Question about LG LW20-EV Notebook
LG LW 20 virtual memory is low??
What does this mean........ there is still more than 30 % free memory
  • cavallogirl Sep 12, 2008
    Hey Wiz
    Thanks for your help - I had no problem finding the right screen and have adjusted to ""system managed"" the paging file was at the maximum set for the system, tho twice as much is available.
  • 135 Answers
You could be using a progam or have background services that eats up your memory and the page file on advanced settings could be set to a specific range.  You could set it to system managed that could fix the issue. Right click on computer, select properties, select advanced system settings, select advance tab, click on settings under performance, click advance tab, then you can check out virtual memory from there.
Hope this helps
Posted on Sep 12, 2008
Virtual memory low, not sure how much I have got and what I can upgrade to? My desktop ser no is 11419107876?
I assume that you got a little balloon in the
bottom right-hand corner announcing that your
virtual memory is low and that Windows is
adjusting it. If this happens just once, don't
As the message said, Windows found a problem
and fixed it. But if it happens repeatedly,
it could be that your settings don't allow
Windows to make the necessary adjustment.
First, make sure your drive isn't overly full.
In Windows Explorer, right-click the drive
icon and choose Properties.
If the amount of free space is under about
10 percent, you'll need to free up some space.
You can use the Disk Cleanup button right next
to the free space indicator, or manually move
some files to off-line storage,
or uninstall unnecessary applications whatever
it takes to get more free space.
If low drive space isn't the problem, the
virtual-memory settings may be wrong.
Right-click My Computer and choose
Properties. Click the Advanced tab.
Click the Settings button in the
Performance panel.
Click the Advanced tab in the Performance dialog.
Click the Change button in the Virtual
memory panel. Whew! This setting is buried
quite thoroughly!
Look for the System managed size option,
select it if it isn't already selected,
and then click OK, OK, OK. That should end the
Aug 17, 2010 | Targa Computers & Internet
Virtual Memory too low Warning Trouble in win xp and vista
When there is less physical memory than needed, then some virtual memory (virtual RAM) is created on the disk. When there is a limit set to the size of virtual memory usage and there is not enough of it present there is a warning that frequently comes "Virtual Memory too low". Solution 1 : This problem occurs when physical RAM + Virtual RAM (usually created on hard disk) together are not sufficient to take care of the currently needed RAM size, or this situation is about to arise. This usually happens when some fixed upper limit for Virtual Memory has been set. To solve this problem, you can either upgrade you physical RAM on your computer (recommended), or you can set the Virtual Memory to system managed size or you can do both. Setting Virtual Memory to system managed size means windows will set it to higher size whenever needed automatically,for this, <br /> Right click on My computer --&gt; goto properties, goto advanced tab, click on performance settings, now click on advanced, now click on advanced, now click on change button for Virtual memory. <br /> On this screen select the System managed size, press OK. After this re-start your computer. This will solve the virtual memory too low problem. Solution 2: Recommended solution is to upgrade your physical memory (RAM) according to requirements of the kind of applications that you run on your computer. If you upgrade RAM or not, the following procedure will help prevent this warning by increasing the virtual memory limit. <br /> Right click on My computer icon and click properties. <br /> This will show system properties window. Click on a advanced tab and click on the settings button under heading performance. This will open performance options window. Click on advanced tab and click on change button under heading virtual memory. Check if the space available is set to some custom value or double the RAM size ? If it is not double the RAM memory size , then select the size option set the virtual memory size double the RAM Size and press set button and press OK button. Restart the computer
on Apr 04, 2011 | Computers & Internet
Computer Tips: Low Memory Problems
How to solve low memory problems...?
Normally this warning message shows when you run many programs same time than the RAM installed on your computer is designed to support. Your can solve this problem by increasing the system paging file size also called as virtual memory. Using this virtual memory windows moving information to and from the paging file for fast processing. This will free up enough RAM for other programs to run properly.
To increase the system page file follow the give path:
Control Panel > System > Advanced > Click on Settings (Under Performance) > Advanced > Change
Here under Drive (Volume label), you have option to select any of your hard disk drive, but the best choice is, select any drive other than C drive for virtual memory.
Set the double Initial & Maximum Size of your Virtual Memory. Here set initial size 700 MB and maximum size up to 1000MB; you can change this size according to the free space available on your hard drive.
on Mar 08, 2010 | Computers & Internet
Windows XP Virtual Memory is low. How can I regain memory?
Virtual memory is "memory" on your hard drive, not actual memory. The best way to regain this is reboot and shut down some of the stuff that runs automatically when you DO boot up.
(This Virtual memory is space set aside on your hard drive that the processor moves data into and out of like it would put data on a memory module ... but in comparing the two, the virtual memory is SLOW.)
You can increase the size of your virtual memory to anything you want. Some say too large a allocation will slow you down and too little will cause crashing or slow opertion. You are 99.44% probably set to let Windows manage your virtual memory (default) at this time.
thanks for posting your question to
positive comments are welcome
Nov 02, 2009 | Gateway Essential 500 PC Desktop
I believe I have a virus or worm that Norton cannot detect
Ok. How much space do you have free on your hard-drive right now? (I'm assuming that you know how to check this).
If its low, then maybe you didnt free up enough space on the drive. If it is high however, then answer this: is the message you are receiving telling you that you are low on disk space? or is it telling you that it is low on virtual memory space?
if its low on virtual memory, then the problem could be many including 1) virus etc 2) a program is running that is using up more RAM than is avaivable 3) you need more RAM on your system.
if its low disk space, then the problem could be 1) You need to free up more disk space (that may mean getting a bigger hard-drive installed)
Try using an updated virus scanning utility. If it says that you are virus free, then try one of the solutions above.
Oct 02, 2009 | Computers & Internet
Virtual memory Information.
Tutorial Objective
This tutorial talks about anything about the virtual memory and how much virtual memory you need for your system.
Tutorial Introduction & Background
Today application is getting bigger and bigger. Therefore, it requires a bigger system memory in order for the system to hold the application data, instruction, and thread and to load it. The system needs to copy the application data from the HDD into the system memory in order for it to process and execute the data. Once the memory gets filled up with data, the system will stop loading the program. In this case, users need to add more memory onto their system to support that intense application. However, adding more system memory costs the money and the normal user only needs to run the the intense application that requires the memory only for one or two days. Therefore, virtual memory is introduced to solve that type of problem.
Terminology & Explanation
There are two types of memory, which are as follows:
* System Memory is a memory that is used to store the application data and instruction in order for the system to process and execute that application data and instruction. When you install the memory sticks to increase the system RAM, you are adding more system memory. System Memory can be known as either the physical memory or the main memory.
* Virtual Memory is a memory that uses a portion of HDD space as the memory to store the application data and instruction that the system deemed it doesn't need to process for now. Virtual Memory can be known as the logical memory, and it controls by the Operating System, which is Microsoft Windows. Adding the Virtual Memory can be done in system configuration.
Tutorial Information & Facts or Implementation
Virtual Memory is a HDD space that uses some portion of it as the memory. It is used to store application data and instruction that is currently not needed to be process by the system.
During the program loading process, the system will copy the application data and its instruction from the HDD into the main memory (system memory). Therefore the system can use its resources such as CPU to process and execute it. Once the system memory gets filled up, the system will start moving some of the data and instruction that don't need to process anymore into the Virtual Memory until those data and instruction need to process again. So the system can call the next application data and instruction and copy it into the main memory in order for the system to process the rest and load the program. When the data and instruction that is in the Virtual Memory needs to process again, the system will first check the main memory for its space. If there is space, it will simply swap those into the main memory. If there are not any space left for the main memory, the system will first check the main memory and move any data and instructions that doesn't need to be process into the Virtual Memory. And then swap the data and instruction that need to be process by the system from the Virtual Memory into the main memory.
Having too low of Virtual Memory size or large Virtual Memory size (meaning the size that is above double of the system memory) is not a good idea. If you set the Virtual Memory too low, then the OS will keep issuing an error message that states either Not enough memory or Virtual too low. This is because some portion of the system memory are used to store the OS Kernel, and it requires to be remain in the main memory all the time. Therefore the system needs to have a space to store the not currently needed process data and instruction when the main memory get filled up. If you set the Virtual Memory size too large to support the intensive application, it is also not a good idea. Because it will create the performance lagging, and even it will take the HDD free space. The system needs to transfer the application data and instruction back and forth between the Virtual Memory and the System Memory. Therefore, that is not a good idea. The ideal size for the Virtual Memory is the default size of Virtual Memory, and it should not be exceed the value of the triple size of system memory.
To determine how much virtual memory you need, since the user's system contains the different amount of RAM, it is based on the system. By default, the OS will set the appropriate size for Virtual Memory. The default and appropriate size of Virtual Memory is:
* 1.5 =
For example, if your system contains 256 MB of RAM, you should set 384 MB for Virtual Memory.
256 MB of RAM (Main Memory) * 1.5 = 384 MB for Virtual Memory
If you would like to determine how much the Virtual Memory is for your system and/or would like to configure and add more virtual memory, follow the procedure that is shown below. The following procedure is based on windows XP Professional.
1-1) Go to right-click My Computer and choose Properties
1-2) In the System Properties dialog box, go to Advanced tab
1-3) Click Settings button that is from the Performance frame
1-4) Once the Performance Options shows up on the screen, go to Advanced tab
1-5) Under the Advanced tab, click the Change button from the Virtual Memory frame to access to the Virtual Memory setting
Then the Virtual Memory dialog box appears on the screen. In there, you are able to check how much the Virtual Memory you set. If you would like to modify the size of Virtual Memory, follow the procedure that is shown below.
2-1) In there, select the drive letter that is used to install the Operating System
2-2) Choose the option that says, "Custom Size:"
Once you choose that option, the setting for Initial Size and Maximum Size become available for you to set. Initial Size (MB) means the actual size of Virtual Memory, and Maximum Size (MB) means the maximum size of Virtual Memory that is allowed to use.
Let's say if your system contains 512 MB of RAM, then the ideal setting for the Virtual Memory is as follows:
Initial Size (MB): 768
Maximum Size (MB): 1500
Once you are happy with that Virtual Memory size, click the Set button from Paging file size for selected drive to apply the setting for the Virtual Memory size. Then click the OK button to apply the setting.
That's where you can manage and configure for the size of Virtual Memory.
Additional Information
* To maintain the good overall system performance, you should be using the default size of actual size for Virtual Memory and the triple the value of the size of the main memory for the maximum size of Virtual Memory. If you find that main memory plus virtual memory is not big enough to load the intensive application, then you will need to add more main memory onto your system.
Search Keyword
virtual memory
on Dec 02, 2009 | Computers & Internet
Virtual memory
Your hard drive is getting to full for it to be used as virtual memory
When normal memory gets used up windows uses the hard drive as memory ans if insufficient room on hard drive is not available you get this message.
1) delete programs from hard drive to create more space
2) Install new hard drive and transfer programs to it. creating more room on C drive
3) If hard drive is already partitioned and 2nd partition has a lot of free space transfer Virtual over to it.
Go to Start / Control panel Open The System folder go to "Advanced" "performance settings"
Then to "Advanced " Click on change and set Virtual memory to new disk.
Set maximum and minimum the same at 3 times the amount of normal memory you ave
Jan 05, 2009 | Computers & Internet
I need to increase virtual memory
I don't wish to sound rude but if you don't know how to do this, you prolly should just let windows continue managing it. A few wrong keystrokes can have major repurcussions
Jul 15, 2008 | Computers & Internet
Temporary Internet Files
Temporary internet files could harm your pc if the files contents virus, this could also slow your pc because if you have files that was infected with virus specifically the application files. Those files were automatically load into the services and in the processes and also in the start up without your consent. If all these files will run in the system this will cause " a low virtual memory" because the memory speicified was use by these useless and annoying application.
If you encounter these problem i would suggest that scan you computer with a potent antivirus, you should empty the temporary files and the recycled bin.
If you are sure that the computer is virus free and still encountering the "low virtual memory" you can increase your virtual memory by doing these:
1 right click my computer and then properties
2. click the advance tab
3. in the performance., click setting
4. then " advance tab"
5. in the virtual memory click change
6. check custom setting
7. in the initial size double the size of your memory
7. maximum double the initial size you setted.
If these will not solve the problem i would recommend you to format and reinstall your system.
Hope this help
Jan 22, 2008 | Computers & Internet
My vitual memory
it means the amount of hard drive free space is either low or it means you must increase the limit of this space. first remove any un-necessary files by doing the following: 1.) open explorer and click c drive. 2.) right click and select properties 3.) select "disk cleanup" now select the Tools tab above and select "check now" now select "Defragment now" next, right click "my computer" on desktop then select Advanced tab and select "settings" then select next Advanced tab and select "change" in the virtual memory area. type in the maximum under custom size and select "set" and ok out.
Sep 15, 2007 | Microsoft Windows XP Professional for PC
LG LW20-EV Notebook Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
