Question about Philips SPC 200NC Webcam
Uninstalled the camera but the "vm_sti.exe" is still eating my cpu
This process is eating %50 of my cpu: "vm_sti.exe"
You can see that it belongs to Philips SPC 200NC installation:
[BigDogPath] C:\WINDOWS\VM_STI.EXE Philips SPC 200NC PC Camera
Can you please help me clean this from my pc...?
Thanks,
Erdem
  • eyagan Sep 12, 2008
    Earlier the process was using %50 of my cpu and I was affraid to simply erase it.
    However, simply deleting the vm_sti.exe haven't caused a side effect yet.
    So it seems like the problem is solved.
    Thanks you for your help,
    Erdem
    Brigadier General:
  • 6,966 Answers
Your post ..."C:\WINDOWS\VM_STI.EXE...clean this from my pc..." would mean remove/delete.
Initially, pls try to:
  • Uninstall the Philips SPC 200NC;
  • Run in Safe mode and delete C:\WINDOWS\VM_STI.EXE;
  • goto Start, Run, type "msconfig", click on Startup, uncheck reference(s) to C:\WINDOWS\VM_STI.EXE;
  • open Windows Task Manager, Applications (or Processes), highlight VM_STI.EXE, click on End Process button.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Sep 12, 2008
Why is this file SSCKbdHk.exe appearing to cause problems?
I can't tell you what to do for your problem, however you have to decide what to do. Check the following information from http://www.file.net/process/ssckbdhk.exe.html
What is SSCKbdHk.exe?
SSCKbdHk.exe is a executable file (a program) within Windows. The filename extension .exe denotes an executable file. You should only run executable files from publishers you trust, because executable files can potentially change your computer settings or harm your computer. The free file information forum can help you determine if SSCKbdHk.exe is a virus, trojan, spyware, or adware that you can remove, or a file belonging to a Windows system or to an application you can trust.
SSCKbdHk.exe file informatiion.
The process known as SSCKbdHk belongs to software Samsung Support Center by SAMSUNG Electronics (www.samsung.com).
Description: SSCKbdHk.exe is not essential for Windows and will often cause problems. The file SSCKbdHk.exe is located in a subfolder of "C:\Program Files". Known file sizes on Windows 7/XP are 91,136 bytes (57% of all occurrences), 1,749,504 bytes and 4 more variants.[img src="http://www.file.net/img/space.gif" alt="http://www.file.net/process/ssckbdhk.exe.html" width="1" height="1">
The program has no visible window. It can change the behavior of other programs or manipulate other programs. SSCKbdHk.exe is not a Windows core file. The software can be uninstalled in the Control Panel. SSCKbdHk.exe is able to record inputs. Therefore the technical security rating is 42% dangerous, however also read the users reviews.
If problems with Samsung Support Center come up, you may want to uninstall it from your computer using the Control Panel applet "Add/Remove programs".
Recommended: Identify SSCKbdHk.exe related errors
Important: Some malware camouflages itself as SSCKbdHk.exe. Therefore, you should check the SSCKbdHk.exe process on your PC to see if it is a threat. We recommend Security Task Manager for verifying your computer's security. This was one of the Top Download Picks of The Washington Post and PC World.
Aug 15, 2014 | Samsung R530 Notebook
Svchost.exe: 50 - 70% CPU load The SVCHOST.exe is started from C:\windows\system32
Unless you have a program to identify it, you won't be able to tell just what program this is associated with. You can actually have 2-3 instances of this running.
Here's what you do: Go to this link: http://technet.microsoft.com/en-us/sysinternals
Download the process monitor. It will show you what files are associated with which process and allow you to see if you can safely kill the process.
Jun 13, 2011 | Microsoft Windows XP Professional w/SP1...
I cant download anything on my pc, it says winssnotify.exe unable to locate this application has failed to start because cert.dll was not found reinstalling may fixt it, and also it says, RUNDLL error...
winssnotify.exe is a program that is associated with windows "One Care." Unless you specified otherwise, you should see the One Care icon near running programs (area near the clock, on the bottom right of your screen). Go to Control Panel, uninstall/install programs and Reinstall or repair One Care. One Care is legit, and has firewall/virus options associated with it. If you recently uninstalled the program or installed another antivirus program, that may be your issue. If you uninstalled it, there may be files that were not removed or another program may have identified Onecare files as spyware. If you recently did anything like a "registry cleaner" or supposed "scan" of your system from a less than reputable online source, that can definitely be your issue. If you never downloaded Onecare, the program may be an imposter. It should be located under program files in the one care folder. If you do have this program, Onecare has a website scan to help users with problems. Hope this helps. Leave a comment if you need further assistance.
Nov 17, 2009 | Microsoft Windows XP Home Edition
Problem with rundell.exe and ntvdm.exe
dear mewms. I am using windows2003(vistacapable)& ie-7,this is office p.c, My problem is- Fewdays b4 I had got some virus-(funnyusscandal,killer.exe,lsass.exe,sms.exe,renounce.exe..and some more) At that time I was using avg7.0,but it had not helped me, Then I uninstalled avg... Read more
Jul 31, 2008 | IBM ThinkPad T60 Notebook
SYSTEM FREEZES WHEN CONNECTED TO INTERNET
You should try to test your memory (before windows boots.See download) to make sure the sticks are good. Download this. Next try using a program called Process Explorer to locate hanging modules of your computer. This will help you narrow it down.
Mar 05, 2008 | Computers & Internet
Slow data transfer rate
Do you have this Bios version? P5LD2-VM BIOS version 1303
Support new CPU's. Please refer to Asus website at: http://support.asus.com/cpusupport/cpusupport.aspx
Your board came out around June-2005 so improvements are here. I'm not saying its all about the CPU & FSB but it may help.
Jan 27, 2008 | ASUS P5LD2-VM Motherboard
Laptop computer lagging horribly
You have something running in the background that is eating up the CPU useage. You need to identify which process is doing this.
Use the built in task manager, using ctrl-alt-delete to bring it up, and see which process is at above 90% cpu usage. Then post back here what you find.
Oct 23, 2007 | Acer Aspire 5100-3357 Notebook
Philips SPC 200NC Webcam Logo
626 people viewed this question
Top Philips Computers & Internet Experts
Computer Repairing
Computer Repairing
micky dee
Are you a Philips Computer and Internet Expert? Answer questions, earn points and help others
