks repeatedly 6 times over and over.
I *did* get it to come back on by holding the power button down for about 5 seconds. Now I'm afraid to turn it off again! :(
Nov 29, 2007 | Sony FD Trinitron WEGA KV-34XBR800 34" TV
Sony KV-34HS510 blink codes
I would question that diagnosis, Did you get it online somewhere or did you have a tech check your B+ voltages ?
6 blinks is almost always caused by 2 chips on the "D board", they are both marked MCZ3001D you can order them here if you are a consumer not a tech 800-575-9833. Not to say that the jungle IC & those 2 caps couldn`t cause a dead set symptom but these 2 IC`s are notorious for the 6 blink code, I have personally fixed approx. 10 sony sets with the 6 blink code with those IC`s, hope this helps
Nov 29, 2007 | Sony FD Trinitron WEGA KV-34HS510 34" TV
Sony kv 32s42 32 tv
turn up your master screen control on flyback transformer. if when sceen gos black ,the timer light will be blinking. this means your picture tube is week. by turning up the screen control you may give it more time.
Aug 05, 2007 | Sony KV-32S42 32" TV
Sony tv no pic or sound
Sony error codes usually only go up to 7. If the LED blinks 11 times, this usually indicates that either the clock or data line is shorted and this needs to be serviced by someone with experience with Sony sets.
Jun 28, 2007 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Sony FD Trinitron WEGA KV-27FS100 27" TV Logo
211 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
